Quick and easy rear lowering? #1637454
06/23/14 05:20 PM
06/23/14 05:20 PM
London Ontario Canada Eh
Dono Offline OP
Dono  Offline OP
1993 dodge ram 250 diesel two wheel drive. The rear of the truck has to much rake for my liking. What is a quick and easy way to lower the rear. I remember about some kind of a shackle flip or simple mod along those lines. Anyone have a quick and easy fix?
Cheers Don.
Re: Quick and easy rear lowering? [Re: Dono] #1637455
06/23/14 05:58 PM
06/23/14 05:58 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
quickest and easiest is to use a set of lowering shackles.. About $40.00 at O Rielys..
I am truckless..
Re: Quick and easy rear lowering? [Re: 340SHORTY] #1637456
06/25/14 12:06 AM
06/25/14 12:06 AM
Hawley, Texas
shinnery Offline
super street
shinnery  Offline
super street
Hawley, Texas
The ones for chebbys actually work on our trucks.
Bryce
Every electronic device is manufactured with smoke stored deep inside... only a true genius can find a way to set it free. The most terrifying words in the English language are: "I'm from the government and I am here to help!"
Re: Quick and easy rear lowering? [Re: shinnery] #1637457
06/25/14 12:49 PM
06/25/14 12:49 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Shackle flip would be a 4" Lift. Considering you have a 1ton the normal Chevy drop shackle will need hole for bolt enlarged and the Bushing addressed for the larger bolt
Re: Quick and easy rear lowering? [Re: 76dodgeboy] #1637458
06/26/14 03:11 AM
06/26/14 03:11 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
The lowering shackles come in 2 sizes when it comes to bolt size.. IIRC 9 /16 AND 5/16 .
I am truckless..
Re: Quick and easy rear lowering? [Re: 340SHORTY] #1637459
06/26/14 01:46 PM
06/26/14 01:46 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
9/16" & 16 MM
Re: Quick and easy rear lowering? [Re: Dono] #1637460
07/04/14 05:00 PM
07/04/14 05:00 PM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
Not to hijack this thread but we're in the process of trying lowering shackles on our '75 and here are the issues we found with the O'Reilly sourced (Superior Performance 13-4100)pieces - applies to the earlier trucks like ours:
Original shackle bushing length measures about 2.85" vs 3.02" on the replacement - so the hanger would have to be spread about 1/8" for it to fit in there. Not a big deal - it was probably crushed that much when the factory built it. But the deal breaker is bushing ID. Leaf spring bushing ID is 1/2", while the new shackles measure 9/16" on all holes. Could enlarge the original holes are replace the bolts but I cannot find a proper size bushing for the leaf.
