Trans Stuff
#1648311
07/19/14 05:49 PM
07/19/14 05:49 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Guys I'm looking for a OD assembly for a hyd 518.. any one know where they can be found... looks like I messed up on the assembly before EDIT Just for Slippery440(so he wont have this post dumped) this is RACE stuff.. the power has to go through the OD unit weather its turned on or not)... he has the tendency to call the mods if HE thinks its not a related topic
Re: Trans Stuff
[Re: ntstlgl1970]
#1648313
07/19/14 09:18 PM
07/19/14 09:18 PM
MR_P_BODY
PATC used to sell complete OD units, but I don't know if they were for the hydraulic or the electronic version of the trans. What is wrong with yours?
I failed to put the torrington bearing in and it ate the back end up and I think its gonna be cheaper to get the whole OD assembly than replace the parts.. I was gonna call them today but I figured I'd call a few other places(and did) but Cope wasnt open and SMR didnt have anything
Re: Trans Stuff
[Re: MR_P_BODY]
#1648314
07/19/14 10:01 PM
07/19/14 10:01 PM
Posts: 276 Temecula, Ca.
zzyzxpat
Temecula, Ca.
Just so you know, the OD section is the same , electronic or not. The differences are, the early were 22* planet pinion angles which created excessive thrust, which loaded the bearings and planet, and the later units which they went to 15* on the planet, sungear and ring gear, less thrust load. There are differences in the number of clutches in the OD direct, which for a gas engine should be 8, or for a diesel or V10, should be 10. You can play around with the number of OD brake clutches by changing the pressure plates.
It's all common stuff, any trans parts house will have it.
Pat
" The last official act of any goverment, is to loot the treasury" George Washington
Re: Trans Stuff
[Re: zzyzxpat]
#1648315
07/19/14 10:12 PM
07/19/14 10:12 PM
MR_P_BODY
Pat
The electronic version doesnt have a governor on the output shaft and the hyd version does.. I want the governor sytle
Re: Trans Stuff
[Re: MR_P_BODY]
#1648316
07/20/14 02:25 AM
07/20/14 02:25 AM
MR_P_BODY
BTT.... any help from the west coast guys.. I want to get this thing back together QUICK... WOODWARD CRUISE is around the corner
Re: Trans Stuff
[Re: Twostick]
#1648321
07/20/14 08:00 AM
07/20/14 08:00 AM
Posts: 20,272 north of coder
moparx
I know my trans guy uses the OD from a 618 in his builds. He has one behind a Hemi in his 64 wagon, push buttons and all.
Kevin
how did he adapt the od unit to the pb. case ? or is this a later transmission with the "imperial services" modification ?
Re: Trans Stuff
[Re: tboomer]
#1648324
07/20/14 11:05 AM
07/20/14 11:05 AM
MR_P_BODY
Mike....Did you try Rock Auto?
No I didnt... but I may have found something local but I need to call
Re: Trans Stuff
[Re: moparx]
#1648328
07/20/14 02:59 PM
07/20/14 02:59 PM
Posts: 6,621 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Kevin
It's a 518 with the JVX (sp?) adapter and he made his own set-up for the typewriter shifter. Not sure how he did it but he's a pretty sharp guy.
Kevin
Re: Trans Stuff
[Re: MR_P_BODY]
#1648329
07/20/14 06:21 PM
07/20/14 06:21 PM
zzyzxpat
Temecula, Ca.
Pat
Didn't figure you needed the output shaft.
Pat
