Re: AAR not running good
[Re: aar1]
#1638328
06/25/14 06:05 PM
06/25/14 06:05 PM
RapidRobert
What carb? You might take out the 2 idle mixture screws and shoot a 2 second blast of starting fluid into both screw holes. First count the # of turns to get the screws to lightly seated then unscrew them so you can quickly and accurately return them to their original setting
[Re: DAYCLONA]
#1638330
06/26/14 01:37 AM
06/26/14 01:37 AM
Posts: 1,145 ontario calif
ns1aar
ontario calif
My AAR does this also if I let it sit too long. The bowels dry out, the floats drop and the needles fall down causing the floats not rise when fuel is pumped in. This allows raw fuel to be pumped into the carb bores. You can see this if you remove the A/C, run the car for a few minutes, shut it off and look down the bores for fuel dripping. If it is back off the needle and seat until the float rises and then reinstall the needle and seat.
NS1AAR
[Re: ns1aar]
#1638331
06/26/14 06:37 PM
06/26/14 06:37 PM
RapidRobert
If it is acting up from too rich you might also check fuel psi/needle & seats/float saturation (pinhole)/needle/seat/float hanging up in it's travel, anything that might possibly be letting it recieve too much fuel. Keep us posted. EDIT at that point are you in the power circuit? (in hg level)
