Page 1 of 4 1 2 3 4
reading these plugs #1628656
06/04/14 05:21 PM
06/04/14 05:21 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
NGK R5671A-9. I can get about 5 runs on a new set before the motor starts to miss above 4500. 408 blown application with water injection. If I clean them they are good again. Thinking about going to -8's or 7's and or running a little less water. Didn't have this problem when I was running cast iron heads. Seemed to crop up when I switched to aluminum heads? Thoughts??
Fastest 300
Re: reading these plugs [Re: Crizila] #1628657
06/04/14 05:22 PM
06/04/14 05:22 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
pic2
Fastest 300
Re: reading these plugs [Re: Crizila] #1628658
06/04/14 05:23 PM
06/04/14 05:23 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
pic3
Fastest 300
Re: reading these plugs [Re: Crizila] #1628659
06/04/14 05:48 PM
06/04/14 05:48 PM
MR_P_BODY Offline
MR_P_BODY  Offline
In the first pic they are so rich you cant read them..
lean it down.. the other pics are flashed out so
I cant see them clearly
EDIT
isnt the 9 a cold plug and the 7 is hotter.. I can
never remember which way is hotter
Re: reading these plugs [Re: MR_P_BODY] #1628660
06/04/14 06:51 PM
06/04/14 06:51 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
EDIT
Agreed about rich but how`s the idle circuit first and foremost and how does your wide band read idle, cruise and wfo............Yes Mike, 7=hot 9=cold...........
Re: reading these plugs [Re: MR_P_BODY] #1628661
06/04/14 08:00 PM
06/04/14 08:00 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
EDIT
9 = coldest. The smaller the number the hotter. Ordered up some -8's. I'm about 5 sizes over what the carb came with, so I will pull a couple of sizes out of it on all 4 corners and try to take some better pics. Guess I'm a little gun shy after melting some pistons. FYI, I'm testing on the street, so I have to run an exhaust system ( which the blower don't like ) and I have to idle to and from the house to get to me test site. All not too good for plug reading. Bought a wide band, but don't have it installed yet. The 2 tracks still open around here are so crowded most of the time that I just can't get enough passes in to do any real testing.
Fastest 300
Re: reading these plugs [Re: Crizila] #1628662
06/04/14 08:06 PM
06/04/14 08:06 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Install the w/b, drive the car then report #`s...............way easier than pretending you know what`s goin on in the combustion chamber.............
Re: reading these plugs [Re: Thumperdart] #1628663
06/04/14 09:28 PM
06/04/14 09:28 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Gee, wonder what everyone did before the wide band 02 sensor came along.
Fastest 300
Re: reading these plugs [Re: Crizila] #1628664
06/04/14 09:33 PM
06/04/14 09:33 PM
Q
Quicktree Offline
Quicktree  Offline
Q
you really can't tell crap if they have 5 runs on them
Re: reading these plugs [Re: Quicktree] #1628665
06/04/14 09:41 PM
06/04/14 09:41 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Those are FAT... period... but a hotter plug might
do a lot for it... no one needs to change plugs that
often... unless its a TF engine
Re: reading these plugs [Re: MR_P_BODY] #1628666
06/04/14 09:42 PM
06/04/14 09:42 PM
Q
Quicktree Offline
Quicktree  Offline
Q
they could fat from the return road
Re: reading these plugs [Re: Quicktree] #1628667
06/04/14 09:58 PM
06/04/14 09:58 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Come on Tony... he gets 5 passes and they are shot
if its on the return road its DUMPING fuel.... but
it can be a weak ignition also... either way those
plugs are fowled
Re: reading these plugs [Re: MR_P_BODY] #1628668
06/04/14 10:55 PM
06/04/14 10:55 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Ya, agree with most of what's been said here. First, been through the ignition system in it's entirety and it is solid. What I know for sure is I get about 5 runs on it and the performance drops off ( engine miss ). Runs good when it's hittin on all 8 with speeds in the 129 MPH range, so the A/F can't be too far off at WOT. Yes, I gotta idle to staging and back to my pit area after my run. No boost, no miss. I can clean a set of plugs and make them work good again. I don't run an inner cooler. I do run a alcohol / water injection system. Run a mix - about 35% alcohol - probably do screwy things to a W/B 02 reading? Think I will try to drop some jet sizes and maybe put in a smaller water injection jet to see if that will help. My system is adjustable. I have it set for full spray pressure at 15 lbs of boost and over. Could try slowing it down? Also going to try a 1 step hotter plug.
Fastest 300
Re: reading these plugs [Re: Crizila] #1628669
06/04/14 11:16 PM
06/04/14 11:16 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Posted questions like yours.................. Thing is, you`re rich but you don`t know where otherwise you wouldn`t be askin..........
Re: reading these plugs [Re: Crizila] #1628670
06/04/14 11:25 PM
06/04/14 11:25 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Dont do a bunch of things together... do the plugs
and less water.. also whats the plug gap
Re: reading these plugs [Re: MR_P_BODY] #1628671
06/05/14 01:25 AM
06/05/14 01:25 AM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Ya, the nice thing about doing the testing from home - I can do one change at a time and then go test. Made jet changes today and will test tomorrow. Send some fresh plug pics. Then do a test with less water, then with hotter plugs. My brother is sending me the alcohol correction factor program I will have to use if / when I install my wide band. .030" on the plug gap.
Fastest 300
Re: reading these plugs [Re: Crizila] #1628672
06/05/14 01:29 AM
06/05/14 01:29 AM
Cab_Burge Online work
Cab_Burge  Online Work
Try leaning down the primary jets two sizes and richen up the secondarys two sizes or the primary power valve enrichment channel the same amount of volume that the two jets sizes smaller are, if your using a power valve in the front(if not jet the back up two) That should help keep the plugs cleaner while putting around in the pits and still safe at WOT
Re: reading these plugs [Re: Cab_Burge] #1628673
06/05/14 02:50 AM
06/05/14 02:50 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
If you are trying to read the plugs for power and proper mixture at WOT, you are just wasting your time the way you are doing it. The ONLY way plug reading works, is to make a power pull, kill the motor at the stripe and then read the plugs. Once you let it idle or drive it around, the plug reading is useless.
Monte
Re: reading these plugs [Re: Monte_Smith] #1628674
06/05/14 06:44 AM
06/05/14 06:44 AM
Q
Quicktree Offline
Quicktree  Offline
Q
Monte
thankyou
Re: reading these plugs [Re: Crizila] #1628675
06/05/14 08:03 AM
06/05/14 08:03 AM
Arizona
Chris'sBarracuda Offline
Arizona
Don't you live up around the 5000' mark there in Payson.??
I'm thinking that won't help you one bit testing up there and racing down here..
And.. What Monte says..
Chris..
Page 1 of 4 1 2 3 4
