Page 1 of 3 1 2 3
383 to 440 swap question. #1639688
06/28/14 03:12 PM
06/28/14 03:12 PM
South San Francisco, Californi...
MidPenMopar Offline OP
Looking for fun? Keep looking
If you swap out a 383 long block to a 440 long block what would you need to change on the engine to make it all work??
I know the manifold would be different but would all the other parts interchange. Like motor mounts, pulleys, power steering pump?? ect....
Thanks!!!
Stu
Re: 383 to 440 swap question. [Re: MidPenMopar] #1639689
06/28/14 03:48 PM
06/28/14 03:48 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
Every thing should be the same. Check 440SOURCE.com and look into the stroker kits for the ultimate 383 sleeper. Keep the 383!
http://www.440source.com/strokerkits.htm
Re: 383 to 440 swap question. [Re: MidPenMopar] #1639690
06/28/14 04:53 PM
06/28/14 04:53 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
Only things I can think of are the intake manifold and the distributor. If there are headers on the 383 then may not work with the 440 because of the height and width difference of where the headers bolt to the heads. A possible clearance issue.
Next
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: 383 to 440 swap question. [Re: Junky] #1639691
06/28/14 05:08 PM
06/28/14 05:08 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Exhaust may have to be massaged (then again, you've done that a lot). Like said the distributor is different as is the intake, but the rest is a bolt-in.
Re: 383 to 440 swap question. [Re: Junky] #1639692
06/28/14 05:45 PM
06/28/14 05:45 PM
Next
Oh the headers may not fit??
Re: 383 to 440 swap question. [Re: MidPenMopar] #1639693
06/28/14 06:01 PM
06/28/14 06:01 PM
Andrewh Offline
Andrewh  Offline
its not that they won't "bolt up" obviously, but you are pulling them up and out.
so if you barely cleared something above them before, they will probably hit now.
Re: 383 to 440 swap question. [Re: MidPenMopar] #1639694
06/28/14 06:06 PM
06/28/14 06:06 PM
intake manifold. valley pan metal intake gasket. (2) fore/aft metal strip pieces that secure the valley pan gasket. dist. The nominal (on paper) height of the "V" will be ~.745 (3/4") higher on the RB than on the B so the head ports which are the header mounting locations will be raised upward and outward at a 45 deg angle roughly that amount. If my pythagorean math is correct a .745" height increase at the V at a 45 angle is a .527" vertical height increase (air cleaner to hood) all else being the same which it likely wont be (diff manifold type etc). The threaded bosses on the front of the heads will also be raised .745" at a 45 angle so the alt on one side and PS on the other side will likely take diff brackets & I think some alt flat triangle trackets have 2 holes to take care of that and the AC brackets are different. Sounds worse than it is & I'd want that 440 in there. Stu I never could get the hang of hand sharpening drill bits so I bought a drill doctor. Now if I can get the instructional disc with it to open I can get something done about my 200 dull drill bits. Has the wedding in Grand Island taken place? How'd the trunk lock problem turn out?
Re: 383 to 440 swap question. [Re: RapidRobert] #1639695
06/28/14 06:21 PM
06/28/14 06:21 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Re: 383 to 440 swap question. [Re: RodStRace] #1639696
06/28/14 06:24 PM
06/28/14 06:24 PM
thanks bro I've been dead in the water on this deal for too long now
Re: 383 to 440 swap question. [Re: RapidRobert] #1639697
06/28/14 06:36 PM
06/28/14 06:36 PM
Ok, guys thanks for the advice and i think the stroker idea is a better alternative.
I hope the drill doctor works for you but if all else fails and you cant get the disc to open just ship them to me and i will sharpen them all for you!!
The trunk lock was a piece of cake until i had to put the retaining clip on the cylinder. I want to know who has hands small enough to get inside the access holes...Took me like 20 minutes of messing around until i got a pair of needle nose vice grips to stay on that sucker!
Re: 383 to 440 swap question. [Re: MidPenMopar] #1639698
06/28/14 06:45 PM
06/28/14 06:45 PM
I'd get a 400 block & stroke it. It'd be a B like the 383 so everything external would stay the same which'd get you up & going quicker. An offset ground 440 crank in the 400 is 470 cubes
Re: 383 to 440 swap question. [Re: RapidRobert] #1639699
06/28/14 06:59 PM
06/28/14 06:59 PM
Ultimately what i am looking for is a super reliable engine that runs on pump 91 and has enough poop to get out of it's way. I want to be able to drive it car all over the country someday and not worry. So i will sacrificial HP for dead reliability.
Re: 383 to 440 swap question. [Re: MidPenMopar] #1639700
06/28/14 07:39 PM
06/28/14 07:39 PM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
I'd think a mild 400 stroker should have enough poop. I mean, you already made it down here so I'd say you aren't too far off from reaching your goal.
Re: 383 to 440 swap question. [Re: MuuMuu101] #1639701
06/28/14 07:54 PM
06/28/14 07:54 PM
Well even though my poor old original 383 is running fine it's starting to use a quart of oil every couple hundred of miles or so and its fouling the rear plugs right as soon as i clean them. I am doing a rebuild soon i would expect.
Re: 383 to 440 swap question. [Re: MidPenMopar] #1639702
06/28/14 07:57 PM
06/28/14 07:57 PM
SoCal
MuuMuu101 Offline
MuuMuu101  Offline
SoCal
You could do a rebuild... OR... remove it, bag it, find a place in or next to the garage bar to put it, and install a 400 stroker.
Re: 383 to 440 swap question. [Re: MidPenMopar] #1639703
06/28/14 08:03 PM
06/28/14 08:03 PM
One adv of rebuilding an eng on the side is as you know it'll minimize your down time. I'm (slowly) doing a 451 (440 crank/400 block) & it's a simple/proven/reliable deal (440 crank/440 rods/stroker pistons required). If I was to start over I would have had the crank offset ground to go to 470 cubes while they were turning down the mains and turning the counterweights. Andy got 550 horse out of his (470) with good heads & cast iron 68-70 B body HP manifolds
Re: 383 to 440 swap question. [Re: RapidRobert] #1639704
06/28/14 08:15 PM
06/28/14 08:15 PM
I was also thinking of going with some aluminum heads and roller rockers too.
Re: 383 to 440 swap question. [Re: MidPenMopar] #1639705
06/28/14 11:24 PM
06/28/14 11:24 PM
SE PA
Yellow Fever Offline
SE PA
I did the 450 stroker kit from muscle motors for my 383, dropped right in and runs great. Used source heads.
http://www.mopar1.us/cuda/IMG_20130728_125321a.jpg
Re: 383 to 440 swap question. [Re: MidPenMopar] #1639706
06/29/14 12:03 AM
06/29/14 12:03 AM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Say no to 'offshore'...
What's wrong with a stock 383 with a few tweaks???
Make it pump-gas compatible...
Maybe a little port clean-up...
Good induction, and exhaust...
Dial it in and drive...
Re: 383 to 440 swap question. [Re: RapidRobert] #1639707
06/29/14 12:38 AM
06/29/14 12:38 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
The headers should work no problem if they are decent ones.Ive done a few and all the headers worked.One I had to ding the one tube just a bit to clear one grease fitting.Rocky
Chrysler Firepower
Page 1 of 3 1 2 3
