Local source for 68 B body headpipe? #1630487
06/08/14 03:18 PM
06/08/14 03:18 PM
Kent, WA
triple_green Offline OP
Kent, WA
Does anyone know if there is a local source like napa or oreillys that carries the headpipe for the big block stock exhaust manifold headpipe (from exhaust manifold to muffler) for a 68 Charger.
Thanks!
68 Charger, 383 HP console auto, spring green, stock restoration
Re: Local source for 68 B body headpipe? [Re: triple_green] #1630488
06/08/14 03:40 PM
06/08/14 03:40 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Have you tried either one of those?
Re: Local source for 68 B body headpipe? [Re: triple_green] #1630489
06/08/14 03:41 PM
06/08/14 03:41 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
http://www.walkerexhaust.com/catalog/walker-exhaust-systems/e-catalog-lookup
I believe NAPA still sells Walker Exhaust. You'll probably need to order them. I got the
2-1/2" set manifold back H pipe from TTI. very nice fit and quality
Re: Local source for 68 B body headpipe? [Re: Pynzo] #1630490
06/08/14 04:13 PM
06/08/14 04:13 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I don't think Walker makes anything for the old mopars anymore.
I will need exhaust for a 1970 Challenger soon and owner just wants to have it made locally ( friend of mine is mgr. of a Midas so we're just going to take it there.)
Re: Local source for 68 B body headpipe? [Re: gtx6970] #1630491
06/08/14 04:35 PM
06/08/14 04:35 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I would not use Midas.. Their pipe is barely thicker than tin foil.
I am truckless..
Re: Local source for 68 B body headpipe? [Re: gtx6970] #1630492
06/08/14 04:36 PM
06/08/14 04:36 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
Probably your best bet. I've worked at Midas and Meineke. Go for the aluminized pipe. I just cut down the system I installed on my Bee back in '87. The pipes were still solid! A custom dual system was $350 back then. I paid $25 for Walker turbos and 3 sticks of aluminized 2-1/2" pipe. Didn't have a bender available this time so I went with the TTI.
Bring new hangers with you. You will not like what they have. Mufflers too-
Re: Local source for 68 B body headpipe? [Re: 340SHORTY] #1630493
06/08/14 04:40 PM
06/08/14 04:40 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
Meineke was a better place to work for and had better pipe.
Re: Local source for 68 B body headpipe? [Re: triple_green] #1630494
06/09/14 11:50 AM
06/09/14 11:50 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Thanks!
No , they stopped making pipes for muscle car era cars decades ago.
Isn't Accurate Ltd. in your neck of the woods? That would be as local as you would find .
Re: Local source for 68 B body headpipe? [Re: triple_green] #1630495
06/09/14 11:53 AM
06/09/14 11:53 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Thanks!
Accurate has what you need. Give Tom a call.
