Page 1 of 3 1 2 3
Spark plug images #1637857
06/24/14 12:38 AM
06/24/14 12:38 AM
W. Kentucky
justinp61 Offline OP
W. Kentucky
Anyone seen the strap look like this?
Re: Spark plug images [Re: justinp61] #1637858
06/24/14 12:51 AM
06/24/14 12:51 AM
W. Kentucky
W. Kentucky
These are out of my pump 93 10.9-1 408. I've taken the carb back to close to the original set up. At cruise, 3000 rpms the afr is 13.0-13.4. From a dead stop I pulled wide open to 6100 in high and the afr was 12.6-12.8 except when it was spinning in first and second gears until it hooked at 5200. When it was spinning the afr was 13.6-13.9. When it hooked the afr went to 12.4.
Re: Spark plug images [Re: justinp61] #1637859
06/24/14 12:53 AM
06/24/14 12:53 AM
W. Kentucky
W. Kentucky
Last one.
Re: Spark plug images [Re: justinp61] #1637860
06/24/14 03:59 AM
06/24/14 03:59 AM
If those where brand new and you drove it a very short distance before taking these pictures I would try the next step colder plugs, maybe two steps colder and see how those look If those have been driven a lot longer than a short time definitely go to a colder plug
Re: Spark plug images [Re: Cab_Burge] #1637861
06/24/14 08:10 AM
06/24/14 08:10 AM
W. Kentucky
W. Kentucky
Cab, they were new. I set the idle mixture and took it for a ride, probably four miles at the most. with the exception of the wide open blast most of the time was spent at 2800-3300,NGK 7s.
Re: Spark plug images [Re: justinp61] #1637862
06/24/14 08:19 AM
06/24/14 08:19 AM
Q
Quicktree Offline
Quicktree  Offline
Q
plugs to hot and to lean, but if you didn't do a shut off pass it's hard to get a good read.
http://www.youtube.com/watch?v=fiMM2S0aADM
Re: Spark plug images [Re: justinp61] #1637863
06/24/14 12:10 PM
06/24/14 12:10 PM
jacksonville,FLORIDA
slammedR/T Offline
slammedR/T  Offline
I assume that is an extended reach plug in the zrf series? if so prolly try 4554 #8 race plug from NGK, they are cheaper at speed shops. $18.75 for a set of 8 here in jax at my speed shop I use.
2000 Dakota R/T, 408 magnum, 727, Indy heads
1000cfm 4150 carb, 93 octane fuel.
motor; 10.258 @ 132.78
200 shot; 9.262 @ 144.69
racemagnum
Re: Spark plug images [Re: slammedR/T] #1637864
06/24/14 12:33 PM
06/24/14 12:33 PM
W. Kentucky
W. Kentucky
The plugs are BRK7E, #4644.
Re: Spark plug images [Re: justinp61] #1637865
06/24/14 12:38 PM
06/24/14 12:38 PM
slammedR/T Offline
slammedR/T  Offline
OH, I didn't know the BRK's were also extened tip. anyway my 408 is at 10.5:1 compression and I run the 4554 plugs with no issue even on a 200 shot of juice.
racemagnum
Re: Spark plug images [Re: slammedR/T] #1637866
06/24/14 03:02 PM
06/24/14 03:02 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
you need to take it to the track or a dyno and start jetting up then see what the AF meter says. don't go by that thing till you know what the engine wants. I wouldn't be buying plugs till you feel carb is tuned. I think -7 will be just fine. In my engine, those plugs would be way lean
Re: Spark plug images [Re: sixpackgut] #1637867
06/25/14 12:14 AM
06/25/14 12:14 AM
W. Kentucky
W. Kentucky
Today I jetted the primaries up two numbers and dropped the high speed bleeds two sizes and will drive it with the same plugs tomorrow afternoon when I get off work.
Thanks guys .
Re: Spark plug images [Re: justinp61] #1637868
06/25/14 01:01 AM
06/25/14 01:01 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Thanks guys .
This may help based on the wide jet spread you`re running and those plugs aren`t too hot for your compression in my opinion since I ran em at 12.1.1 comp. but like the 8`s better now that the carb`s tuned. Measure your pvcr`s then that will help you determine the proper jet spread.................
Re: Spark plug images [Re: Thumperdart] #1637869
06/25/14 08:14 AM
06/25/14 08:14 AM
W. Kentucky
W. Kentucky
I have a set of 1-60 and 61-80 drill bits on the way.
Re: Spark plug images [Re: Thumperdart] #1637870
06/25/14 08:27 AM
06/25/14 08:27 AM
Q
Quicktree Offline
Quicktree  Offline
Q
Thanks guys .
really, what is the ground strap telling you?
Re: Spark plug images [Re: Quicktree] #1637871
06/25/14 09:23 AM
06/25/14 09:23 AM
W. Kentucky
W. Kentucky
I don't honestly know, that's why I posted the photos. I'll have to order a set of 8s.
Re: Spark plug images [Re: justinp61] #1637872
06/25/14 11:19 AM
06/25/14 11:19 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Here's some interesting info....
http://www.wallaceracing.com/plug-reading-lm.html
Joe
Re: Spark plug images [Re: justinp61] #1637873
06/25/14 11:22 AM
06/25/14 11:22 AM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
I would say the strap is saying the temp in the chamber is high.
Needs more fuel, less timing or a combination of both.
Don
Re: Spark plug images [Re: Quicktree] #1637874
06/25/14 12:40 PM
06/25/14 12:40 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Thanks guys .
Not clear enuff to read the strap but based on our phone conversations, he needs to measure the pvcr`s to get a feel for the jet spread cos a 12 spread and small pvcr`s could be creating the lean that I see.............but what do I know.
Re: Spark plug images [Re: Quicktree] #1637875
06/25/14 01:11 PM
06/25/14 01:11 PM
Az
Crizila Offline
Crizila  Offline
Az
That's what I will be doing this Saturday at the track. Besides reading plugs, I temporarily mounted my camera so that I can record A/F and boost gauge readings at WOT.
Fastest 300
Re: Spark plug images [Re: justinp61] #1637876
06/25/14 01:19 PM
06/25/14 01:19 PM
Q
Quicktree Offline
Quicktree  Offline
Q
go watch the video i posted and come back and report, the message is clear.
Page 1 of 3 1 2 3
