Page 2 of 4 1 2 3 4
Re: How to make 1200-1300 streetable HP? [Re: 65 Hemi] #1648577
07/21/14 10:11 PM
07/21/14 10:11 PM
St.Louis, Mo.
mokid Offline
mokid  Offline
St.Louis, Mo.
Noy to Hijack this thread but whats your thoughts on a W8 R3 Turbo/Pro Charger build
Re: How to make 1200-1300 streetable HP? [Re: mokid] #1648578
07/30/14 01:07 PM
07/30/14 01:07 PM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
I have the KOS 499 out now and am gonna change it from nitrous to something else and a blower is one option. The motor has very serious heads and ran like poop N/A with those huge ports. So a F2 is better than a F1R for keeping the fuel req't lower?
Who has pics of one of these installed geared on a BB in an A body?
Re: How to make 1200-1300 streetable HP? [Re: Airwoofer] #1648579
07/30/14 02:31 PM
07/30/14 02:31 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
I'm partial to P/charger.
Re: How to make 1200-1300 streetable HP? [Re: bigtimeauto] #1648580
07/30/14 02:54 PM
07/30/14 02:54 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
I build a lot of 3600lb 8 second blow thru street cars. Pump gas on the street c-16 at the track. You can't go wrong with a blow thru f-2. Don't put to much stroke in it, its not a turbo.
Just curious, why run c-16 at the track? I was informed that there are plenty that run 1,200 hp turbo/supercharged apps with 10.5:1 compression on pump gas only.
Re: How to make 1200-1300 streetable HP? [Re: TheOtherDodge] #1648581
07/30/14 05:09 PM
07/30/14 05:09 PM
Here is the best way to do what you asked
Re: How to make 1200-1300 streetable HP? [Re: TheOtherDodge] #1648582
07/30/14 05:25 PM
07/30/14 05:25 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
non intercooled. If you want to add the weight and the plumbing for a A/A or A/W intercooler then yes.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: How to make 1200-1300 streetable HP? [Re: bigtimeauto] #1648583
07/30/14 07:39 PM
07/30/14 07:39 PM
Houston, Texas
Houston, Texas
Awesome! I didn't realize you could make that much power at that compression ratio with just an intercooler on pump gas with no meth, etc.
Re: How to make 1200-1300 streetable HP? [Re: 65 Hemi] #1648584
07/30/14 08:17 PM
07/30/14 08:17 PM
Thank you for your input and help.
I have been leaning towards my 583 B1MC motor and changing pistons and cam and adding a F2 gear drive or side slinger with no inter cooler.
I agree on your choice on the Pro charger, which fuel do you wan to use on the street? If E85 is doable then forget the intercooler, if gasoline I would run a water to air intercoller and use ice in it as needed As far as street motor on gasoline I have built several hemi with roots type superchargers, 10:71 with both EFI and dual dominator carbs, 1300 HP was reach with a lot of work out of a 499 C.I. motor on race gas with Motech EFI The larger B1-MC motor with the right compression ratio should make as much or real close to the same HP per C.I. as the Hemiroids did, intercooling can help a bunch when it comes to using and compressing air for your motor IHTHs
Re: How to make 1200-1300 streetable HP? [Re: BobR] #1648585
07/30/14 08:36 PM
07/30/14 08:36 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Man that thing is sweet......and really fast.
Re: How to make 1200-1300 streetable HP? [Re: Cab_Burge] #1648586
07/30/14 10:41 PM
07/30/14 10:41 PM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
Thank you for your input Cab and Big Times. I respect what you have done and believe that both of your knowledge has great value. I will be posting more questions and updates as I go. The build will include E 85 since it is local get buy.
Doug
MOPAR or NO CAR!!!
1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas
1964 Dodge Polara 582" Indy alum Block 426-1RA heads,
1933 Plymouth PE all Steel, LT1 4L60E
1959 Plymouth Savoy 33,000 mile survivor
Old cars are never done. They are ongoing projects!
Re: How to make 1200-1300 streetable HP? [Re: 65 Hemi] #1648587
07/31/14 11:50 AM
07/31/14 11:50 AM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
Let's take this procharger discussion to the next level - gear drive or cog belt? The guys at Supercharger Store are pretty negative about the cog belt and are pumping the gear drive now. Problem is the little A body doesn't have much room behind the bumper/valance.
They are also saying that with a F1R 1300 HP on pump swill is doable and more so with a F2. 12 points of boost and windshield washer injection. Any real world experience out there in Moparland? What about a RB vs B based block with a 4.5 bore either way?
Re: How to make 1200-1300 streetable HP? [Re: Airwoofer] #1648588
07/31/14 12:06 PM
07/31/14 12:06 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
I have both combos, I ran a f-2 cog side slinger for the last 5 years making 24lbs no issues. now I have the gear driven chris alston drive.
Re: How to make 1200-1300 streetable HP? [Re: bigtimeauto] #1648589
07/31/14 12:47 PM
07/31/14 12:47 PM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
How bad was it at throwing belts, if at all? I will be streeting this as well as trackin. Looks like it is a much cleaner install with the belt and an air cleaner is also easire to put on. This ain't gonna be no X275 car with a round hole in the front.
Re: How to make 1200-1300 streetable HP? [Re: Airwoofer] #1648590
07/31/14 12:55 PM
07/31/14 12:55 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
I never threw a belt. it is driven on the street still. rad is in the back and the lic plate on the front is dual locked
Re: How to make 1200-1300 streetable HP? [Re: bigtimeauto] #1648591
07/31/14 04:27 PM
07/31/14 04:27 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
We run the gear drive from the Supercharger Store and it is rock solid. Never had a problem and we run more than 50 pounds boost spinning really fast.
Re: How to make 1200-1300 streetable HP? [Re: camastomcat] #1648592
07/31/14 04:31 PM
07/31/14 04:31 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Doug built the car in his garage. Crazy knowledge and skills.
Re: How to make 1200-1300 streetable HP? [Re: BobR] #1648593
07/31/14 05:00 PM
07/31/14 05:00 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
the problems with the supercharger store gear drives is not the quality or reliability its the fact that you need special gears for them and they do not make all of the accessory drives.
Re: How to make 1200-1300 streetable HP? [Re: bigtimeauto] #1648594
07/31/14 06:06 PM
07/31/14 06:06 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Chris Alston also makes a nice unit that is actually very similar to the SS unit. Don't know how his parts support is. So far we have been able to get everything we needed.
Re: How to make 1200-1300 streetable HP? [Re: bigtimeauto] #1648595
07/31/14 10:10 PM
07/31/14 10:10 PM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
Hi Bob, since your car is for sale any chance you want to sell your side slinger set up? If so please pm a price and what it includes. I want to try a couple of Josh's races but know I can't get it done NA. My Dart is perfectly set up with a stock fire wall and bolt on strut/k member.
Doug
MOPAR or NO CAR!!!
Twin Turbo [Re: 65 Hemi] #1648596
07/31/14 11:15 PM
07/31/14 11:15 PM
Cincinnati OH
Bishop Offline
Bishop  Offline
Cincinnati OH
Page 2 of 4 1 2 3 4
