'51 Coronet rear end upgrade? #1644912
07/10/14 12:23 PM
07/10/14 12:23 PM
Lemont, IL
Not_A_Blazer Offline OP
super gas
super gas
Lemont, IL
I'm working on my '51 club coupe,swapping in a 318/904 that I had lying around,wondering if anyone has done a similar swap,and what rear end did you use? I've heard a jeep cherokee rear will fit with spring perches flipped,but which gear ratio would be best to look for behind the 904?
Re: '51 Coronet rear end upgrade? [Re: Not_A_Blazer] #1644913
07/11/14 12:08 AM
07/11/14 12:08 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Under the sheet metal, the frame & suspension isn't much different then any 46-48 Mopar. There is a lot of info concerning this swap here and several other places, a Google search should find you hours of reading and pictures.
Basically, you off set the motor & trans about a inch and a half towards the passenger side so the exhaust clears the steering column and make motor mounts.
The Jeep rear end is a good choice, as well as several others.
According to my book, the shipping weight of a 51 Coronet club coupe is 3410 lbs, and the flathead 6 your removing weighs more then the 318/auto your installing. Pretty much any gear ratio will work out. Personally, I'd go for something in the 3:21 range, but a 2:76 would work as well, limited slip optional. If you use the OD trans, a 3:55 works well. Gene
Re: '51 Coronet rear end upgrade? [Re: poorboy] #1644914
07/13/14 01:11 AM
07/13/14 01:11 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
check the D/24-P/15 SITE lot of those type cars over there good luck nice project
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
