Page 1 of 3 1 2 3
Wheel Stud Spinning Can't Get Nut Off #1651733
07/27/14 08:40 PM
07/27/14 08:40 PM
Canton, Ohio
Crazy68Dart Offline OP
Canton, Ohio
Very productive day in the garage, getting close to the first drive of the Dart and on the last stud I was tightening on the rear wheel, the flipping stud spun on me and the nut won't back off.
A little background... the rear brakes are Ford disk brakes. The nuts are acorn style (closed) with a lock nut (which requires a key) for each wheel.
Tightening them on by hand, thought it was tightening fine, but stud started spinning. All I can imagine is that the splines on the back side of the stud have not engaged the disk. Nut was going on a little tight (just beyond what I could do with my fingers), so now I can't back it off either because the stud is spinning.
All I can think to do is remove the other 4 nuts and "wedge" between the mounting face of the wheel and disk hat to hopefully get the stud splines to grab.
This is on a D60 with Torino ends for the disk kit.
383, Hemi 4-Speed, AlterKtion, D60
Re: Wheel Stud Spinning Can't Get Nut Off [Re: Crazy68Dart] #1651734
07/27/14 09:38 PM
07/27/14 09:38 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
IF........You can wedge a bit of pressure on the nut/stud and use a high rpm air gun..the lugnut may back off...small prybar..careful not to damage wheel....
Re: Wheel Stud Spinning Can't Get Nut Off [Re: terzmo] #1651735
07/27/14 09:43 PM
07/27/14 09:43 PM
Canton, Ohio
Canton, Ohio
Wheel damage is the biggest concern since these are custom offset wheels.
There is no thread showing. The only place I have to wedge is on the "hat" of the disk between the face of the wheel.
Wish me luck...
Re: Wheel Stud Spinning Can't Get Nut Off [Re: Crazy68Dart] #1651736
07/27/14 10:14 PM
07/27/14 10:14 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Just pull on the wheel opposite where the stud is while you try to undo that lug nut. (With other 4 nuts already removed now)
Re: Wheel Stud Spinning Can't Get Nut Off [Re: buildanother] #1651737
07/27/14 10:25 PM
07/27/14 10:25 PM
Canton, Ohio
Canton, Ohio
Tried that... no luck. I am done for today. Tried the impact too, no luck. No good way to wedge anything between the wheel and disk.
This could not be any worse. The nut is on far enough that there are no threads showing and the wheel is pretty much seated against the disk. Very little wiggle room. The nut is into the taper/seat of the wheel.
I can't believe this. I guess I never put a nut on that stud in the 10 years this rear has been under the car. Only ever used three as I was just rolling the car around.
Re: Wheel Stud Spinning Can't Get Nut Off [Re: Crazy68Dart] #1651738
07/27/14 10:38 PM
07/27/14 10:38 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
you'll need a 3rd hand but if 4lugs are off, use the tire/wheel for leverage on the stud and try the impact
Re: Wheel Stud Spinning Can't Get Nut Off [Re: Crazy68Dart] #1651739
07/27/14 10:38 PM
07/27/14 10:38 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Use a die grinder with a carbide burr and just grind away at it until the nut is gone.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Wheel Stud Spinning Can't Get Nut Off [Re: Hemi_Joel] #1651740
07/27/14 11:16 PM
07/27/14 11:16 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
I had to use a die grinder once.....got the nut off but did put a couple knicks in the wheel. Luckily the wheel was not that nice anyhow. Good luck!
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: Wheel Stud Spinning Can't Get Nut Off [Re: Crazy68Dart] #1651741
07/27/14 11:43 PM
07/27/14 11:43 PM
North Pole,New York
formula_s Offline
formula_s  Offline
North Pole,New York
Here is your best tip: Take a center punch and mark the middle of the nut or stud,whichever is exposed. Now drill down the middle of it until its gone. Had this happen years ago with a nice Keystone wheel , no damage.
Re: Wheel Stud Spinning Can't Get Nut Off [Re: Crazy68Dart] #1651742
07/27/14 11:47 PM
07/27/14 11:47 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
The splines do not engage the disc, they engage the axle flange. Sounds like you have the wrong stud, or a wallered out hole.
Can you get to the back side of the stud at all? Since you were only hand tightening it you might be able to pry on the backside enough to unthread the nut.
Don't be the exception.
Re: Wheel Stud Spinning Can't Get Nut Off [Re: Supercuda] #1651743
07/27/14 11:56 PM
07/27/14 11:56 PM
N.W. Florida
Fat_Mike Online work
Fat_Mike  Online Work
N.W. Florida
That is what I was about to suggest. It's probably going to be cheaper to "modify" whatever is in the way on the back side than it would be to ruin that custom wheel. Good luck!
Re: Wheel Stud Spinning Can't Get Nut Off [Re: Fat_Mike] #1651744
07/28/14 12:19 AM
07/28/14 12:19 AM
Canton, Ohio
Canton, Ohio
Thanks for the tips. Yes, I meant to say axle flange, not disk.
This stuff is all brand new. I am thinking the stud was not seated/pulled into the axle flange, hence the issue.
It happens to to be the key nut, so that complicates things more.
I'm not sure if I can get to the back of the stud or not. Possibly if I destroy the disk dust shield. But the parking brake shoes, etc. might get in the way as they are internal design.
I don't see a way to grind the nut off. I'll get a shot with the camera tomorrow, but I am dealing with American Racing Torque Thrust II wheels, 11" wide with 5.5" backspacing.
Might be able to drill it out... not sure yet. Definitely no burs and/or grinding especially since the nut is nearly seated in the taper.
PITA.
Re: Wheel Stud Spinning Can't Get Nut Off [Re: Crazy68Dart] #1651745
07/28/14 12:30 AM
07/28/14 12:30 AM
Canton, Ohio
Canton, Ohio
Snapped some pics... Not sure, but thinking if I can get a porta power or something between the wheel and the disk and put some pressure against the wheel hoping to pull the stud into the flange. Long shot.
Re: Wheel Stud Spinning Can't Get Nut Off [Re: Crazy68Dart] #1651746
07/28/14 12:31 AM
07/28/14 12:31 AM
Canton, Ohio
Canton, Ohio
Re: Wheel Stud Spinning Can't Get Nut Off [Re: Crazy68Dart] #1651747
07/28/14 12:31 AM
07/28/14 12:31 AM
Canton, Ohio
Canton, Ohio
Re: Wheel Stud Spinning Can't Get Nut Off [Re: Crazy68Dart] #1651748
07/28/14 12:53 AM
07/28/14 12:53 AM
Overland Park, KS.
Joshs68 Offline
Joshs68  Offline
Overland Park, KS.
Mm that's ugly.
I was going to suggest drilling a hole in the stud and pounding an Allen wrench in the hole to hold the stud. That may be hard to drill through the end of the keyed nut, then a bigger hole in the nut so it will spin around the wrench.
Re: Wheel Stud Spinning Can't Get Nut Off [Re: Joshs68] #1651749
07/28/14 01:03 AM
07/28/14 01:03 AM
Raleigh, NC
Meangreen68 Offline
Meangreen68  Offline
Raleigh, NC
Start masking that wheel off with layers of duct tape. Wrap shim stock in areas where a cutter may nick if you accidentally lose control. Take a chisel and break off the center of the lug nut. Use a carbide burr until you can peel off that junk.
Re: Wheel Stud Spinning Can't Get Nut Off [Re: Meangreen68] #1651750
07/28/14 03:04 PM
07/28/14 03:04 PM
Canton, Ohio
Canton, Ohio
Could also (possibly) grind the tbolt heads at the back of the housing flange. I think then the whole wheel, disk, and axle assemble should pull out.
I really hope I can just get the stud bound up in some way to allow me to back the nut off without going to extreme measures.
Re: Wheel Stud Spinning Can't Get Nut Off [Re: Crazy68Dart] #1651751
07/28/14 03:12 PM
07/28/14 03:12 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Is the rear end an 8 3/4? If not, can you just pull the axle?
Re: Wheel Stud Spinning Can't Get Nut Off [Re: Crazy68Dart] #1651752
07/28/14 03:20 PM
07/28/14 03:20 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
I've used a chisel before and split the side of the nut from the front to the back and got it off. The TTII wheels are very tight around the studs. Patience will be the key here...
...FAFO...
Page 1 of 3 1 2 3
