Page 1 of 3 1 2 3
Problem with my axle berrings #1646010
07/13/14 05:43 PM
07/13/14 05:43 PM
South San Francisco, Californi...
MidPenMopar Offline OP
Looking for fun? Keep looking
Hey guys the roadrunner just ate up the "Green" berrings after only a few thousand miles.
I know when i had the REAR disc brake set up installed by a local shop the instructions called for replacing the factory taper berrings with the GREEN berrings for some reason??
Now that these green berrigns failed so quickly is it possible to go back to the stock Timkin berrings and not use the GREEN ones any more??
Thanks for help.
Stu
Re: Problem with my axle berrings [Re: MidPenMopar] #1646011
07/13/14 05:49 PM
07/13/14 05:49 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
if you are running an set of aftermarket rear disc brake set up like strange..wilwood...the green bearing are necessary....
Tony
70 AARCuda Vitamin C
Re: Problem with my axle berrings [Re: 70AARcuda] #1646012
07/13/14 05:52 PM
07/13/14 05:52 PM
Ok, but why would they only last a few thousand miles???
I did some reading and they said they are for racing only and not to be used for a street car??
Could they just have been a bad set??
Re: Problem with my axle berrings [Re: 70AARcuda] #1646013
07/13/14 05:55 PM
07/13/14 05:55 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Hey Stu,
Not all kits require the "Green" bearings. Some kits such as ones available from DrDiff allow the use of the factory Timkens. Also, GREEN is a brand name. There are a few companies that make these non adjustable replacement bearings. I don't know if they all are just as unreliable, but I assume that they would be. They are a BALL bearing with only a fraction of the contact area of the tapered roller bearings from Timken.
My Charger is on the second failing set in 9000 miles. There are some Mopar guys that are totally in love with these POS bearings but I certainly am not one of them.
I prefer corners to drag racing and I have learned that they are terribly inadequate. I have the Dr Diff rear disc kit and plan to return to the stock type bearings soon.
Re: Problem with my axle berrings [Re: MidPenMopar] #1646014
07/13/14 05:55 PM
07/13/14 05:55 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
The Dr. Diff rear disc brake setup I have in my 68 Valiant runs factory tapered bearings. You might want to give Cass a call.
Re: Problem with my axle berrings [Re: MidPenMopar] #1646015
07/13/14 05:55 PM
07/13/14 05:55 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Did they remove the thrust block from the differential?
Re: Problem with my axle berrings [Re: bobby66] #1646016
07/13/14 06:00 PM
07/13/14 06:00 PM
Dont know what that in unfortunately.
I bought the SSBC rear disc kit and for whatever reason they mandated the ball berring type and not the tapered type.
Would this be for some clearance issue on the axles maybe??
Re: Problem with my axle berrings [Re: MidPenMopar] #1646017
07/13/14 06:04 PM
07/13/14 06:04 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
I think it has to do with the axle endplay tends to change as the brake pads wear. The Dr Diff and a few other kits somehow have a way around that.
Re: Problem with my axle berrings [Re: Kern Dog] #1646018
07/13/14 06:48 PM
07/13/14 06:48 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
If the thrust block is present it may put a load on the bearings, pushing out on them and leading to premature failure.
Re: Problem with my axle berrings [Re: bobby66] #1646019
07/13/14 06:52 PM
07/13/14 06:52 PM
OK so with greens you do NOT want the thrust block in there?
Re: Problem with my axle berrings [Re: bobby66] #1646020
07/13/14 06:58 PM
07/13/14 06:58 PM
Well now this is interesting.
Maybe that is the case??
Re: Problem with my axle berrings [Re: MidPenMopar] #1646021
07/13/14 08:04 PM
07/13/14 08:04 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Stu, I wiped a set of greens myself by leaving block in place. Not all block equipped rears have that interference though. I would ask the doc as suggested. In my case , I was able to grind almost 1/8" off of each axle, re-istall new greens and they then lived a happy life.
Re: Problem with my axle berrings [Re: MidPenMopar] #1646022
07/13/14 08:11 PM
07/13/14 08:11 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
More than likely the case , the only way around it is to cut your axles if you have a cone type sure grip because the only way to remove the thrust block from a cone type is to disassemble the sure grip.
Re: Problem with my axle berrings [Re: MidPenMopar] #1646023
07/13/14 08:14 PM
07/13/14 08:14 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Rigid calipers don't like any axle end play, the rotors need to stay in the same relative in/out position that's why many brake kits require the Greens.
I still believe there's no reason why the factory taper bearings can't be adjusted for a little preload on the bearings instead of the mandated few thousands end play...tapered front wheel bearings tolerate preload, why not the rears?
Re: Problem with my axle berrings [Re: John_Kunkel] #1646024
07/13/14 08:27 PM
07/13/14 08:27 PM
Thank you everyone for the help. I understand now why the tapered berrings needed to be changed.
I will take all your advice and suggestions and see if we cant get this rectified somehow.
Stu
Re: Problem with my axle berrings [Re: MidPenMopar] #1646025
07/13/14 08:50 PM
07/13/14 08:50 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
BEARINGS!!!
Re: Problem with my axle berrings [Re: stumpy] #1646026
07/13/14 09:31 PM
07/13/14 09:31 PM
BEARINGS!!!
Sorry ......I stand corrected.... Bearings
Re: Problem with my axle berrings [Re: John_Kunkel] #1646027
07/13/14 10:03 PM
07/13/14 10:03 PM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
Always wondered about this myself.
BEARINGS!!!
I think stumpy needs a hug.
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: Problem with my axle berrings [Re: I_bleed_MOPAR] #1646028
07/21/14 09:24 PM
07/21/14 09:24 PM
Ok so as suggested a cause of the problem was when i had the rear disc brake conversion done the shop that did it left the crush washer in. This caused the problem of the bearings failing. Its all apart and getting fixed as i type.
Thanks for the advice!!
Re: Problem with my axle berrings [Re: MidPenMopar] #1646029
07/21/14 10:46 PM
07/21/14 10:46 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Stu there are hundreds of thousands of Toyota pickup trucks out there with the same basic radial ball bearings as your "green" bearings and they live long tortured lives for over 100K.
The first question I ask when setting up a rear is what kind of axle bearings are you going to use? Rollers get the spacer and ball bearings do not.
I would really call the expert Cass (doctordiff) for your options on tapered roller bearings if you don't want to disassemble your differential. There may be a bearing retainer that you can shim like a Ford pickup uses to adjust the axle endplay.
Gus
64 Plymouth Savoy
Dana 60
Page 1 of 3 1 2 3
