Re: Cal Tracs and Drag Radials
[Re: 1967dartgt]
#1638871
06/28/14 10:58 AM
06/28/14 10:58 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Yes, you don't want to be to aggressive. The lower hole works best and you want to extend the shock slower then with a slick. I would recommend a good double adjustable shock. How much power are you trying to hook?
Not to hyjack the post, but mine are in the top hole...should I change them? Haven't run the car yet but hoping to get up in the next 2 weeks. I'm running the MT Radial Pro's. and crappy Comp Eng drag shocks. I'm just looking for 1.52-1.55's
[Re: Mr.Yuck]
#1638874
06/28/14 02:42 PM
06/28/14 02:42 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
Mine are in the top hole also, rear shocks set on 9 and the the bolt just touching the spring. I am think about moving to bottom hole to see if it will com down the front end when it leaves. But it hooks good now. I am running M/T 315/60 Drag radials. 1.33 60 ft.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: Thumperdart]
#1638876
06/28/14 03:18 PM
06/28/14 03:18 PM
D-50
North, Alabama
Do you always race w/out a hood? Cos I`m thinking there`s a few mph w/one on............
Thumper check the thread out that I posted ( hood and scoop color with pictures)I think it is on page 3 now.I don't want to hijack this thread. Tell me what you think.
[Re: D-50]
#1638878
06/29/14 12:16 PM
06/29/14 12:16 PM
Posts: 13,380 Marion, South Carolina [><]
an8sec70cuda
Bottom hole, 1/4 turn preload, rancho 9 ways on 9, 20 psi in 295-65 radials. 1.320 sixty foot on motor footbraking from a fast idle at 3800+ lbs.
