Page 2 of 3 1 2 3
Re: FREE Headers. So far they are NOT worth it. [Re: gtsdude] #1629814
06/09/14 07:16 AM
06/09/14 07:16 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Never tried headmans.
I ran a set back in the 80's, they fit with no problem in a Dart. I'm surprised the OP had such problems. Must have changed since then.
"I think its got a hemi"
Re: FREE Headers. So far they are NOT worth it. [Re: gdonovan] #1629815
06/09/14 11:29 PM
06/09/14 11:29 PM
Granite Bay CA
Kern Dog Offline OP
Striving for excellence
Kern Dog  Offline OP
Granite Bay CA
I usually have pretty decent luck in life. I could see blaming fitment on an engine sitting out of position, but the RH pipes are grouped together too wide. The oil pan and Torsion bar are parallel yet the pipes are too wide to fit between them without denting. I'm probably going to pull the RH out to smash in some clearance. I hate doing it but I dont want them to rattle or cook the temper out of the torsion bar. I suppose they would heat the oil in the pan too.
Re: FREE Headers. So far they are NOT worth it. [Re: Kern Dog] #1629816
06/10/14 02:30 AM
06/10/14 02:30 AM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Eight tubes riding down there in a street car can cause all kinda temp related issues...
I can tell you all about trans pan gaskets that spend time between two header collector's...
For hours upon hours...
In extreme heat...
Whole different world than a car ridin' down the 1320...
Re: FREE Headers. So far they are NOT worth it. [Re: Kern Dog] #1629817
06/10/14 02:44 AM
06/10/14 02:44 AM
Roseburg, Oregon
Tom Swope Offline
Tom Swope  Offline
Roseburg, Oregon
We did some tech for Hedman on these particular headers years ago at their request as we were Mopar specific. The headers were tested on 67-72 and 73 newer a-body applications. Without modifications we considered them as a no-fit header at least for the applications we tested. Suggestions were made to Hedman for possible improvements
but it appears no changes were made. Even if the headers were modified above for clearance then it takes a pretty good pipe bender tech to hook them up to clear linkage and everything else. Cutting the 3 bolt flanges off offers a little more room but it still is difficult for an experienced fabricator.
Re: FREE Headers. So far they are NOT worth it. [Re: Tom Swope] #1629818
06/10/14 02:12 PM
06/10/14 02:12 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Schumacher Creative Industries sells a wonderful smallblock header- but they are very expensive.
Keep old mopars alive.
Re: FREE Headers. So far they are NOT worth it. [Re: 2boltmain] #1629819
06/11/14 12:54 AM
06/11/14 12:54 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
I once made the mistake of trying to fit a set of Doug Thorley headers into by 74 FrankenDuster. After somewhere between 12-15 times installing, removing to make clearance dents and trial fitting again, I got fed up and hacked them apart with a sawzall. I ordered TTI pipes and never regretted it. I had every intention of keeping that car but ended up selling it a few years later.
This time I'm working on a car that I plan to sell. I knew these were cheap headers and expected to have a few adjustments to make. If this were a low budget bracket race car, the money saved on headers would be fine. In truth, even with some additional dents they will still outflow even the best factory iron manifold. If & when I decide to build another A body to keep, I will sell parts, mow lawns, wash cars or have a bake sale to have the $$$ to buy a set of Dougs or TTI pipes.
Re: FREE Headers. So far they are NOT worth it. [Re: Tom Swope] #1629820
06/11/14 01:47 AM
06/11/14 01:47 AM
Tacoma, Washington USA
Adam71Charger Offline
Are these problems with Hedman only found in small block applications? Will be searching for RB headers in my B body soon. I've heard dougs are nice
Re: FREE Headers. So far they are NOT worth it. [Re: Adam71Charger] #1629821
06/11/14 02:39 AM
06/11/14 02:39 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
The main problem stems from trying to fit CHEAP headers in an A body Chassis.
When I went from a 318 to a 440 in my Charger, my first set of headers were Hooker #5903. The car had never been in a wreck and I used new mounts. The headers still made contact at the LH torsion bar and the idler arm. I later went with Hooker #5209 pipes. Those had a 3&1 design with a separate pipe from the 4. Yeah, still a few points of contact. These TTIs clear everything, even the Fast ratio Idler and Pitman even though their instructions clearly state that they DO NOT clear.
I like the habit of UNDER promising and OVER delivering.
Re: FREE Headers. So far they are NOT worth it. [Re: Kern Dog] #1629822
06/11/14 02:57 AM
06/11/14 02:57 AM
I hear you. Do you remember the part # on the TTI?
Re: FREE Headers. So far they are NOT worth it. [Re: Kern Dog] #1629823
06/11/14 11:10 AM
06/11/14 11:10 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I guess you get what you pay for . My Hustlers were not cheap by any means, but they fit like a glove and make good power.
Re: FREE Headers. So far they are NOT worth it. [Re: Adam71Charger] #1629824
06/11/14 12:00 PM
06/11/14 12:00 PM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
Took off a set of brand new headmans on my 70 runner and replaced them with a set of Doug Thorleys. No clearance problems at all. Love them!
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: FREE Headers. So far they are NOT worth it. [Re: justinp61] #1629825
06/11/14 12:05 PM
06/11/14 12:05 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Back when I wanted to get my GTX back on the road I cut out the beat Hookers and tossed in a cheap set of the Summit house brand.
440 in a b-body but I was impressed, they hit nothing and fit perfect.
Go figure.
As an A-body owner they have always been a bear when it came to headers.
Re: FREE Headers. So far they are NOT worth it. [Re: Adam71Charger] #1629826
06/11/14 10:39 PM
06/11/14 10:39 PM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
The headers I used on the 74 Duster were the 1 5/8" versions. They had one set that also had 3 pipes with the 4th put in around the torsion bar. The ones I had were different with all 4 pipes in one.
The Charger has 2" TTI pipes that are listed to fit 67-76 A as well as 66-70 B and all E body cars. Sorry I do not have the part numbers.
Re: FREE Headers. So far they are NOT worth it. [Re: scratchnfotraction] #1629827
06/12/14 10:16 AM
06/12/14 10:16 AM
Slidell, LA
Plum440 Offline
Plum440  Offline
Slidell, LA
x2 on the hedman hustler
X3 here... Mine were very easy on the 440 with PS. I had to make a slight adjustment by the pump but that was 2 taps of a hammer. No harm, no foul.
70 Challenger, 440, 4-speed, pLuM cRaZy
71 VW Super Beetle Convertible, Lemon Yellow
A couple of Jeeps…
Re: FREE Headers. So far they are NOT worth it. [Re: Kern Dog] #1629828
06/12/14 12:55 PM
06/12/14 12:55 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Free junk is still junk. I'm a manifold guy (but would pass on the expensive extrude honing because it actually does very little) but if I was going to use headers I would buck up and buy a decent set. Smashing headers in a bunch of locations and still having the pipes way to close to the oil pan and other elements isn't my idea of a great install.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: FREE Headers. So far they are NOT worth it. [Re: RapidRobert] #1629829
02/16/15 11:38 AM
02/16/15 11:38 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
By eyeballing the enginebay and the shorties I think I have a much easier time installing these then a set of full length headers.
When the time comes let us know how they fit & what brand are they
Well, as a late update to the Shorties above...
I sold them again, because centerdump headers don't work for me as the main tubes are then supposed to go under the steeringlinkage. This leaves them prone to being hit by everything higher then a pebble on the street on my lowstance Dart.
Properly designed shorties would need to exit between the last two cylinders, just like a regular castiron manifold would exit, only slightly lower.
Re: FREE Headers. So far they are NOT worth it. [Re: BigBlockMopar] #1629830
02/16/15 10:57 PM
02/16/15 10:57 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
you might look at some smallblock truck shorty headers. they're tight to the block, and exit at the rear.
Re: FREE Headers. So far they are NOT worth it. [Re: Golden-Arm] #1629831
02/17/15 12:58 AM
02/17/15 12:58 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
I had a set of Dakota 5.2/5.9 headers once. The RH side looked like it would fit but the LH collector aimed right at the trans column linkage. I even looked at a manual trans car I had and the clutch linkage torque shaft was in the way there as well. The LH collector seems to need to be between #s 5 and 7 port and pointing almost straight down.
Re: FREE Headers. So far they are NOT worth it. [Re: Kern Dog] #1629832
02/18/15 06:59 AM
02/18/15 06:59 AM
The Netherlands
The Netherlands
Thanks for the advice. I had read elsewhere once about this but never really looked into it.
Just had a look at Dakota headers and they seem affordable enough to find on Ebay to try out a set.
My Dart has a console-shifter but the headers could get some modifying if needed. It also has powerbrakes and powersteering (But it's a Borgeson box).
On the other hand I've never seen any good pics of smallblock A-bodies with these kinda Dakota headers on them before.
Re: FREE Headers. So far they are NOT worth it. [Re: BigBlockMopar] #1629833
02/18/15 02:58 PM
02/18/15 02:58 PM
Montana
DDodger Offline
DDodger  Offline
Montana
The thing "I don't get" about the Hedman design. I'm an old guy. Those were first made, when? late 60's? certainly early 70's. I HAD a set when I swapped a SB into a 70 B body in about 74?
The point? NO reason why a product that has spanned that length of time could not have been "tweeked" to fit acceptably.
I DO understand the variation in A body pillow mounts, but the OP seems to have spool mounts which should get that part of the tolerance down to a fairly small amount.
Page 2 of 3 1 2 3
