Door Frame - correct sheen ? ? '70 Roadrunner #1632603
06/12/14 05:19 PM
06/12/14 05:19 PM
Phoenix, AZ
MCTPhoenix Offline OP
Phoenix, AZ
Having taken a break on my '69 Charger since it's debut at MATS (thanks again everyone for the great advice and info!) I'm now back on my brothers '70 Roadrunner. B5 with White vinyl top and interior...the plate shows B7 color on the interior items that weren't white vinyl. When he first painted this car back in '86 it was in the school body shop (remember those?) and everything was sprayed fresh B7 centauri. Now it's going back to B5. What is the correct sheen on the inner door frames and the rear metal upper "pads". I'm relatively sure full gloss clear is wrong but I seem to think that the low gloss/ satin to near flat is also wrong. Thoughts?
Re: Door Frame - correct sheen ? ? '70 Roadrunner [Re: MCTPhoenix] #1632604
06/12/14 05:46 PM
06/12/14 05:46 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
I don't have it in front of me but there are two different paint formulas for int vs. ext. ....of course I painted my upper doors in full gloss F8 before learning this...
I did my dash in base clear and when I realized it was wrong, I had them apply satin clear over top and it looks darn close but that would be too flat for the upper door frames
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Door Frame - correct sheen ? ? '70 Roadrunner [Re: MCTPhoenix] #1632605
06/12/14 07:03 PM
06/12/14 07:03 PM
USA
b54406barrel Offline
USA
Pretty sure it's gloss but I can look tonight. There are about 9 shades/finishes of blue on the inside of my car and it's been that way since new.
Re: Door Frame - correct sheen ? ? '70 Roadrunner [Re: b54406barrel] #1632606
06/12/14 07:05 PM
06/12/14 07:05 PM
Wisconsin
Stewpar Offline
Stewpar  Offline
Wisconsin
Gloss
Admiration For Multiple Carburetor Vehicles...
Re: Door Frame - correct sheen ? ? '70 Roadrunner [Re: Stewpar] #1632607
06/12/14 07:43 PM
06/12/14 07:43 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
Re: Door Frame - correct sheen ? ? '70 Roadrunner [Re: MCTPhoenix] #1632608
06/12/14 07:56 PM
06/12/14 07:56 PM
USA
USA
Now that I think of it, I had a blue 69 rr that had white interior and I think the door frame was white. Maybe I'm just remembering wrong?
Re: Door Frame - correct sheen ? ? '70 Roadrunner [Re: b54406barrel] #1632609
06/12/14 08:12 PM
06/12/14 08:12 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
All the white interiors I've seen have from the inside of the weatherstripping, interior door top and bottom painted gloss black. Same with upper back window panel. Outside of the weatherstripping body color.
Re: Door Frame - correct sheen ? ? '70 Roadrunner [Re: b54406barrel] #1632610
06/12/14 08:18 PM
06/12/14 08:18 PM
USA
USA
Whoops, nevermind! I see now that I look at the govier report on my 70, the frame can come in several colors with different interiors. Sorry!
Re: Door Frame - correct sheen ? ? '70 Roadrunner [Re: MCTPhoenix] #1632611
06/12/14 08:26 PM
06/12/14 08:26 PM
Phoenix, AZ
Phoenix, AZ
I'm sure of the color, B7. Just wanting clarification on the sheen. Full gloss with the clear just seems to look "wrong" Perhaps it's the aged originals in single stage that just appear to have lower gloss that have me confused
Re: Door Frame - correct sheen ? ? '70 Roadrunner [Re: b54406barrel] #1632612
06/12/14 08:27 PM
06/12/14 08:27 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
I could be wrong too. I was shopping for ideas as to what to do with my interior as I haven't had one since I pulled it out in'87 for some paint work. Only thing left of my blue interior are the coat hooks and seatbelts. I saw a couple of white seat/ door panel setups, all having black dash/door paint and I believe seat hinge covers/ seatbelts and figured that's the way they all were. Was this a special option? Did all B5 cars have B7 interiors? Don't mean to hijack!
Re: Door Frame - correct sheen ? ? '70 Roadrunner [Re: MCTPhoenix] #1632613
06/12/14 09:11 PM
06/12/14 09:11 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
I still have the roof rails that were B7 gloss, but the front headliner panel is satin like the dash and steering column were.
Re: Door Frame - correct sheen ? ? '70 Roadrunner [Re: MCTPhoenix] #1632614
06/12/14 09:18 PM
06/12/14 09:18 PM
USA
USA
Likely because of b/c, not because of the age though that would play in some being 44 years old now, on original paint cars. Here's mine at 9 months old, in front of the house. They definitely were not as shiny as b/c, even when new.
Re: Door Frame - correct sheen ? ? '70 Roadrunner [Re: b54406barrel] #1632615
06/12/14 10:55 PM
06/12/14 10:55 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
interior were not clear coated.
Re: Door Frame - correct sheen ? ? '70 Roadrunner [Re: Pynzo] #1632616
06/13/14 12:20 PM
06/13/14 12:20 PM
DPelletier Offline
DPelletier  Offline
Yep, dash, headliner panel and steering column were unique from the rest of the car in terms of finish.
Re: Door Frame - correct sheen ? ? '70 Roadrunner [Re: Pynzo] #1632617
06/13/14 05:06 PM
06/13/14 05:06 PM
Phoenix, AZ
Phoenix, AZ
Umm... nothing was cleared back then
Re: Door Frame - correct sheen ? ? '70 Roadrunner [Re: MCTPhoenix] #1632618
06/13/14 07:48 PM
06/13/14 07:48 PM
DPelletier Offline
DPelletier  Offline
Re: Door Frame - correct sheen ? ? '70 Roadrunner [Re: DPelletier] #1632619
06/13/14 07:55 PM
06/13/14 07:55 PM
DPelletier Offline
DPelletier  Offline
As you can see in this example (thanks to Barry Washington and Andy440.com) there are several different paint colors. Using my '70 Dodge in F8 with matching interior as an example;
Gloss Interior: PPG 43926 (i.e. quarter window upper mouldings)
Gloss Exterior: PPG 43786 (i.e. all integral mouldings. door and quarter)
Low Gloss: PPG 43929
Suede Finish: PPG 43925 (i.e. instrument panel, steering column, windshield mouldings)
....as you can see there are four different paint codes for the color that is simply described on the fender tag as F8
Hope this helps.
