Re: Headliner Install Question
[Re: fastmark]
#1630613
06/11/14 10:45 AM
06/11/14 10:45 AM
Posts: 440 Canada
Dons Dart
Canada
Not sure how your is made. My cuda had card board panels that went on afterwards. The Challenger I worked on first did not have those so it was tougher. I stretched it at far as I could and then glued and stuck them in the teeth.
ps i have never seen my 69 darts with separate sail panels.
[Re: Dons Dart]
#1630614
06/11/14 11:52 AM
06/11/14 11:52 AM
Posts: 2,636 Nashville, TN
MOPARMIKE69
Nashville, TN
The sheer size and the included sail panels tell me you got the wrong headliner for a Dart. B'bodies have those sail panels and they just are held in with one or two clips. I hope you can make it work for your application.
69 Road Runner vert 69 GTX hard top 70 Road Runner 4 speed 70 Hemi Cuda vert
[Re: mikemee1331]
#1630619
06/12/14 06:31 PM
06/12/14 06:31 PM
Posts: 1,212 Canton, Ohio
Crazy68Dart
Canton, Ohio
Not sure what the deal is on the clips. I bagged everything when I took the car apart. No clips to be found. As big as it is there is what seems to be the appropriate amount towards the front. The sides and back are excessive though. Should be able to make it work though. ![](/ubbthreads/images/graemlins/thumbs.gif)
383, Hemi 4-Speed, AlterKtion, D60
