Page 2 of 3 1 2 3
Re: The famous Neon rough idle question... [Re: eightlitermopar] #1632669
06/14/14 02:36 PM
06/14/14 02:36 PM
North Central Florida
E
eightlitermopar Offline OP
E
So I took off the IAC, and it actually looks pretty clean. If I wanted to clean it out, do I just spray brake cleaner in the hole to the left? I don't want to ruin anything...
Mopar or no car
Re: The famous Neon rough idle question... [Re: eightlitermopar] #1632670
06/14/14 02:39 PM
06/14/14 02:39 PM
E
E
Also, while I was poking around, I noticed the plug on one of the vacuum ports. You can see which port I am talking about in the picture.
Mopar or no car
Re: The famous Neon rough idle question... [Re: eightlitermopar] #1632671
06/14/14 02:40 PM
06/14/14 02:40 PM
E
E
Here is the plug that was covering it.....
Mopar or no car
Re: The famous Neon rough idle question... [Re: eightlitermopar] #1632672
06/14/14 02:41 PM
06/14/14 02:41 PM
E
E
another view
Mopar or no car
Re: The famous Neon rough idle question... [Re: eightlitermopar] #1632673
06/14/14 04:28 PM
06/14/14 04:28 PM
CO
Twisted Offline
Twisted  Offline
CO
Just spray everything including the TB side. I have connected power to actuate the valve but it doesn't seem needed if it seems to be working, just spray both sides. Not sure on that cap. It could be a problem but I would think it would be more noticeable of a stumble if it had a vacuum leak.
Thank you
Aaron
69 Dodge Polara 4DHT
70 Plymouth Duster
03 Dodge Neon R/T
05 Dodge Grand Caravan SXT
Re: The famous Neon rough idle question... [Re: Twisted] #1632674
06/14/14 07:16 PM
06/14/14 07:16 PM
E
E
I haven't sprayed the throttle body or the IAC yet, I wanted to see what difference the new vacuum cap made.
Before I was idling (in gear) at about 600 rpm (according to the dash tach).
I put on a good plug and now I am idling about 800, so some of a difference there, but the rough idle "shudder" is still there.
I will keep playing around and keep you guys posted.
eightlitermopar
Mopar or no car
Re: The famous Neon rough idle question... [Re: eightlitermopar] #1632675
06/15/14 06:57 AM
06/15/14 06:57 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Could you actually see rust particles in the injector? Or were they just to small and wedged down there?
One way to tell is the spray pattern on the injectors.
"I think its got a hemi"
Re: The famous Neon rough idle question... [Re: eightlitermopar] #1632676
06/15/14 01:22 PM
06/15/14 01:22 PM
Benton, IL.
DaveRS23 Offline
Master of nothing...
DaveRS23  Offline
Benton, IL.
In my experience, when the IAC is dirty the idle is slow to respond or unresponsive. As in idles too high or the engine dies at idle because it is too low. The IAC is just a tapered plunger that plugs and unplugs a by-pass hole in the throttle body that allows more or less air into the engine.
It doesn't usually cause a rough running idle condition, unless it causes an extremely low idle that causes the engine to shake.
I usually spray carb cleaner in it and let it soak for awhile and then spray it again. Be sure to remove the gasket/seal first.
Master, again and still
Re: The famous Neon rough idle question... [Re: DaveRS23] #1632677
06/15/14 01:32 PM
06/15/14 01:32 PM
Ohio
Todd Offline
Todd  Offline
Ohio
Where I work we have BG induction service.
It has an injector that sprays cleaner in the t-body with the engine running.
Works very well. Cleans the entire t-body,IAC circuts and intake.
I had a neon I did that to and the inside of the intake looked like new.
I clean all my vehicles every 30k with it.
Re: The famous Neon rough idle question... [Re: Todd] #1632678
06/15/14 05:10 PM
06/15/14 05:10 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
You might check to see if you have plenty of clearance between the core support and the engine and trans. I have seen alot of neons that have bottomed out at some time or another and pushed the core support back into the engine of trans. Especially the second gen cars. The The PCM and rad fans like to come in contact with the trans causing the issue you describe. One other thing, Have you ever done a compression test on your engine? Later 2.0s had horrible valve jobs and are common for the valves not to seat well and cause miss or shake without setting a MIL.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: The famous Neon rough idle question... [Re: 71yelladustr] #1632679
06/15/14 08:22 PM
06/15/14 08:22 PM
E
E
I have not checked the compression yet, mostly because I am afraid I am going to find a low cylinder. I have heard that about these cars as well. Also, the car drives great (other than the idle, which isn't horrible) and it gets great mileage, so even if I have a dead cylinder....I probably wouldn't do anything about it anyway
Mopar or no car
Re: The famous Neon rough idle question... [Re: DaveRS23] #1632680
06/16/14 02:58 AM
06/16/14 02:58 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I agree as a dirty IAC wont cause a rough idle just a slow or fast idle. My question is does it feel like a dead miss or more like a vibration but still hitting on all 4 cylinders ? Ron
Re: The famous Neon rough idle question... [Re: eightlitermopar] #1632681
06/16/14 12:43 PM
06/16/14 12:43 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
I feel your pain, Eightliter, I am pulling my hair out with the same problem for the last 2 months.
And, just like you, I found a lot of suggestions but no real solution with Google.
One, that will be a last resort, is a fellow drilled a 5/32nd hole in his throttle plate.
I just had a Dealer re-flash done on the car as per a TSB for "rough idle, P0300 random misfire" issues. It didn't help, but the misfire codes don't show up as much.
Still getting P0300 and P0301. Have swapped wires, plugs, tested the coil, checked wiring harness to coil, changed the IAC, and just last night I took all the injectors out and cleaned them off the car (pretty neat method I found online ).
Unhooked the battery, cleared the codes, and fired it back up. Ran smooth and figured I got it. Drove it a few minutes, stopped in Drive, and the miss/low idle is back.
This little issue has really soured my high praise for Chrysler. The thing has low miles, well-cared for, drives/handles, just generally does everything better than any brand-x vehicle otherwise.
I did the timing belt, crank seal, and cam seal and was very careful on getting the timing marks correct. The car ran perfect for a few thousand miles and then the misfire codes came up.
Some great suggestions on here too, thanks Guys, I'll give them a try. I guess I gotta find some time this week and dig into it again.
Mo' Farts
Moderated by "tbagger".
Re: The famous Neon rough idle question... [Re: eightlitermopar] #1632682
06/16/14 12:56 PM
06/16/14 12:56 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
What pluigs and wires did you use?I had one at work that I used Champions in that were direct replacement.It would run great but had rough idle at times.Changed them and wires twice.Finally I had the manager get Champions from the dealer.Installed them and no more roughness.Weird I know as they were the same plug and number.Wires will cause a rough idle and sometimes a miss also.The wifes PT went thru it.New Autolite wires 2 sets.New plugs 3 sets.Id pull number 1 and it would have a track on the porcelian.It wasnt much.I finally used Advanced wires 2 years ago.No more rough idle or occasional miss.Rocky
Chrysler Firepower
Re: The famous Neon rough idle question... [Re: Grizzly] #1632683
06/16/14 01:09 PM
06/16/14 01:09 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
We did coil packs like popcorn too, it was such a noted issue that I still have a test coilpack that was in my toolbox for down and dirty testing.
Re: The famous Neon rough idle question... [Re: gdonovan] #1632684
06/16/14 01:41 PM
06/16/14 01:41 PM
Salem
Grizzly Offline
Grizzly  Offline
Salem
Rocky, I went to an NGK. The gap on them has opened a bit but nothing too crazy. They have probably 15, 20,000 miles on them is all.
I saved the old Champions and threw it back in #1 hole and it still has the miss.
I have heard over the years the only thing a Dodge likes is Champions. I found that out too with 360 Magnum: tried NGK's and wound up going back to Champions.
Swapped the 1 and 4 wire and still missfire on #1. I swapped the #1 and #2 injector last night, we'll see what happens after it gets some miles on it.
Mo' Farts
Re: The famous Neon rough idle question... [Re: Grizzly] #1632685
06/16/14 01:54 PM
06/16/14 01:54 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Normally I run nothing but Champions, but have Autolights from Wally-world in the neon 3 or 4 years ago and it didn't seem to care.
Still running great.
The coil pack on your car might have a carbon track on it, wasn't unusual at all.
Re: The famous Neon rough idle question... [Re: gdonovan] #1632686
06/16/14 03:16 PM
06/16/14 03:16 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
We run NGKs in everything.I always ran Autolites.Then I went NGK in the 440 with 12.5 compression and street driven.It really likes them as does the other cars.Even the PT likes them.The 440s have been in about 4 years and still no problems.The Autolite race plugs always had a slight off sound.Rocky
Chrysler Firepower
Re: The famous Neon rough idle question... [Re: therocks] #1632687
06/17/14 01:45 AM
06/17/14 01:45 AM
E
E
Sorry for the delayed update.
It seems to run fine, just that "shudder" at idle. No codes are being thrown.
Plugs and wires changed as stated. I replaced the plugs with original champions (from NAPA), and MOPAR wires from the dealership.
It did not run any better or worse after the swap. I noticed it fired quicker with the new plugs, not as much cranking.
I'll have to check my coil pack too, and I still have to check the resistance on my injectors.
Mopar or no car
Re: The famous Neon rough idle question... [Re: eightlitermopar] #1632688
06/17/14 09:41 AM
06/17/14 09:41 AM
Salem
Grizzly Offline
Grizzly  Offline
Salem
...........I'll have to check my coil pack too, and I still have to check the resistance on my injectors.
I had 12.4 to 12.7 Ohm all the way across on mine.
Injector Testing
Also, in that troubleshooting series I used their method for testing the coil:
Coil Test
Had a nice, fat spark.
I pulled all the plugs last night and tightened the gap to .30: run it again for awhile and see what happens.
Good luck.
I'm still thinking about drilling the hole in the throttle plate....
Mo' Farts
Page 2 of 3 1 2 3
