Re: nitrous, turbo, procharger or all motor?
[Re: Cab_Burge]
#1644314
07/09/14 10:01 PM
07/09/14 10:01 PM
Posts: 2,412 Weatherford, Texas
RapidusMaximus
Weatherford, Texas
Make the motor either a 512 C.I., 4.250 stroke with a 4.375 bore, or a 518 C.I. 4.300 stroke same bore size as the 512. Shoot for 10.5 to 10.8 to 1 compression ratio for 91 octane pump swill and work on the rear suspension to make it hook anywhere and go have fun. My 612 HP 512 C.I. pump gas motor in my 3450 lb street Duster ran [Email]10.69@124.+[/Email] MPH through the muffs first timeout That was with ported 906 iron heads, I swapped the heads to a set of CNC ported Eddy RPM and the car ran 10.49 at 127.+ MPH. That was on a set of 30.5x13x15 M/T ET Street bias plys tires The last time I raced it it had a set of Indy SR M.W. heads and intake and ran 9.993 at 134.+ MPH through the muffs on straight Oregon 91 octane non ethanol pump swill You can get the same results also
Good info Cab, thanks, gives me alot to think about. Got a buddy with a ford who is really tweaking me to turbo it and he's willing to help with the fab so I'm mulling that over...the GTX restoration is moving along so while it's in the paint shop I'll have some time to start on the Duster.
1968 Plymouth GTX 1974 Dodge P/U Long Bed Stepside 318 2019 Ram 2500 6.4, auto, 4WD
[Re: TheOtherDodge]
#1644315
07/10/14 12:54 AM
07/10/14 12:54 AM
Posts: 3,429 Toronto
mshred
Toronto
Need to know more about your goals...
Do you want a big, loud thumper that sounds intimidating? If so, motor only, but prepared to lose some driveability and have some maintenance.
Do you want med sound with that whine sound? Supercharged, but you will still have some maintenance.
Do you want quiet and unassuming? Turbo. And very little maintenance because you can run a small cam, not a lot of gear and converter and the turbo will eat a lot of the exh sound.
TURBO hands down! For a true street car, nothing beats having GOBS of power, a very streetable rear gear that lets you cruise anywhere, and a very unassuming sounding car (helps with cops and for cleaning the clocks off the ball washers who think they have enough lol).
You say 10's are all you want...and yes, N/A will get you there...but you will want more...thats when you will wish you had a power adder. And when it comes to all around streetability, you cant beat turbos imo
Good luck with it! ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: mshred]
#1644316
07/10/14 08:10 AM
07/10/14 08:10 AM
RapidusMaximus
Weatherford, Texas
Good luck with it!
Thanks! ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: RapidusMaximus]
#1644317
07/10/14 10:47 AM
07/10/14 10:47 AM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
I doubt you could build a low deck, stage 6, motor with the proper sized turbo to only run 10's. It would probably do that on 4psi...lol
If you want a 10 second turbo a body, you don't need those heads, or a stroker.
A 400/383 steel crank, Eddys, and a 80mm t6 turbo will give you 9 second pump gas capability easy. On race gas or would make 1000hp pretty easy.
[Re: dizuster]
#1644318
07/10/14 11:54 AM
07/10/14 11:54 AM
mshred
Toronto
![](/ubbthreads/images/graemlins/drive.gif)
[Re: dizuster]
#1644320
07/10/14 12:04 PM
07/10/14 12:04 PM
Posts: 4,953 Houston, Texas
TheOtherDodge
Houston, Texas
Yup, also. Save your money on the heads and stroker part. Look at what we (the turbo guys) run for parts and we are very mild and in the 9's.
I have Eddy heads on a 389 sb with a .520 hydraulic roller, 3.55 gears, 3000 converter.
I think dizuster is running a similar setup.
[Re: dizuster]
#1644322
07/10/14 01:24 PM
07/10/14 01:24 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
why do you say stuff like that? It makes me want to swap out my pistons, sell the sixpack and buy a turbo or 2.
[Re: SLOW67]
#1644323
07/10/14 01:42 PM
07/10/14 01:42 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Turbo would be my vote but...if you are going to run E15 fuel I'd just go N/A. E15 is a pita to tune on and every tank your specific gravity changes. I loved my turbo setup on non-ethanol 93 but when it wasn't available it caused problems. That's the reason I ditched my turbo was fuel inconsistency got to be an added aggravation I didn't want on a street car.
Thats when EFI comes in real handy.. let it take care of itself ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1644324
07/10/14 03:53 PM
07/10/14 03:53 PM
TheOtherDodge
Houston, Texas
![](/ubbthreads/images/graemlins/beer.gif) Quote:
![](/ubbthreads/images/graemlins/iagree.gif)
[Re: TheOtherDodge]
#1644325
07/10/14 04:09 PM
07/10/14 04:09 PM
Posts: 10,037 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I have a twin screw blower on a 2006 GT mustang and love it. 7.5 psi, and the hp went from 300 to 480, and the torque is right there on the bottom, starting at 2,000 rpm. The car ran 115 mph in the 1/4. Just think what a car that is 500 lbs lighter with a much bigger motor would do. The twin screw eats a little power over the turbo, but the response is instant, and the torque down low is much superior to a Procharger. I would go for a 500 cube motor with the proper sized Whipple unit. As an example of how well they work, the STOCK class record for a new Cobra Mustang racer is 8.05 in the 1/4! That is with a 4.0 liter Whipple on a 302 four valve motor.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
#1644328
07/11/14 02:59 PM
07/11/14 02:59 PM
Posts: 4,595 Motor City
6PKRTSE
Motor City
I am an All Motor guy, but Nitrous sure is a cheap way for quick horsepower. I have enought Nitrous laying around to nuke a small town. Can kind of see the 17 bottles on the right. But boost is the ultimate wat to go in the long run. Got a pair of those too for my big build when I to it someday financially.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#1644329
07/11/14 03:05 PM
07/11/14 03:05 PM
Mr.Yuck
Brookeville, Md
you wouldn't happen to have enough line to run from the bottle to the soleniod for a b-body would ya? Getting ready to get my install going (FINALLY).
