magnum stroker kit from hughes #1633224
06/13/14 10:32 PM
06/13/14 10:32 PM
indiana
mcmopars Offline OP
mcmopars  Offline OP
indiana
thinking of a stroker kit from hughes for the 360 magnum.new to the stroker deal.any imput would be helpfull.hughes=good=bad?i have one of there cams and it runs well.bore size?cam?eddy heads?cast or forged crank?a lot of ? i dont know.was hoping for @450 h.p.and how to get there.dont scold me too bad.i have a good9.5 from ptc and a holley 750 hp.carb already.
Re: magnum stroker kit from hughes [Re: mcmopars] #1633225
06/14/14 10:25 PM
06/14/14 10:25 PM
indiana
mcmopars Offline OP
mcmopars  Offline OP
indiana
thank you
Re: magnum stroker kit from hughes [Re: mcmopars] #1633226
06/14/14 11:53 PM
06/14/14 11:53 PM
SoCal
Brian Hafliger Offline
SoCal
We sell the scat kits and custom Taylor them just for your particular build.
Immengines.com
Brian Hafliger
Re: magnum stroker kit from hughes [Re: Brian Hafliger] #1633227
06/15/14 12:04 AM
06/15/14 12:04 AM
indiana
mcmopars Offline OP
mcmopars  Offline OP
indiana
ill give you a call,thanks.i didnt see it on your web page
Re: magnum stroker kit from hughes [Re: mcmopars] #1633228
06/15/14 12:08 AM
06/15/14 12:08 AM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Decent heads, cam, and compression will get your horsepower goal without a stroker kit.
You will need the heads and cam to get there with a stroker too, but the stock stroke will need a little more rpm.
It just depends on your budget and what your required performance goal is.
Keith
Re: magnum stroker kit from hughes [Re: mcmopars] #1633229
06/15/14 01:22 AM
06/15/14 01:22 AM
Az
Crizila Offline
Crizila  Offline
Az
Hughes has been doing small block Chrysler stuff for many years. They know their stuff and put together good combo packages at many different HP levels. I'm sure there other reputable companies out there, but you won't go wrong if you decide to use Hughes.
Fastest 300
Re: magnum stroker kit from hughes [Re: mcmopars] #1633230
07/16/14 05:55 PM
07/16/14 05:55 PM
B-Body Bull Offline
B-Body Bull  Offline
MCPhony... good one... Just Call them. Thanks, McElroy
