2wd front coil springs Q's #1651480
07/27/14 08:30 AM
07/27/14 08:30 AM
dfw, Tx
AJP087 Offline OP
AJP087  Offline OP
dfw, Tx
So sometime in the next 6 months or so, when I have an area where I can do some wrenching, I plan on replacing my sagging coil springs.
I have already put some coil over rear shocks on, and that lifted the rear some. It has also made for a much softer ride.
The front coil springs are sagging I believe, and there is a very noticeable rake to it now.
I am wanting to lift the front to level with the rear, or as close as I can come.
Something I can do without any other mods other than swapping coil springs, and maybe a spacer on each of the torsion bars. It would have to also be able to be correctly aligned.
Comfortable ride would be nice too.
I've read some things about 1st gen cummins springs, moog 7272 van springs, and air shocks.
Any suggestions or advice?
Re: 2wd front coil springs Q's [Re: AJP087] #1651481
07/27/14 06:56 PM
07/27/14 06:56 PM
Hawley, Texas
shinnery Offline
super street
shinnery  Offline
super street
Hawley, Texas
Please refresh me on what this is? Coil springs AND torsion bars??
Bryce
Every electronic device is manufactured with smoke stored deep inside... only a true genius can find a way to set it free. The most terrifying words in the English language are: "I'm from the government and I am here to help!"
Re: 2wd front coil springs Q's [Re: shinnery] #1651482
07/30/14 03:57 AM
07/30/14 03:57 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
When did trucks get Torsion bars? Ive yet to see Torsion bars with Coils also
Re: 2wd front coil springs Q's [Re: 76dodgeboy] #1651483
07/30/14 04:11 AM
07/30/14 04:11 AM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
I believe it was 2002 on the Ram, and 87 on the Dakota.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: 2wd front coil springs Q's [Re: hp383] #1651484
07/30/14 04:25 AM
07/30/14 04:25 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
with coils?
Re: 2wd front coil springs Q's [Re: hp383] #1651485
07/30/14 03:10 PM
07/30/14 03:10 PM
Hershey, PA
73MagDuster Offline
73MagDuster  Offline
Hershey, PA
Only 4wd got torsion bars, not 2wd.
Re: 2wd front coil springs Q's [Re: AJP087] #1651486
08/01/14 04:37 AM
08/01/14 04:37 AM
dfw, Tx
AJP087 Offline OP
AJP087  Offline OP
dfw, Tx
Then what the hell is the bar that runs from the lower control arm to the front of the frame? The bar that keeps the control arm from bending when you brake. Sway bar bolts to it also. I've always thought it was called a torsion bar?
Original question in short. What can 2wd do for moderate lift?
Re: 2wd front coil springs Q's [Re: AJP087] #1651487
08/01/14 07:32 AM
08/01/14 07:32 AM
scratchnfotraction Offline
strut rod or strut bar
if you want it level find 2 of the rubber coil spring spacers and add them to the new coil springs.
Re: 2wd front coil springs Q's [Re: AJP087] #1651488
08/01/14 09:59 AM
08/01/14 09:59 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
That is only there to "Triangulate" the lower control arm. Vehicles with Coils springs dont have torsion bars that Ive seen yet.
Re: 2wd front coil springs Q's [Re: 76dodgeboy] #1651489
08/01/14 10:01 AM
08/01/14 10:01 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
As for lifting the front of a 72-93 you can use Coil spacers and or or 1 ton coils
Re: 2wd front coil springs Q's [Re: 76dodgeboy] #1651490
08/01/14 01:33 PM
08/01/14 01:33 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
I had lifted my '77 D150 back in 1990 when I was in school still... Superlift used to make lifted coils back then...in the olde days.
