Headliner Install Question
#1630588
06/08/14 06:27 PM
06/08/14 06:27 PM
Posts: 1,212 Canton, Ohio
Crazy68Dart
Canton, Ohio
So, I've been collecting parts for years. Now is the time to do the headliner. I have it laid out, but it seems really big. The listing pockets and material extend well beyond the length of the bows. Talking a good 6+ inches per side when the bow is laying in the center.
Are these things "universal fit" where they can be and I just need to trim *a lot* of material off?
Bows are original, and in the correct order.
For my 68 Dart...
383, Hemi 4-Speed, AlterKtion, D60
Re: Headliner Install Question
[Re: Crazy68Dart]
#1630589
06/08/14 06:37 PM
06/08/14 06:37 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
For my 68 Dart...
it's been awhile since i've done one but keep in mind when you hit it with the hair dryer there will be shrinking and tightening. 6 inches per side seems excessive but i honestly don't remember how much 'slop' there is. if i remember right i didn't start out with having the sides with even amount of slop. i think i had most of the excess on one side and worked front to back, then tacked down on one side and worked it over to the other. i used those jumbo steel trap type paperclips to hold it until i was ready for the tack glue.
[Re: Crazy68Dart]
#1630590
06/08/14 06:39 PM
06/08/14 06:39 PM
RapidRobert
Yes they have extra as they are trim to fit. 6"+ overhang per side does seem like alot of extra material tho & maybe that # fits several apps. I'd check the # & continue on. I've only did one (65 dart) & my advice is to be patient & dont be afraid to walk away when a slight snag develops (pun intended & yes it will) & come back the next day especially if it is your first one and you'll likely need to walk away several times. The concept looks simple but they ain't easy. I've developed alot of of patience thru the years for things mechanical & rarely get rattled in the shop/garage but that headliner tested me
[Re: Crazy68Dart]
#1630593
06/08/14 07:02 PM
06/08/14 07:02 PM
Crazy68Dart
Canton, Ohio
I'll look for a part number... but I've likely had this thing for a decade as I have collected the restoration stuff over the years.
That is the front-most bow (towards the windshield).
[Re: mikemee1331]
#1630595
06/08/14 07:11 PM
06/08/14 07:11 PM
Crazy68Dart
Canton, Ohio
Only markings on it are a faint CGPC "watermark" logo. Okay... if this looks about right... wish me luck.
[Re: mikemee1331]
#1630597
06/08/14 11:51 PM
06/08/14 11:51 PM
Crazy68Dart
Canton, Ohio
I also didn't mention the car has a cage... got as far as I wanted to tonight. So far so good.
[Re: Crazy68Dart]
#1630604
06/08/14 11:56 PM
06/08/14 11:56 PM
Crazy68Dart
Canton, Ohio
New steering wheel... I think it compliments the GT badge on the door panel nicely.
[Re: Crazy68Dart]
#1630607
06/10/14 11:46 PM
06/10/14 11:46 PM
Crazy68Dart
Canton, Ohio
This is going (slightly) better than expected. I am at the point of stretching, clamping, etc.
For the sail panels, does the liner get glued to the inner panel board? Maybe not...
For the sail panels, is it better to glue the side by the quarter windows and then pull into the teeth or the opposite?
