AFCO DOUBLE SETTINGS #1646870
07/15/14 01:14 PM
07/15/14 01:14 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
Just wondered what others were setting these at.
I've got mine at 8 from full tight on comp and 13 from full tight on rebound. This was on a reasonable track with SS springs and calvert 90/10 fronts. Ran a best 1.41 at 10.26 on a fairly warm day.
I'd like to get into consistent 1.30's if i could, so any and all advice is welcome.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: AFCO DOUBLE SETTINGS [Re: deaks] #1646871
07/15/14 03:02 PM
07/15/14 03:02 PM
Arlington, Tx.
BJS racing Offline
BJS racing  Offline
Arlington, Tx.
It is literally all about your car and what it wants. No one else's car is going to have the exact same settings as your would. The shock settings in many cars that do enough testing and racing might have a setting for a certain track at a certain time of the day and change later in the day or when they go to another track. I've worked on cars where I changed the shock setting every pass. You have to play with them and see what the car does and see what it likes. It will be a totally different set up on a ladder bar then a 4 link.
Back in the swing of things at Painless again! Great to be back!
Re: AFCO DOUBLE SETTINGS [Re: BJS racing] #1646872
07/15/14 03:10 PM
07/15/14 03:10 PM
MR_P_BODY Offline
MR_P_BODY  Offline
.. just different weights and torque will
be way different on settings let alone the type of
suspension
Re: AFCO DOUBLE SETTINGS [Re: MR_P_BODY] #1646873
07/15/14 05:02 PM
07/15/14 05:02 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
I just thought someone might chime in with a similar set up. I've read stuff on the net, where people are running the comp on full tight and the extension really loose. My old 9 way ranchos were simple, most of the time they were on either 8 or 9.
best 60ft 1.36
Re: AFCO DOUBLE SETTINGS [Re: deaks] #1646874
07/15/14 06:07 PM
07/15/14 06:07 PM
Arlington, Tx.
BJS racing Offline
BJS racing  Offline
Arlington, Tx.
The closer you get to that will plant the tire harder and keep it there but you can also go too far and it will actually start slowing you down and making the car less consistant.
Re: AFCO DOUBLE SETTINGS [Re: BJS racing] #1646875
07/15/14 10:27 PM
07/15/14 10:27 PM
British Columbia
toddd Offline
toddd  Offline
British Columbia
Get someone to vid your launch and post the vid.
Re: AFCO DOUBLE SETTINGS [Re: toddd] #1646876
07/16/14 01:01 AM
07/16/14 01:01 AM
MR_P_BODY Offline
MR_P_BODY  Offline
This is a very good way to see what is REALLY happening
and not just a guess
Re: AFCO DOUBLE SETTINGS [Re: MR_P_BODY] #1646877
07/16/14 09:03 AM
07/16/14 09:03 AM
gregsdart Offline
gregsdart  Offline
How consistent are the 60 fts? If they are real close, your shock settings might be very close. If they are all over the place, like more than .01 or .02 apart, then due to the SS springs I would start at full tight on extension and see if it hooks at the hit. You need video to watch, and go frame by frame to see what is happening. If it hooks well at the hit but spins later, you might still not have enough shock control for the high leverage of the SS springs. If it spins, then hooks, start loosening them.
What does the rear shackle angle and length look like? If they are long, and angled at a 45 degree angle toward the rear, they will really increase the separation at the hit.
Re: AFCO DOUBLE SETTINGS [Re: gregsdart] #1646878
07/16/14 12:54 PM
07/16/14 12:54 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
They vary more than that, leaf springs are clamped on the front, factory shackles angled as per the mopar manuals. I have just recently moved the shocks in front of the axle and vertical. I tightened the extension and comp 4 clicks on sunday and went from 1.43 to 1.41.
Why do you say full tight on ext and what would you do with the comp with that setting ?
I thought the looser the ext, the tighter the comp to keep the tyres planted.
Thanks Mick
best 60ft 1.36
Re: AFCO DOUBLE SETTINGS [Re: deaks] #1646879
07/16/14 01:02 PM
07/16/14 01:02 PM
Arlington, Tx.
BJS racing Offline
BJS racing  Offline
Arlington, Tx.
Thanks Mick
Moving the shocks just changed the amount of force and the speed the shock works at as well as changing the angle of the shock. More than likely the same results could have been had by just changing the adjustment on the shock in the location they were in. The adjustments on the shocks are just like jets or idle mixtures on a carb. You can use them to tune the way the car works. Every time you make an adjustment it will have an affect on the car one way or the other. When you move the shock to the front of the axle the load on the shock will increase compared to it being mounted behind the axle. There for to have the same type of suspension set up you would have to tighten the setting to achieve the same result. Is it possible to get video of the car launching?
Re: AFCO DOUBLE SETTINGS [Re: deaks] #1646880
07/16/14 01:05 PM
07/16/14 01:05 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Sliders really helped controll the rear on my dart but not sure on the ss springs which I changed to Calvert monos years ago...........
Re: AFCO DOUBLE SETTINGS [Re: Thumperdart] #1646881
07/16/14 01:27 PM
07/16/14 01:27 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
Here is vid but it may not be very clear because it was a spectator i'm in the orange Dart at 3.20.
https://www.youtube.com/watch?feature=player_embedded&v=2AaKaygn72o
best 60ft 1.36
Re: AFCO DOUBLE SETTINGS [Re: deaks] #1646882
07/16/14 02:12 PM
07/16/14 02:12 PM
Arlington, Tx.
BJS racing Offline
BJS racing  Offline
Arlington, Tx.
What torsion bars and shocks do you have up front? Looks to me like you could use a little loser front end to help pitch rotate the car (weight transfer). The tire is spinning then hooking from what I could tell. Very nice car by the way! I would loosen the extension on the rear shocks and leave the compression and see what that does. What RPM are you leaving at?
Re: AFCO DOUBLE SETTINGS [Re: BJS racing] #1646883
07/16/14 03:49 PM
07/16/14 03:49 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
I have 6 cyl torsion bars, calvert 90/10 shocks, i flash stall it from around 2500 rpm, converter is UCC 5000 stall. Tyres are 31 x 10.5 hoosiers with tubes.
I didn't think it was clear enough to tell.
Mick
best 60ft 1.36
Re: AFCO DOUBLE SETTINGS [Re: deaks] #1646884
07/17/14 06:37 PM
07/17/14 06:37 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
Right, i've been looking at my settings, on the vid posted, i had the extension set on 24 from full soft out of a possible 40 clicks. On the afco instructions, for heavy door cars slower than 9.90 at the faster end it says 6-8 clicks from full soft, i've moved it to 8 for next time out.
On the comp i had 14 clicks from full soft out of a possible 24.
Afco says for 12-16 from full soft, so i've moved them to 16.
So basically, the comp is around the same but i've loosened the ext 8 clicks.
Mick
best 60ft 1.36
Re: AFCO DOUBLE SETTINGS [Re: deaks] #1646885
07/17/14 07:10 PM
07/17/14 07:10 PM
Arlington, Tx.
BJS racing Offline
BJS racing  Offline
Arlington, Tx.
Mick
I think that will help from the video I saw but you will notice a difference good or bad when you go out. Let us know what happens.
Re: AFCO DOUBLE SETTINGS [Re: BJS racing] #1646886
07/17/14 07:47 PM
07/17/14 07:47 PM
British Columbia
toddd Offline
toddd  Offline
British Columbia
Doesn't look that bad, hard to tell though.
Put a wide white stripe on the tire and a mark on the quarter panel too.
I also rub white shoe polish around the circumference of the tire to see what it looks like at the hit and during acceleration.
Keep picking away at it, you'll get it.
Re: AFCO DOUBLE SETTINGS [Re: toddd] #1646887
07/17/14 07:54 PM
07/17/14 07:54 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
My phone contract is up, they're going to give me a new phone with a better deal. The new one has frame by frame playback. Just need a friend with a steady hand. Lol
Thanks for sll the tips
Mick
best 60ft 1.36
Re: AFCO DOUBLE SETTINGS [Re: deaks] #1646888
07/17/14 08:28 PM
07/17/14 08:28 PM
San Antonio,TX
440W8 Duster Offline
San Antonio,TX
But if the shocks are mounted in front of the diff. don't that change how the shock reacts? Also if you make any shock adjustments you need to make them bye 4 clicks at a time to notice to see if it works.
70 Duster W8 motor.
1.29 60ft 5.79 1/8 at 120 mph
glide with 1.80 gear
@3170 lbs.
Re: AFCO DOUBLE SETTINGS [Re: 440W8 Duster] #1646889
07/17/14 09:31 PM
07/17/14 09:31 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes it does change the way the shock reacts due to the
difference in leverage... and yes if he has 40 points
of adjustment then he can go 4 or 5 clinks at a time
to see a change
