Re: Spark plug images
[Re: justinp61]
#1637882
06/26/14 02:31 AM
06/26/14 02:31 AM
Posts: 43,744 Bend,OR USA
Cab_Burge
I made some changes to the carb this week and took it for a spin today. I went from 76/88 jets and 31/71 air bleeds to 78/88 jets and 29/71 air bleeds. Idle afr was 14.3-14.8, 3000 rpm cruise was 12.3-12.5 and wot was 12.4-12.6. The plugs have color now, I'd guess from being rich at cruise where it spent most time at. I'll order some ngk 8s, for now I'll put in a set of Autolite AR3934 after I work on the cruise.
2,4,6 & 8.
If you didn't put new plugs in before doing the carb. tuning you should. The two plugs on the left are fatter than needed, the one next to the last one on the right side and especially the last one on the right are close to what I like to see When it comes to tuning, lean is mean and cold sprak plugs that don't foul at part throttle are just right
[Re: Thumperdart]
#1637887
06/26/14 06:26 PM
06/26/14 06:26 PM
Quicktree
look a little better...still too much timing and wrong heat range....
I guess different guys read em differently...........years ago the heat range was measured(by some)as the amount of threads colored going up the plug as seen from the ground strap ie; 2-3 threads was considered good 1 too cold 5 too hot. I know when I went to a colder plug the band on the ground strap mover farther out towards the end.
go watch the video i posted and learn you some of this new technology
[Re: Quicktree]
#1637888
06/26/14 06:37 PM
06/26/14 06:37 PM
Posts: 52,972 Romeo MI
MR_P_BODY
If you want Tony I can show you other sites that say the ground strap is timing.. and I can move the blue line with the timing... that changes the heat in the cyl also... let me know if you want me to post it
[Re: Quicktree]
#1637892
06/26/14 07:30 PM
06/26/14 07:30 PM
MR_P_BODY
what ever you want to believe i guess, i can see timing changing exhaust gas temp but don't see how it can change the ground strap. the only thing that can change that is the plug heat range imo.
I guess you can think the way you want... I'll stay with what I and many others think also... so we will call it equal... hows that
[Re: Quicktree]
#1637894
06/26/14 07:58 PM
06/26/14 07:58 PM
MR_P_BODY
fine with me I still would like you to explain how it can single out the ground strap and change it.
Simple... start the burn earlier and the temp in the cyl goes up... if its later it cooler and burns more in the pipes... I have backed the timing down on my junk and seen the color move closer to the tip of the radius on the strap... this is fact not just a opinion
[Re: Crizila]
#1637896
06/26/14 08:44 PM
06/26/14 08:44 PM
MR_P_BODY
but don't loose sight of the fact that we are not adjusting timing or A/F to make the plugs look happy. Gotta make adjustments in those areas for best HP or at the track, best MPH. Then correct plug choice so they are happy and live for a while - which I can't seem to accomplish.
I know your playing with a boosted engine so on yours are the plugs fouling out or burning up
