BRAKE RELEASE ISSUES / 78 MAGNUM #1638152
06/25/14 12:29 AM
06/25/14 12:29 AM
S.E.Ohio
Magnumguy Offline OP
S.E.Ohio
Replaced both front calipers (rebuilt) and hoses on my 78 Magnum. It seems like they're not releasing as the should, as when i raise either one they're hard to turn, even worse w/the wheel/tire off.
Any clues? Pads are correct, dead-on matches to the ones removed. Also had an awful time getting them bled as well.
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: BRAKE RELEASE ISSUES / 78 MAGNUM [Re: Magnumguy] #1638153
06/25/14 12:51 AM
06/25/14 12:51 AM
I'm assuming the wheel bearing adjustment is OK. Cranck a bleeder & see if it is a PSI problem. I had that on one corner & a $15 rebuild caliper took care of it. Before it was too hard to turn it & with another caliper it was much easier to bearhug/turn the wheel which as you know is normal EDIT provide more info on what was going on with the bleeding
Re: BRAKE RELEASE ISSUES / 78 MAGNUM [Re: RapidRobert] #1638154
06/25/14 01:12 AM
06/25/14 01:12 AM
S.E.Ohio
S.E.Ohio
Both calipers are "new". The bleeding took FOREVER. Just wouldn't pump up. Finally got some pedal, left it set an a week later they were fine.
Re: BRAKE RELEASE ISSUES / 78 MAGNUM [Re: Magnumguy] #1638155
06/25/14 01:26 AM
06/25/14 01:26 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
check valve in master not releasing, Proportioning valve needs reset.. is the booster releasing all the way ??
I am truckless..
Re: BRAKE RELEASE ISSUES / 78 MAGNUM [Re: 340SHORTY] #1638156
06/25/14 10:36 AM
06/25/14 10:36 AM
S.E.Ohio
S.E.Ohio
How is that done?
As far as I can tell it is.
Re: BRAKE RELEASE ISSUES / 78 MAGNUM [Re: Magnumguy] #1638157
06/25/14 10:45 AM
06/25/14 10:45 AM
didn't realize it was PB. crack a bleeder & if that frees it then close the bleeder & pump it up & undo the MC to booster bolts & pull the MC forward a bit & see if that frees it. If so take the bolts the rest of the way off & pull the MC forward so you can get at the rounded pushrod threaded nub & shorten it till you have a slight bit of clearance between the round nub and the bottom of the piston recess "thimble" in the back of the MC
Re: BRAKE RELEASE ISSUES / 78 MAGNUM [Re: RapidRobert] #1638158
06/25/14 01:47 PM
06/25/14 01:47 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
RR it isn't logical that the adjustment on the booster would change with just a hose and caliper replacement. I would look at the new caliper pistons being tight in their bore and not releasing all the way. I would say drive it for a little bit and see if things loosen up.
Re: BRAKE RELEASE ISSUES / 78 MAGNUM [Re: stumpy] #1638159
06/25/14 02:21 PM
06/25/14 02:21 PM
Agreed, I missed that part. for it to start after a caliper replacement I would concentate my efforts there for what is mechanically hanging up
