Re: The famous Neon rough idle question...
[Re: eightlitermopar]
#1632669
06/14/14 03:36 PM
06/14/14 03:36 PM
Posts: 1,630 North Central Florida
eightlitermopar
So I took off the IAC, and it actually looks pretty clean. If I wanted to clean it out, do I just spray brake cleaner in the hole to the left? I don't want to ruin anything...
Mopar or no car
#1632673
06/14/14 05:28 PM
06/14/14 05:28 PM
Posts: 52 CO
Twisted
CO
Just spray everything including the TB side. I have connected power to actuate the valve but it doesn't seem needed if it seems to be working, just spray both sides. Not sure on that cap. It could be a problem but I would think it would be more noticeable of a stumble if it had a vacuum leak.
Thank you Aaron
69 Dodge Polara 4DHT 70 Plymouth Duster 03 Dodge Neon R/T 05 Dodge Grand Caravan SXT
#1632676
06/15/14 02:22 PM
06/15/14 02:22 PM
Posts: 12,802 Benton, IL.
DaveRS23
Master of nothing...
Benton, IL.
In my experience, when the IAC is dirty the idle is slow to respond or unresponsive. As in idles too high or the engine dies at idle because it is too low. The IAC is just a tapered plunger that plugs and unplugs a by-pass hole in the throttle body that allows more or less air into the engine.
It doesn't usually cause a rough running idle condition, unless it causes an extremely low idle that causes the engine to shake.
I usually spray carb cleaner in it and let it soak for awhile and then spray it again. Be sure to remove the gasket/seal first.
Master, again and still
[Re: DaveRS23]
#1632677
06/15/14 02:32 PM
06/15/14 02:32 PM
Posts: 1,377 Ohio
Todd
Ohio
Where I work we have BG induction service. It has an injector that sprays cleaner in the t-body with the engine running. Works very well. Cleans the entire t-body,IAC circuts and intake. I had a neon I did that to and the inside of the intake looked like new. I clean all my vehicles every 30k with it.
#1632681
06/16/14 01:43 PM
06/16/14 01:43 PM
Posts: 6,033 Salem
Grizzly
Moparts Proctologist
Salem
I feel your pain, Eightliter, I am pulling my hair out with the same problem for the last 2 months. And, just like you, I found a lot of suggestions but no real solution with Google. One, that will be a last resort, is a fellow drilled a 5/32nd hole in his throttle plate. I just had a Dealer re-flash done on the car as per a TSB for "rough idle, P0300 random misfire" issues. It didn't help, but the misfire codes don't show up as much. Still getting P0300 and P0301. Have swapped wires, plugs, tested the coil, checked wiring harness to coil, changed the IAC, and just last night I took all the injectors out and cleaned them off the car (pretty neat method I found online ). Unhooked the battery, cleared the codes, and fired it back up. Ran smooth and figured I got it. Drove it a few minutes, stopped in Drive, and the miss/low idle is back. This little issue has really soured my high praise for Chrysler. The thing has low miles, well-cared for, drives/handles, just generally does everything better than any brand-x vehicle otherwise. I did the timing belt, crank seal, and cam seal and was very careful on getting the timing marks correct. The car ran perfect for a few thousand miles and then the misfire codes came up. Some great suggestions on here too, thanks Guys, I'll give them a try. I guess I gotta find some time this week and dig into it again.
Mo' Farts
Moderated by "tbagger".
#1632682
06/16/14 01:56 PM
06/16/14 01:56 PM
Posts: 21,122 Niles , Ohio
therocks
Niles , Ohio
What pluigs and wires did you use?I had one at work that I used Champions in that were direct replacement.It would run great but had rough idle at times.Changed them and wires twice.Finally I had the manager get Champions from the dealer.Installed them and no more roughness.Weird I know as they were the same plug and number.Wires will cause a rough idle and sometimes a miss also.The wifes PT went thru it.New Autolite wires 2 sets.New plugs 3 sets.Id pull number 1 and it would have a track on the porcelian.It wasnt much.I finally used Advanced wires 2 years ago.No more rough idle or occasional miss.Rocky
Chrysler Firepower
[Re: gdonovan]
#1632684
06/16/14 02:41 PM
06/16/14 02:41 PM
Posts: 6,033 Salem
Grizzly
Salem
Rocky, I went to an NGK. The gap on them has opened a bit but nothing too crazy. They have probably 15, 20,000 miles on them is all. I saved the old Champions and threw it back in #1 hole and it still has the miss. I have heard over the years the only thing a Dodge likes is Champions. I found that out too with 360 Magnum: tried NGK's and wound up going back to Champions. Swapped the 1 and 4 wire and still missfire on #1. I swapped the #1 and #2 injector last night, we'll see what happens after it gets some miles on it.
Mo' Farts
[Re: gdonovan]
#1632686
06/16/14 04:16 PM
06/16/14 04:16 PM
therocks
Niles , Ohio
We run NGKs in everything.I always ran Autolites.Then I went NGK in the 440 with 12.5 compression and street driven.It really likes them as does the other cars.Even the PT likes them.The 440s have been in about 4 years and still no problems.The Autolite race plugs always had a slight off sound.Rocky
Chrysler Firepower
[Re: therocks]
#1632687
06/17/14 02:45 AM
06/17/14 02:45 AM
eightlitermopar
Sorry for the delayed update.
It seems to run fine, just that "shudder" at idle. No codes are being thrown.
Plugs and wires changed as stated. I replaced the plugs with original champions (from NAPA), and MOPAR wires from the dealership.
It did not run any better or worse after the swap. I noticed it fired quicker with the new plugs, not as much cranking.
I'll have to check my coil pack too, and I still have to check the resistance on my injectors.
Mopar or no car
