Re: belt drive oil leak
[Re: rebel]
#1642082
07/05/14 01:06 AM
07/05/14 01:06 AM
Posts: 45 Fremont, California Bay area
blindboyscuda
replace the seal, it's not hard to do. I replaced mine last year as it was starting to weep a bit.
where did you get your seal? what did you have to do to get the seal out? i still have the water pump and radiator in and i was hoping to not have to pull those out.
[Re: rebel]
#1642084
07/05/14 09:50 PM
07/05/14 09:50 PM
blindboyscuda
bad news dude, you gotta take them off. set your engine up on TDC, mark the belt against the pulleys in at least 2 places on each pulley. pop the plate off & press out the old seal & press another back in. it's a common seal I bought at an engineering shop. line the dots up on the belt & your pulleys so your timing is back in the same spot. tighten everything & recheck, put the pump back on with the damper & you're done. if you have a press or large vice the job should only take 2 hours. [/quote
ok thanks man. when I first put it together I replace the seal that i got from an engineering shop that specializes in seals, so I wasn't sure if there was a more specific seal I need to get. this seal only has about 800 miles max on it, so I am not sure why it is leaking. looks like i'll plan on pulling the front of the engine a part soon.
[Re: rebel]
#1642086
07/05/14 10:50 PM
07/05/14 10:50 PM
blindboyscuda
has your block been line bored? if it has there's a good chance of a leak since the centerlines will be closer than manufacturers specs. ask me how I know.
yes... so what do I have to do to fix this inaccurate factory production problem? ha
