8 3/4 gasket question #163347
12/06/08 04:59 PM
12/06/08 04:59 PM
Missouri
Confusedcuda Offline OP
Missouri
Just puy together my 8 3/4 for my 67 abody. On my axles I put a gasket in between the axle housing and the backing plate and one inbetween the axle flange and backing plate. I was one gasket short so on the other side I put one in between the housing and backing plate and used silicone in between the flange and backing plate. Will this be okay? Thanks
Re: 8 3/4 gasket question [Re: Confusedcuda] #163348
12/06/08 06:59 PM
12/06/08 06:59 PM
Missouri
Missouri
Anyone?
Re: 8 3/4 gasket question [Re: Confusedcuda] #163349
12/06/08 07:03 PM
12/06/08 07:03 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
If it were me ...I would get some bulk gasket material and make one up.
Re: 8 3/4 gasket question [Re: Confusedcuda] #163350
12/06/08 07:04 PM
12/06/08 07:04 PM
Easton, Kansas
Moparmedic440 Offline
Easton, Kansas
That will work fine, the gaskets are to keep dust out.
Re: 8 3/4 gasket question [Re: Moparmedic440] #163351
12/06/08 08:44 PM
12/06/08 08:44 PM
Ideally you want a steel shim gasket between the backing plate/housing & a white foam gasket between bearing flange/backing plate but as mentioned a wide enough swath of gasket cement(perfect use for rtv) will work. You just want it sealed from water/dust.
