Dry sump inlet #1640797
07/01/14 08:51 PM
07/01/14 08:51 PM
Las Vegas
Al_Alguire Offline OP
Las Vegas
OK question for you guys running dry sump oil systems. Where are you putting the oil back into the engine? Spent half the weekend trying to mount the tank now just curious where everyone is putting oil back in the motor? Oh yeah it is a BB Mopar, the 99 was easy as the inlet was the back of the block. Pics are a plus
Oh yeah I have looked at the plates AndyF makes. Just wondering if this is the best place or is there an alternative?
Re: Dry sump inlet [Re: Al_Alguire] #1640798
07/01/14 08:58 PM
07/01/14 08:58 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
On a BBM would it work to put a fitting in the valley pan and route it their? I'm new to this stuff and have a SBM lol
Re: Dry sump inlet [Re: SpareParts] #1640799
07/01/14 09:19 PM
07/01/14 09:19 PM
Idabel,Oklahoma
Gary Robbins Offline
Idabel,Oklahoma
Mine goes back in where the oil pump use to mount...Sorry no pics on this computer !!
Re: Dry sump inlet [Re: Gary Robbins] #1640800
07/02/14 12:44 AM
07/02/14 12:44 AM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
here ya go
Re: Dry sump inlet [Re: boatracer572] #1640801
07/02/14 12:46 AM
07/02/14 12:46 AM
San Jose Ca.
San Jose Ca.
built this in my mill, before i had outside radii bits, pm me if you need one built....
Re: Dry sump inlet [Re: boatracer572] #1640802
07/02/14 12:55 AM
07/02/14 12:55 AM
San Jose Ca.
San Jose Ca.
Al....have one of these also if your interested.....
Re: Dry sump inlet [Re: boatracer572] #1640803
07/02/14 12:56 AM
07/02/14 12:56 AM
San Jose Ca.
San Jose Ca.
another
Re: Dry sump inlet [Re: Al_Alguire] #1640804
07/02/14 01:17 AM
07/02/14 01:17 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Re: Dry sump inlet [Re: J_BODY] #1640805
07/02/14 03:09 AM
07/02/14 03:09 AM
Las Vegas
Las Vegas
Well looks like my suspicions are confirmed and the best, maybe only way back is though the stock hole. We have it covered was just looking for any new ideas/thoughts on the subject. My new mill will be off to the machinist this weekend hope to have it back late August. Will let you all know what kind of power it makes.
Re: Dry sump inlet [Re: Al_Alguire] #1640806
07/02/14 03:10 AM
07/02/14 03:10 AM
Las Vegas
Las Vegas
Tony, what is the small line on the adapter for? Assume oil pressure?
Re: Dry sump inlet [Re: Al_Alguire] #1640807
07/02/14 10:31 AM
07/02/14 10:31 AM
Socal
littleVAL Offline
littleVAL  Offline
Socal
I am a smallblock guy but I thought the old school racers would take oil off the back of the block and plumb it into the lifter area to get more oil to one of the mains to help oil the crank/ rods. It would seem like a good idea to run a small line there unless it is no longer needed with newer blocks etc.
Re: Dry sump inlet [Re: littleVAL] #1640808
07/02/14 12:10 PM
07/02/14 12:10 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
AndyF also makes another one that comes out different.
2011 Drag Pak Challenger
Re: Dry sump inlet [Re: rickseeman] #1640809
07/02/14 01:56 PM
07/02/14 01:56 PM
AndyF Offline
AndyF  Offline
I make several different block plates. Some engine builders prefer a NPT fitting while others want an o-ring or AN fitting. Some want the fitting to come straight out, others want the fitting pointed to the front.
http://arengineering.com/home-page/dry-sump/
Re: Dry sump inlet [Re: Al_Alguire] #1640810
07/02/14 03:49 PM
07/02/14 03:49 PM
San Jose Ca.
San Jose Ca.
Racepak oil psi sensor...
Re: Dry sump inlet [Re: boatracer572] #1640811
07/07/14 03:33 PM
07/07/14 03:33 PM
Tampa Fl
K
kens avenger Offline
mopar addict
mopar addict
K
Tampa Fl
Tap the main oil feed hole (feeds the block ,Big hole)where the pump mounts .install a #12 fitting..Tap the oil feed hole and put a plug in it.this is the hole that comes from where the oil pick up tube feeds but do it at the oil pump mounting pad (block side)...and move on..run a tube in the lifter vally to pull oil out of there looks like a spider..<if your push rod oiling..Theres alot more but you will learn
Oil control
Remember in here some don't think you should have a Opinion.. sad fact..
