Re: Spark plug images
[Re: MR_P_BODY]
#1637897
06/26/14 08:57 PM
06/26/14 08:57 PM
Posts: 5,165 CT
GTX MATT
CT
Heres a silly question - does it matter if you do a shut down run right before reading the plugs if you're looking at the ground strap for a timing indicator?
If not then I would say it has more to do with the timing and not the effects of changing the timing (i.e. EGT)
[Re: GTX MATT]
#1637898
06/26/14 09:01 PM
06/26/14 09:01 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Its much easier to read a true reading on a shut down run.. its more pronounced
[Re: MR_P_BODY]
#1637899
06/26/14 09:05 PM
06/26/14 09:05 PM
Posts: 5,165 CT
GTX MATT
CT
Will it usually stay in the same spot though?
[Re: GTX MATT]
#1637900
06/26/14 09:12 PM
06/26/14 09:12 PM
MR_P_BODY
From what I have seen .. yes if the timing wasnt changed but if you reduce the timing its gonna end up with a wider burn mark and its usually better to start with fresh plugs.. but I usually just put in 1 or 2 plugs for a reading then if it looks better/right then I change the rest to get a full engine reading
[Re: GTX MATT]
#1637902
06/26/14 09:19 PM
06/26/14 09:19 PM
MR_P_BODY
Good to know, I've been wondering about this.
I pulled 2 plugs today on my street rod... seen that I'm a couple degrees high on timing and its still rich.. I checked them because I'm going on a run tomorrow with a lot of X-way running and I wanted to make sure I wasnt lean.. I pulled 2 degrees of timing and left it on jetting till after tomorrow
