Re: Spark plug wire recommendation
[Re: fullmetaljacket]
#1649540
07/25/14 11:52 AM
07/25/14 11:52 AM
Posts: 733 jacksonville,FLORIDA
slammedR/T
My only complaint with the firecore wires is my moroso had heat shrink sleeves over the boot and wire points and they had heat shrink cyliner markers on them. The firecore wires don't, just have the little white cylinder markers that always move and I hate them.
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
[Re: Thumperdart]
#1649543
07/25/14 02:25 PM
07/25/14 02:25 PM
Posts: 11,786 Portage,michigan
B3422W5
Portage,michigan
Count me solidly in the camp that believes there is virtually zero horsepower gain from one brand of wire to another... not squat... I would be be looking at heat shielding/ability to last being around heat, fit, and even appearance if its important to what a hobbyist has going on under the hood.... Hot rod magazine in fact a few years ago dyno'ed about 10 different wires and said the same thing in an article expressedly to clarify this myth...... So... not being a politician, I will buy wires that fit and are a nice color that matches my underhood.... I find it kinda funny that a fuel team would prefer one wire over another( assuming quality brands being used) because they make way more power than can be used anyhow... thats why clutches are set up to slip so much.... all a wire has to do is conduct output from coil to plug...it isn't rocket science..... good quality wire, connectors, insulation....you are plenty good to go....anything else is politics
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam, footbrake street/strip car Best so far, 10.32 1/4 1.41 best 60 foot 6.56 at 104.17
[Re: sunroofgtx]
#1649545
07/25/14 02:29 PM
07/25/14 02:29 PM
slammedR/T
I have Firecores on my small block, but have a new set of Magnecors to try. My Firecores are a ton long and the boots are huge. Good wires I'm sure, just don't care for the fit.
Wow, that's an old set. One of our originals from longer than 7 years ago, looks like. Haven't used those spark plug boots in a long time. The Pro-Fit sets are longer as to route around the valve covers so guys can lash the valves without taking off the wires. Pro-Fits are for engines with headers. The wire markers moving , must be a new 7mm set. Your Magnum should have 8.5mm wires on it. Markers will not move on them.
No, I sent in my old moroso and had you make me firecore50 set from them. My maggy motor is a 408 stroker with Indy heads, not stock. Also didn't mean any thing bad just being nit picky is all, I hate those msd plastic white markers.
[Re: Thumperdart]
#1649546
07/25/14 03:08 PM
07/25/14 03:08 PM
Posts: 11,702 W. Kentucky
justinp61
W. Kentucky
Did you have him send a basic set cos he`ll go off of your measurements and make em perfect like mine were.
Dom, I just called and ordered a set for a SBM .
