2001 Durango 4.7 thermostat #1626716
05/30/14 09:40 AM
05/30/14 09:40 AM
Carson City, NV
babarracuda Offline OP
Carson City, NV
I prety sure that the thermostat on my Durango is stuck closed. The problem is that I don't see where it is located. Also a mechanic I know said that if it is plastic, get a new one because the old one will leak. HELP an old man, please!!
Re: 2001 Durango 4.7 thermostat [Re: babarracuda] #1626717
05/30/14 09:47 AM
05/30/14 09:47 AM
NJ
rth Offline
rth  Offline
NJ
It's on engine side of lower hose. Bolts tend to break,go easy with them. I had to drill out my lower bolt and used long bolt and nut.
Re: 2001 Durango 4.7 thermostat [Re: rth] #1626718
05/30/14 11:54 AM
05/30/14 11:54 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I just did this job, my housing would leak in cold weather, got the housing and new stat from rockauto. I cut the head of the bolts off since they were rusty, this way I had plenty of stud to hold, then heated the and used penetrating oil they came right out.
You should be fine in NV might not need the housing but for the price I would just replace anyway.
