22 inch rad #1643249
07/07/14 11:32 AM
07/07/14 11:32 AM
O
otter440 Offline OP
otter440  Offline OP
O
I have a car I am putting together for a client he has a 440-6pak in it 69 clone superbee who would have the best aftermarket rad with schroud that I could use on this car Thanks
Re: 22 inch rad [Re: otter440] #1643250
07/07/14 11:36 AM
07/07/14 11:36 AM
massachusetts U.S.A.
1969ronnie Offline
1969ronnie  Offline
glen ray rad. talk to bob
Re: 22 inch rad [Re: 1969ronnie] #1643251
07/07/14 12:23 PM
07/07/14 12:23 PM
O
otter440 Offline OP
otter440  Offline OP
O
he is looking for an aluminum rad or I would use glen ray
Re: 22 inch rad [Re: otter440] #1643252
07/07/14 12:30 PM
07/07/14 12:30 PM
If he is Ok with generic there is always Champion. There was a comprehensive thread on them recently that you might be able to retrieve. I used one (22") in a 65 318 dart & no leaks and no fitment issues other than having to redrill 1 hole in one of the side flanges. tho my 318 did not test it's cooling capabilities even with it being a 2 core but the inner tubes/cores looked very generous & I didn't see a problem anywhere. Some reports of them being warped slightly so check that right off the bat when you get one & a guy on here sells them with an unconditional money back guarantee. Cant beat that. Just have to drill some holes to mount the shroud. EDIT it was $189 to my door from eBay (cant beat that) & all good till a drunk driver took me out
Re: 22 inch rad [Re: RapidRobert] #1643253
07/07/14 10:38 PM
07/07/14 10:38 PM
O
otter440 Offline OP
otter440  Offline OP
O
wow that sucks sorry man
Re: 22 inch rad [Re: otter440] #1643254
07/07/14 11:20 PM
07/07/14 11:20 PM
IN
ahy Offline
ahy  Offline
IN
I used the Mancini "Muscle Car" radiator on mine. The 26" version cools my 496 with AC and the "dinky" 5 blade MP viscous fan without problem. From what I understand, the 22" will do it on a BB if everything is "right".
http://chucker54.stores.yahoo.net/mucaralra1.html
