Do they make X/.001 undersized SB main bearings?
#1648871
07/20/14 09:32 PM
07/20/14 09:32 PM
Posts: 2,073 Tulsa, Ok
WadeMetzinger
Tulsa, Ok
Building a 416 street/strip stroker for a buddy and when checking today using micrometer on crank and inside mics on the torqued mains I'm getting .002 and would like to have .003 so wondering if anyone makes an X or .001 340 main bearing. If not I can take it back to the machine shop and have them align hone it again and get another . 001.
Wade Metzinger 918-809-0987 71 Cuda 9.28@145 -1s, Pglide 68 Cuda 10.64@124 1.45 60's 318->390 eddys Moparts discount code on WIX - moparts www.Filter1.com
Re: Do they make X/.001 undersized SB main bearings?
[Re: WadeMetzinger]
#1648872
07/20/14 09:46 PM
07/20/14 09:46 PM
Posts: 1,499 San Antonio,TX
440W8 Duster
San Antonio,TX
yes clevite does Wade MS540HXK.
70 Duster W8 motor. 1.29 60ft 5.79 1/8 at 120 mph glide with 1.80 gear @3170 lbs.
[Re: 440W8 Duster]
#1648874
07/21/14 12:02 PM
07/21/14 12:02 PM
WadeMetzinger
Tulsa, Ok
Thanks guys!
MS540HX is the non-coated X bearings, found some for $125 and will be delivered by Thursday.
[Re: WadeMetzinger]
#1648875
07/21/14 12:21 PM
07/21/14 12:21 PM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
That x bearing is a over size not under.
JAKES AUTOMOTIVE
[Re: WadeMetzinger]
#1648877
07/21/14 05:21 PM
07/21/14 05:21 PM
JAKE68
Shelby mi.
I knew what you ment I was just having some fun busting your chops!!!!
JAKES AUTOMOTIVE
