Page 2 of 3 1 2 3
Re: 1970 Coronet RT ? [Re: stateline] #162652
12/06/08 02:57 PM
12/06/08 02:57 PM
Gloucester,VA STOP MOVING HERE
RangerDan440 Offline
getting back to the original post, my '68 R/T is coded on the fender tag for wheelwell and rocker moldings and not for the exhaust tips but it has them anyway (and always has)
All the chrome doodads, including tips, were part of the R/T package (except the CA cars) and the tag and/or BS may or may not be coded for them seperately. They were optional on Bees.
68 Valiant 408
69 Charger 318
69 Cougar 351W
70 Torino GT 351C
71 Country Squire 351W
71 Road Runner 440+6
71 Satellite sedan 318
73 Duster 318
73 Challenger 383
77 Grand Prix 455
83 Malibu 9C1 383
84 Delta 88 403
87 Grand National
96 Ram 360
09 Crown Vic
10 Challenger R/T M6
15 Challenger Hellcat M6
Re: 1970 Coronet RT ? [Re: RangerDan440] #162653
12/06/08 03:59 PM
12/06/08 03:59 PM
Houston, Tx
hemi68charger Offline
Houston, Tx
Not to be picky, but the original post mentioned the 1970 model year.. Also, you mentioned you car always had them. I'm taking it you're the original owner of the car or bought it from the original owner. Could very well have had them originally, but as an option. Using the point of "all R/T models came with all chrome doodads" is false. My v-code '70 Charger R/T didn't have them, wasn't on the BS. It came with turn-downs....... Either that, or someone took the tips off somewhere down the road. If the bright tips where standard on R/T and Superbees only, then why would there be a $20+ option cost listed.
Just food for thought or I'm missing something.
Troy
Houston Mopar Connection Club
Re: 1970 Coronet RT ? [Re: 6bblgt] #162654
12/06/08 04:19 PM
12/06/08 04:19 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
"This info is taken trom the 1970 Dodge Pocket Salesman's Guide posted on Hamtramck Historical.
Does anyone have the '70 PLYMOUTH version? It would be great to see it posted also."
The 70 Plymouth salesman pocket book is hard to find and $$$ when you do.
The 70 Plymouth data book will be on HH soon.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: 1970 Coronet RT ? [Re: hemi68charger] #162655
12/06/08 04:19 PM
12/06/08 04:19 PM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
Posts that stray from the original question often indicate how unknown the answers to these questions are. Differences exist within a model year & model. Bringing other years and models into the question doesn't help to clarify the question or answer. I know I am guilty of this also in my post above, but I was trying to point out the facts of the differences within Dodge in the '70 model year, after the Challengers got thrown into the post.
So ... does anybody have a b'cast sheet (or LA fender tag) for a '70 Coronet R/T, Super Bee or Charger R/T that shows: N42 N95 N97 ??
I think the original question was answered, N42 was an OPTION ($20.80 ) on '70 Coronet R/Ts.
It would be listed on the b'cast sheet or window sticker, and on a LA assembled car's fender tag.
Re: 1970 Coronet RT ? [Re: Ludington1] #162656
12/06/08 05:01 PM
12/06/08 05:01 PM
Detroit
Kidsixpack Offline
Kidsixpack  Offline
Detroit
I have the build sheet to my 70 Bee. Duel exhaust is marked, but N42 Exhaust tips is not marked? I guess my Bee did not come with tips!
My car was built at Lynch Rd.
KID
Re: 1970 Coronet RT ? [Re: 6bblgt] #162657
12/07/08 01:25 AM
12/07/08 01:25 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Not an LA built car but a Lynch Road 70 440-6 4 speed bee I used to own. The broadcast sheet for my old car has N95 N96 N97 AND N42 on it!
6bbl - Is your GTX Yellow by chance?
Re: 1970 Coronet RT ? [Re: RobX4406] #162658
12/07/08 02:10 AM
12/07/08 02:10 AM
Under the big sky
stateline Offline OP
Under the big sky
Thanks for the replys , to add another question to the mix - are the wheel lip molding standard on a 70 Coronet RT , I do at least know it had them and there isnt anything on the fender tag
Re: 1970 Coronet RT ? [Re: 6bblgt] #162659
12/07/08 02:30 AM
12/07/08 02:30 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
I'll check my Superbee 440+6 BS when I get home. I don't know if it has N97, but it does have N42 and N95.
I can't check on my old 70 R/T as I sent the BS to the new owner
Re: 1970 Coronet RT ? [Re: RobX4406] #162660
12/07/08 03:34 AM
12/07/08 03:34 AM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
Nope ... originally FJ5 "lime light", but custom painted early in its life.
Re: 1970 Coronet RT ? [Re: stateline] #162661
12/07/08 03:44 AM
12/07/08 03:44 AM
Detroit
Kidsixpack Offline
Kidsixpack  Offline
Detroit
Yep!
Re: 1970 Coronet RT ? [Re: 6bblgt] #162662
12/07/08 03:45 AM
12/07/08 03:45 AM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
M26 - wheel lip mouldings are STANDARD on '70 Coronet R/Ts & Super Bees.
Re: 1970 Coronet RT ? [Re: 6bblgt] #162663
12/07/08 06:56 PM
12/07/08 06:56 PM
El Cerrito Ca.
gregn96cuda Offline
gregn96cuda  Offline
El Cerrito Ca.
[image][/image]
I know these are not B bodies but I would think B&E cars would be the same for California.
These two tags are from a couple of 1970 cudas I have, a 440+6 & 440 4bbl. Both cars are 4 speeds both cars have n95 but the shaker car has turned down exhaust. I was told years ago that if you had fresh air intake the tips would be deleted for noise reduction.
The 440 4bbl... n41, n42, n95
The 440+6... n41, n95, n96, n97
Re: 1970 Coronet RT ? [Re: gregn96cuda] #162664
12/07/08 09:04 PM
12/07/08 09:04 PM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
That's the problem & source of confusion. You can't compare apples to oranges, in this case b-bodies to e-bodies or 1970 Coronets to 1968 Coronets or 440-4bbl to 440-6bbl.
On an e-body the SHAKER had nothing to do with N97 - "noise reduction".
Re: 1970 Coronet RT ? [Re: 6bblgt] #162665
12/07/08 09:54 PM
12/07/08 09:54 PM
El Cerrito Ca.
gregn96cuda Offline
gregn96cuda  Offline
El Cerrito Ca.
Then please explain why the noise reduction is on the shaker car.
In California n95 + n96 got you n97 on an e body. I am sure that a few might have slipped through, but they would have been an anomaly. You must remember 1970 was the first year for earth day, and all kinds of pollution were targeted to be reduced including noise pollution. Here in California the intake volume through the fresh air system made enough noise along with the exhaust note to be over the limit, so you got n97.
Why does the 440 4 bbl have tips? Do you think the guy that bought the 6bbl didn't have the $20 for tips, or maybe he didn't want the ev2 shaker car to be too flashy with chrome tips?
Re: 1970 Coronet RT ? [Re: 6bblgt] #162666
12/07/08 10:15 PM
12/07/08 10:15 PM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
The difference IS the 6bbl on an E-body!!
For 1970
CHALLENGER
N95 - Evaporative Control System - required on all cars registered in the State of California N.A. otherwise .......... $37.85
N97 - Noise Reduction Package - required on all cars registered in the state of California equipped with 440-6 engines or 426 Hemi .......... N.C.
N97 - Noise reduction was accieved in different ways on different body platforms, again California "only".
E-body - eliminate N42 "bright exhaust tips" from 440-6 & Hemi cars.
I will "assume" Plymouth's 'Cuda was dealt with in the same manner (in California).
Re: 1970 Coronet RT ? [Re: 6bblgt] #162667
12/07/08 10:24 PM
12/07/08 10:24 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Re: 1970 Coronet RT ? [Re: Alaskan_TA] #162668
12/07/08 11:10 PM
12/07/08 11:10 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
I have seen grills with red pin stripe in surround..and then not with pin stripe
Re: 1970 Coronet RT ? [Re: Alaskan_TA] #162669
12/07/08 11:12 PM
12/07/08 11:12 PM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
Barry, Same 2 pages?
I put some time/effort into this topic, this is what I came up with:
1970 performance cars sold in California
Super Bee
HEMI - N41, N95, N96, N97 (STD or Mandatory) N97 = NO TIPS
383 4bbl - N41, N95, N97 (STD or Mandatory) & N42, N96 (optional) N97 = noise reduction mufflers
440 6bbl - N41, N95, N97 (STD or Mandatory) & N42, N96 (optional) N97 = add resonators
Coronet R/T
440 4bbl - N41, N95, N97 (STD or Mandatory) & N96 (optional) N97 = NO TIPS
Charger R/T
HEMI - N41, N95, N97 (STD or Mandatory) N97 = NO TIPS
440 4bbl - N41, N95, N97 (STD or Mandatory) N97 = NO TIPS
440 6bbl - N41, N95, N97 (STD or Mandatory) & N42 (optional) N97 = add resonators
Challenger
340 4bbl - N41, N42, N95 (STD or Mandatory) & N94, N96 (limited/optional)
Challenger R/T
HEMI - N41, N95, N97 (STD or Mandatory) & N94, N96 (limited/optional) N97 = NO TIPS
383 4bbl - N41, N42, N95 (STD or Mandatory) & N94, N96 (limited/optional)
440 4bbl - N41, N42, N95 (STD or Mandatory) & N94, N96 (limited/optional)
440 6bbl - N41, N95, N97 (STD or Mandatory) & N94, N96 (limited/optional) N97 = NO TIPS
Road Runner
GTX
'Cuda
HEMI - N41, N95, N97 (STD or Mandatory) & N96 (optional) N97 = NO TIPS
340 4bbl - N41, N42, N95 (STD or Mandatory) & N96 (limited/optional)
383 4bbl - N41, N42, N95 (STD or Mandatory) & N96 (limited/optional)
440 4bbl - N41, N42, N95 (STD or Mandatory) & N96 (limited/optional)
440 6bbl - N41, N95, N97 (STD or Mandatory) & N96 (optional) N97 = NO TIPS
The guides make it "clear-as-mud",
but what happened to a 383 4bbl Charger, Sport Satellite, or Coronet 500?
I'm thinking the 383 4bbl, 440 4bbl, & 440 6bbl b-bodies with N97 may have required resonators only if "tips" were ordered??
More to follow ...
Re: 1970 Coronet RT ? [Re: 6bblgt] #162670
12/08/08 01:13 AM
12/08/08 01:13 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I thought those cars never got tips anyway. Neither did 70 383 N code E-bodies
Only non performance package (R/T, GTX, RR..) cars I can think of that got dual chrome tips were 70 A66 Challengers, 71 340 Challengers (non R/T), and maybe 71 Charger S/E 440 cars???
Getting off subject with tips, would be the 64-66 273 HP single big resonator chrome tips. Did every 273 HP get them? Or just Dart GT's and Formula "S". You could get a 273 HP Dart station wagon.
Re: 1970 Coronet RT ? [Re: autoxcuda] #162671
12/08/08 01:35 AM
12/08/08 01:35 AM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
I believe we were talking N95 - "CA emissions" & N97 - "CA noise reduction". or was it N42 - "tips" on a Coronet R/T that started this?
Page 2 of 3 1 2 3
