Re: painting over por 15?
[Re: 3wracing]
#1641967
07/04/14 07:21 PM
07/04/14 07:21 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
They do sell a topcoat... I never tried it. But I use Magnet Paints Chassis black and had painted over it many times. Works better and cheaper than por 15, sold at carquest/napa.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: 3wracing]
#1641968
07/08/14 08:26 PM
07/08/14 08:26 PM
Posts: 856 1.5 hours SE of Pittsburg, Pa
geno440
Scuff it well or the primer and top coat will lift eventually. I asked a vendor and he said use 220.
Love them 68 MOPARS! GTS 340 auto, Charger R/T 440 4-speed, Superbee 383 auto, GTX 440 auto, D100 (new front frame 5.7 hemi - in process), Formula S 340 4-Speed A/C (it's green), 383 auto Roadrunner (maybe a hemi - waiting) and a 68 W200 Power Wagon. Drivers: 07 Cummins and 14 Ecodiesel 4x4.
[Re: geno440]
#1641969
07/09/14 02:27 AM
07/09/14 02:27 AM
Posts: 4,664 Wichita
GY3
Wichita
Do NOT use the POR15 if you haven't already. Do a search here if you need validation. A good epoxy primer like PPG DPLF90 is much better.
[Re: GY3]
#1641970
07/09/14 02:55 AM
07/09/14 02:55 AM
Posts: 18,157 Mass
DAYCLONA
Mass
I coated the entire sandblasted bare steel shell of my 71 HEMICUDA with POR-15 Clear after all the bodywork was finished, then topcoated that with DuPont primer sealer, POR 15 recommendations were NOT to sand or effect the POR-15 finish in any way prior to coating with a sealer or primer, I then primed/blocked the car, the finish coat was single stage DuPont Centari enamel,....that was in 1994, that was over 2 decades ago, the finish on the car, the body work, the POR-15 base are still flawless in finish/appearance, like anything in the automotive bodywork/paint application trade, prep, prep, prep, and attention to detail yields results
Mike
[Re: RSNOMO]
#1641972
07/09/14 07:31 AM
07/09/14 07:31 AM
Posts: 18,157 Mass
DAYCLONA
Mass
Just curious why you went that route...(POR15)
Is that your preference over an etching primer???
My experience with POR 15 is limited...
I painted the brake drums with black POR
Holding-up well after 20+ years...
I painted some batter-tray bolts with the clear...
Didn't hold-up worth a schnit...
That was one of my toys that I deviated on, I was interested in trying a new technique during it's restoration, generally I prefer Acid Etchant in the Dupont Vari-Prime line to topcoat a freshly blasted frame/shell, then followed by a high build primer like 2K in the Dupont line
The POR-15 has had no issues over the years, nor the topcoats, I've used the Chassis black on several projects in the mean time with no issues either....
Mike
[Re: DAYCLONA]
#1641973
07/09/14 01:02 PM
07/09/14 01:02 PM
Posts: 21,065 Niles , Ohio
therocks
Niles , Ohio
I did my frt end and gas tank back in the 90s.My kid did the rear end and a buch of his truck with it also.It still looks new.I even had to tap my upper A arms in with a hammer and no ill effects.Rocky
Chrysler Firepower
