AFR at WOT ? #1638198
06/25/14 02:04 AM
06/25/14 02:04 AM
BigFish69 Offline OP
whats is a good range afr # at wot
Re: AFR at WOT ? [Re: BigFish69] #1638199
06/25/14 02:11 AM
06/25/14 02:11 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Depends on fuel type...................my unleaded oxygenated fuel likes richer #`s like 12.2-12.4 so far and the plugs say the same...........
Re: AFR at WOT ? [Re: BigFish69] #1638200
06/25/14 04:20 AM
06/25/14 04:20 AM
As already said it depends on fuel type, open exhuast versus closed exhaust, which sending unit, where located and metering unit. The best bet is to jet for best MPH at the 1/4 track and then record that AFR number for those weather conditions Ball park #s on pump gas with closed exhaust work well in my car from 12.3 to 13.3 depending on the weather and fuel brand and type Richer always feels better as far as throttle responce, that is not nessecarily the best AFR #s for best performance at the track
