Re: Race Car Tow Vehicle Advice
[Re: cudaman1969]
#1632315
06/13/14 08:24 PM
06/13/14 08:24 PM
Posts: 1,169 MI
68shifter
MI
The tough thing between the stick/auto is engine rating. With a DRW the stick option is 660ft/lb and the Aisin auto will bump you to 850ft/lb. the newer models do not have deletes yet available and tuners are slow to the market so it's not a simple option to gain that power back. I think stick will probably always have a bit better resale value being Ram is the only one with that option. The Aisin has been top notch but is a pricey option, around $2-2500. The 68rfe is a darn good auto as well and is the base option in most trucks. Good luck Cumminsforum.com has a lot of good info on the new trucks.
[Re: dusturbd340W5]
#1632316
06/13/14 09:37 PM
06/13/14 09:37 PM
Posts: 43,846 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
1 more thing to think about when towing a trailer srw and a rear tire failure not so good, with a drw no problem you keep on trucking till you can pull of the interstate.
Yep, when you blow a tire on a dually you buy a new bedside, DAMHIK! Especially the new dually's that have plastic bedsides. I blew a tire on my SRW towing my trailer and there were no issues at all, I was going 65 MPH and pulled over to the shoulder, no damage on my bed, changed the tire, and went on my way. I have probably towed more than anyone on this board, but you don't have to believe me.
JB Rhinehart, Realist
A-Body's RULE!
[Re: Rhinodart]
#1632317
06/13/14 10:47 PM
06/13/14 10:47 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
yeah and you where on the shoulder with other vehicles wizzing by. I will take a DRW every day of the week when pulling.
I have pulled open trailers, enclosed race trailers and my 35' 5th wheel all over the south east and for me its a DRW all the way.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: dusturbd340W5]
#1632320
06/14/14 01:14 AM
06/14/14 01:14 AM
Rhinodart
Rhinotruck
Rhinotruck
Had a 48' fifth wheel and I did pull it with a 99, 05, and 07 dually's. Also pulled this monster for 200K miles...
A-Body's RULE!
[Re: Rhinodart]
#1632321
06/14/14 02:35 AM
06/14/14 02:35 AM
dusturbd340W5
Kissimmee Fl.
sweet rig
