Drop spindles ? #1636989
06/22/14 02:49 PM
06/22/14 02:49 PM
pa
demongup Offline OP
demongup  Offline OP
pa
Who makes them ? All I seen was magnum force ...
A body ,small drum spindel
Thx
Dealer For Calvert Racing Products Free Shipping on any order
Re: Drop spindles ? [Re: demongup] #1636990
06/22/14 04:10 PM
06/22/14 04:10 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Fat Man fabrication has them,but they are based on the Volare spindle.You'll have to change over to the larger ball joints and brakes (73 up A-body disc etc) to use either of these spindles.
Nautilus Racing-
Re: Drop spindles ? [Re: Chris2581] #1636991
06/22/14 05:03 PM
06/22/14 05:03 PM
pa
demongup Offline OP
demongup  Offline OP
pa
I have brakes for the early model and I'm not looking to change the offset either
Re: Drop spindles ? [Re: demongup] #1636992
06/23/14 01:35 AM
06/23/14 01:35 AM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
Pretty pricey aren't they ? Lol
Don't be so cheap lol
....BAD A$$ STREET CAR.....
Re: Drop spindles ? [Re: n20mstr] #1636993
06/23/14 08:38 AM
06/23/14 08:38 AM
pa
demongup Offline OP
demongup  Offline OP
pa
Than maybe I should ask this ....... Anyone have a coupon for them ? Lol
Re: Drop spindles ? [Re: demongup] #1636994
06/23/14 11:22 AM
06/23/14 11:22 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Re: Drop spindles ? [Re: Stanton] #1636995
06/23/14 12:29 PM
06/23/14 12:29 PM
Park Forest, IL
slantzilla Online content
slantzilla  Online Content
Park Forest, IL
The upper ball joint has a larger stud in it. They do make spacers so you can still use the small stud ball joint though.
Re: Drop spindles ? [Re: slantzilla] #1636996
06/23/14 12:54 PM
06/23/14 12:54 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Strange that there's no mention of this in the brake swap article ...
http://www.moparaction.com/Tech/archive/disc-main.html
Maybe it only applies to these aftermarket spindles ????
Re: Drop spindles ? [Re: demongup] #1636997
06/23/14 03:02 PM
06/23/14 03:02 PM
maryland
74yellowduster Offline
maryland
the HDK kit that Denny Laube sells over on forabodies is offered with drop spindles if you are looking for that. i'm pretty sure his kit uses wildwood mustangII-type 1" or 2" drop spindle or 0" drop. some autocrossers use it, but his kit is real good for drag because it has zero toe change from 10" compressed all the way to 15" fully extended.
(i.e. no bump steer from fully compression to full extension)
those kits are nice, but cost just under $3k
http://www.forabodiesonly.com/mopar/showthread.php?t=259684
you pick whatever spindles you want
Re: Drop spindles ? [Re: demongup] #1636998
06/23/14 03:58 PM
06/23/14 03:58 PM
pa
demongup Offline OP
demongup  Offline OP
pa
Phone # for HDK ? I can't find it
I have 9 in drum spindel that is drilled for the big ball joint . My rotors fits that spindel . Magnum force only makes the drop for a 73-76 that takes a larger bearing in the rotor . Also the 73-76 moves the wheel toward the outside of the body
Re: Drop spindles ? [Re: demongup] #1636999
06/23/14 04:42 PM
06/23/14 04:42 PM
maryland
maryland
sent you the contact info. his stuff is a kit, the spindles would not be a stock bolt on in place of your spindles.
that being said, his kit does not move the wheels inward or outward from stock.
Re: Drop spindles ? [Re: Stanton] #1637000
06/23/14 05:24 PM
06/23/14 05:24 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
It's mentioned towards the end of the article under that A body section...
Nautilus Racing-
