Re: Problem with my axle berrings
[Re: MidPenMopar]
#1646011
07/13/14 05:49 PM
07/13/14 05:49 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
if you are running an set of aftermarket rear disc brake set up like strange..wilwood...the green bearing are necessary....
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 70AARcuda]
#1646012
07/13/14 05:52 PM
07/13/14 05:52 PM
Posts: 36,840 South San Francisco, Californi...
MidPenMopar
Looking for fun? Keep looking
Ok, but why would they only last a few thousand miles???
I did some reading and they said they are for racing only and not to be used for a street car??
Could they just have been a bad set??
[Re: bobby66]
#1646016
07/13/14 06:00 PM
07/13/14 06:00 PM
MidPenMopar
Did they remove the thrust block from the differential?
Dont know what that in unfortunately.
I bought the SSBC rear disc kit and for whatever reason they mandated the ball berring type and not the tapered type.
Would this be for some clearance issue on the axles maybe??
[Re: bobby66]
#1646019
07/13/14 06:52 PM
07/13/14 06:52 PM
RapidRobert
OK so with greens you do NOT want the thrust block in there?
[Re: MidPenMopar]
#1646022
07/13/14 08:11 PM
07/13/14 08:11 PM
Posts: 75,071 U.S.S.A.
JohnRR
U.S.S.A.
If the thrust block is present it may put a load on the bearings, pushing out on them and leading to premature failure.
Well now this is interesting.
Maybe that is the case??
More than likely the case , the only way around it is to cut your axles if you have a cone type sure grip because the only way to remove the thrust block from a cone type is to disassemble the sure grip.
[Re: MidPenMopar]
#1646029
07/21/14 10:46 PM
07/21/14 10:46 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
Stu there are hundreds of thousands of Toyota pickup trucks out there with the same basic radial ball bearings as your "green" bearings and they live long tortured lives for over 100K. The first question I ask when setting up a rear is what kind of axle bearings are you going to use? Rollers get the spacer and ball bearings do not. I would really call the expert Cass (doctordiff) for your options on tapered roller bearings if you don't want to disassemble your differential. There may be a bearing retainer that you can shim like a Ford pickup uses to adjust the axle endplay. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
