Re: msd vs mopar ecu [Re: 540challenger] #1635340
06/23/14 07:03 PM
06/23/14 07:03 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
The MSD's advantage if there is one will be more pronounced at low engine speed under 3000 rpm because that is the range that it multi strikes. Over 3K it goes to single strike.
At idle speed the multi strike hits it several times over 20 crank degrees so if it doesn't light it the first time it gets a few shots at it. This helps get a cleaner idle on engines that have cams with a lot of overlap.
Kevin
Re: msd vs mopar ecu [Re: slantzilla] #1635341
06/23/14 08:37 PM
06/23/14 08:37 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
I've never had a problem with the orange or chrome box...don't believe the hysteria.
oooooh yes.... believe it! I do, because I have being there!
Aren't you the one who takes them apart and fixes them?
he is indeed! but i think he fixes them because it's too hard to get stuff in his country. it's easier to fix what you have or found. i also believe when he wrote his thread about doing that that he determined heat was the number one issue with the internal components. now why do they get too hot? you'd have to ask the crowd who runs them with no ballast.
Re: msd vs mopar ecu [Re: mikemee1331] #1635342
06/23/14 09:26 PM
06/23/14 09:26 PM
USA
JoesMopar Offline
JoesMopar  Offline
USA
Forgot about that crowd.
I've still yet to have a Mopar ECU crap out on me. I'm patiently waiting and it's getting a bit frustrating to be perfectly frank.
Re: msd vs mopar ecu [Re: JoesMopar] #1635343
06/23/14 09:52 PM
06/23/14 09:52 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
jump the ballast "Perfectly Frank"!
Re: msd vs mopar ecu [Re: JoesMopar] #1635344
06/24/14 12:23 AM
06/24/14 12:23 AM
western Ky
CraigS Offline
CraigS  Offline
western Ky
Really? Never had an ecu crap out.?
Do you ever drive your car?
Re: msd vs mopar ecu [Re: CraigS] #1635345
06/24/14 12:43 AM
06/24/14 12:43 AM
USA
JoesMopar Offline
JoesMopar  Offline
USA
Hell yes! All of them, as much as I can.
Re: msd vs mopar ecu [Re: CraigS] #1635346
06/24/14 09:49 AM
06/24/14 09:49 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I had a mopar ECU go bad in 1976, my car sat broke down for 4 or more months until my uncle helped me figure it out.
Then I don't remember another going out on me since.
I have like 6 or more ECUs from cars I parted out. I found that a OEM one from the early 70s runs better than the chrome one I bought in the 2000s
