Pictures of fore/aft locators installed. motor plate #1648622
07/20/14 12:07 PM
07/20/14 12:07 PM
Mt.Vernon ,Ohio
VernMotor Offline OP
Mt.Vernon ,Ohio
I can't do them on the trans. Because the ears with the holes are cut off. both my trans are that way. so need some ideals Thanks
Re: Pictures of fore/aft locators installed. motor plate [Re: VernMotor] #1648623
07/20/14 12:27 PM
07/20/14 12:27 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Jamie I went off the motor mounts to the frame(I used
2, 1 on each side).. they are at about a 30* angle..
I'll see if I can find a pic
Re: Pictures of fore/aft locators installed. motor plate [Re: VernMotor] #1648624
07/20/14 01:09 PM
07/20/14 01:09 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
No pics but mine goes from the pass. motor mount foreward to the k member and is fully adjustable.
Re: Pictures of fore/aft locators installed. motor plate [Re: VernMotor] #1648625
07/20/14 08:30 PM
07/20/14 08:30 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I thought using the trans ears was a NO-NO
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Pictures of fore/aft locators installed. motor plate [Re: hemi-itis] #1648626
07/20/14 09:14 PM
07/20/14 09:14 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
I know many do it. sure would be easy ? I would think it would work ok.. But I do not know that for sure. Anyone here do it that way and had problems ?
Re: Pictures of fore/aft locators installed. motor plate [Re: VernMotor] #1648627
07/20/14 09:44 PM
07/20/14 09:44 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I know 3 or 4 guys that mount off the trans ears..
who ever said it was a no-no... and for what reason
Re: Pictures of fore/aft locators installed. motor plate [Re: MR_P_BODY] #1648628
07/20/14 10:01 PM
07/20/14 10:01 PM
hemi-itis Offline
hemi-itis  Offline
Mr P, it's just one of those things I've heard through the years. Limiters are on the bucket list along with "J" bars.
Re: Pictures of fore/aft locators installed. motor plate [Re: hemi-itis] #1648629
07/20/14 11:08 PM
07/20/14 11:08 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
I solid mount my transmissions. no need to add extra weight.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Pictures of fore/aft locators installed. motor plate [Re: bigtimeauto] #1648630
07/20/14 11:23 PM
07/20/14 11:23 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
But you run a mid plate. If I did that I would break tail shaft housings.
Re: Pictures of fore/aft locators installed. motor plate [Re: VernMotor] #1648631
07/20/14 11:43 PM
07/20/14 11:43 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I would never solid mount in 3 locations.. when the
chassis flexes something has to give.. and the tailshaft
is the weakest point
Re: Pictures of fore/aft locators installed. motor plate [Re: MR_P_BODY] #1648632
07/20/14 11:54 PM
07/20/14 11:54 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
then you need to build a stiffer chassis
Re: Pictures of fore/aft locators installed. motor plate [Re: VernMotor] #1648633
07/20/14 11:55 PM
07/20/14 11:55 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
I would never run a motor plate without a midplate
Re: Pictures of fore/aft locators installed. motor plate [Re: bigtimeauto] #1648634
07/20/14 11:58 PM
07/20/14 11:58 PM
MR_P_BODY Offline
MR_P_BODY  Offline
LOL... like yours dont flex
Re: Pictures of fore/aft locators installed. motor plate [Re: VernMotor] #1648635
07/21/14 12:02 AM
07/21/14 12:02 AM
So. IL. USA
PLUM BAD Offline
PLUM BAD  Offline
So. IL. USA
stock block
Indy block
On the stock block, I had to bush the hole in the block and notch the oil pan for the rod end to clear.
Re: Pictures of fore/aft locators installed. motor plate [Re: MR_P_BODY] #1648636
07/21/14 12:12 AM
07/21/14 12:12 AM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
evidently not.
Re: Pictures of fore/aft locators installed. motor plate [Re: VernMotor] #1648637
07/21/14 12:18 AM
07/21/14 12:18 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Jamie.. I've seen a few guys that made a bracket that
used 3 of the oil pan bolts and then to the K-member..
I believe they actually used studs(on the side of the pan)
Re: Pictures of fore/aft locators installed. motor plate [Re: MR_P_BODY] #1648638
07/21/14 01:17 AM
07/21/14 01:17 AM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Here's how I did mine.
Re: Pictures of fore/aft locators installed. motor plate [Re: MR_P_BODY] #1648639
07/21/14 02:24 AM
07/21/14 02:24 AM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
That is how we did it. Captured 4 ARP pan studs with a home-made bracket and an S&W Racecars kit (chrome-moly tube, rod ends and tabs for K-frame). When we got the car it didn't have one and the trans mount was destroyed. Have this one on the car for the last 5 years and it seems to work great. Studs provide enough strength with no deflection.
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: Pictures of fore/aft locators installed. motor plate [Re: Dads426] #1648640
07/21/14 08:27 AM
07/21/14 08:27 AM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
My chassis guy built a bracket that bolts to the pan rail. Hard to see the bracket in this pic.
Re: Pictures of fore/aft locators installed. motor plate [Re: Bigcube] #1648641
07/21/14 11:00 AM
07/21/14 11:00 AM
hemi-itis Offline
hemi-itis  Offline
Is that one or two limiters???
