Shorty water pump for 440?
#1647094
07/15/14 11:32 PM
07/15/14 11:32 PM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
Does anyone make a short water pump for a big block? Trying to get some clearance on a very tight build. We won't be using the stock fan, or anything like that. Still running an alternator though. Thanks!
Re: Shorty water pump for 440?
[Re: dave571]
#1647095
07/16/14 12:04 AM
07/16/14 12:04 AM
RapidRobert
Not to my knowledge but you can press the "cross" rearward a bit (support the shaft on the back side if you ever do this) but the limiting factor is the clearance between the pulley groove to the pump 4 bolts & you'd need a shallower pulley and a pulley with a straight barrel rather than a tapered barrell may help with the clearance inside the barrel (been a long time since I dealt with that) but I remember an issue there. Easier might be to mill the pump housing rear face to move the whole shebang rearward then reestablish pulley alignment. there is a part number for a short fan extension (jaguar?) that has been used by us. EDIT now I remember, a non tapered pulley barrel did not touch the pump body shank
[Re: RapidRobert]
#1647096
07/16/14 09:53 AM
07/16/14 09:53 AM
Posts: 21,050 Niles , Ohio
therocks
Niles , Ohio
You can use button head allens to hold the pump to body.March pulleys use them.I had a set from when we installed the Marchs on our BBs.But they are hidden somewhere.Small parts always hide in one of my garages.Rocky
Chrysler Firepower
