Re: 1970 Coronet RT ?
[Re: stateline]
#162652
12/06/08 02:57 PM
12/06/08 02:57 PM
Posts: 12,861 Gloucester,VA STOP MOVING HERE
RangerDan440
getting back to the original post, my '68 R/T is coded on the fender tag for wheelwell and rocker moldings and not for the exhaust tips but it has them anyway (and always has)
All the chrome doodads, including tips, were part of the R/T package (except the CA cars) and the tag and/or BS may or may not be coded for them seperately. They were optional on Bees.
68 Valiant 408 69 Charger 318 69 Cougar 351W 70 Torino GT 351C 71 Country Squire 351W 71 Road Runner 440+6 71 Satellite sedan 318 73 Duster 318 73 Challenger 383 77 Grand Prix 455 83 Malibu 9C1 383 84 Delta 88 403 87 Grand National 96 Ram 360 09 Crown Vic 10 Challenger R/T M6 15 Challenger Hellcat M6
[Re: RangerDan440]
#162653
12/06/08 03:59 PM
12/06/08 03:59 PM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
Not to be picky, but the original post mentioned the 1970 model year.. Also, you mentioned you car always had them. I'm taking it you're the original owner of the car or bought it from the original owner. Could very well have had them originally, but as an option. Using the point of "all R/T models came with all chrome doodads" is false. My v-code '70 Charger R/T didn't have them, wasn't on the BS. It came with turn-downs....... Either that, or someone took the tips off somewhere down the road. If the bright tips where standard on R/T and Superbees only, then why would there be a $20+ option cost listed.
Just food for thought or I'm missing something.
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
[Re: 6bblgt]
#162654
12/06/08 04:19 PM
12/06/08 04:19 PM
Posts: 8,948 Harlan, Iowa
69CoronetRT
Harlan, Iowa
"This info is taken trom the 1970 Dodge Pocket Salesman's Guide posted on Hamtramck Historical. Does anyone have the '70 PLYMOUTH version? It would be great to see it posted also."
The 70 Plymouth salesman pocket book is hard to find and $$$ when you do.
The 70 Plymouth data book will be on HH soon.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs. Over 2,000 thanks to you!
[Re: hemi68charger]
#162655
12/06/08 04:19 PM
12/06/08 04:19 PM
Posts: 17,529 Las Vegas, NV
6bblgt
Las Vegas, NV
![](/ubbthreads/images/graemlins/iagree.gif) Posts that stray from the original question often indicate how unknown the answers to these questions are. Differences exist within a model year & model. Bringing other years and models into the question doesn't help to clarify the question or answer. I know I am guilty of this also in my post above, but I was trying to point out the facts of the differences within Dodge in the '70 model year, after the Challengers got thrown into the post. So ... does anybody have a b'cast sheet (or LA fender tag) for a '70 Coronet R/T, Super Bee or Charger R/T that shows: N42 N95 N97 ?? I think the original question was answered, N42 was an OPTION ($20.80 ) on '70 Coronet R/Ts.It would be listed on the b'cast sheet or window sticker, and on a LA assembled car's fender tag.
[Re: 6bblgt]
#162657
12/07/08 01:25 AM
12/07/08 01:25 AM
Posts: 12,271 Overpriced Housing Central
RobX4406
So ... does anybody have a b'cast sheet (or LA fender tag) for a '70 Coronet R/T, Super Bee or Charger R/T that shows: N42 N95 N97 ?? ![](/ubbthreads/images/graemlins/scope.gif)
Not an LA built car but a Lynch Road 70 440-6 4 speed bee I used to own. The broadcast sheet for my old car has N95 N96 N97 AND N42 on it!
6bbl - Is your GTX Yellow by chance?
[Re: 6bblgt]
#162659
12/07/08 02:30 AM
12/07/08 02:30 AM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
I'll check my Superbee 440+6 BS when I get home. I don't know if it has N97, but it does have N42 and N95.
I can't check on my old 70 R/T as I sent the BS to the new owner
[Re: RobX4406]
#162660
12/07/08 03:34 AM
12/07/08 03:34 AM
6bblgt
Las Vegas, NV
Nope ... originally FJ5 "lime light", but custom painted early in its life.
![](http://pic20.picturetrail.com/VOL1601/960418/2754845/261827581.jpg)
[Re: stateline]
#162661
12/07/08 03:44 AM
12/07/08 03:44 AM
Posts: 6,111 Detroit
Kidsixpack
Detroit
Thanks for the replys , to add another question to the mix - are the wheel lip molding standard on a 70 Coronet RT , I do at least know it had them and there isnt anything on the fender tag
Yep!
[Re: 6bblgt]
#162663
12/07/08 06:56 PM
12/07/08 06:56 PM
Posts: 1,225 El Cerrito Ca.
gregn96cuda
El Cerrito Ca.
[image] ![](http://i41.photobucket.com/albums/e283/fishhead71/mvc-034s-1.jpg) [/image] I know these are not B bodies but I would think B&E cars would be the same for California. These two tags are from a couple of 1970 cudas I have, a 440+6 & 440 4bbl. Both cars are 4 speeds both cars have n95 but the shaker car has turned down exhaust. I was told years ago that if you had fresh air intake the tips would be deleted for noise reduction. The 440 4bbl... n41, n42, n95 The 440+6... n41, n95, n96, n97
[Re: gregn96cuda]
#162664
12/07/08 09:04 PM
12/07/08 09:04 PM
6bblgt
Las Vegas, NV
That's the problem & source of confusion. You can't compare apples to oranges, in this case b-bodies to e-bodies or 1970 Coronets to 1968 Coronets or 440-4bbl to 440-6bbl.
On an e-body the SHAKER had nothing to do with N97 - "noise reduction".
[Re: 6bblgt]
#162665
12/07/08 09:54 PM
12/07/08 09:54 PM
gregn96cuda
El Cerrito Ca.
Then please explain why the noise reduction is on the shaker car.
In California n95 + n96 got you n97 on an e body. I am sure that a few might have slipped through, but they would have been an anomaly. You must remember 1970 was the first year for earth day, and all kinds of pollution were targeted to be reduced including noise pollution. Here in California the intake volume through the fresh air system made enough noise along with the exhaust note to be over the limit, so you got n97.
Why does the 440 4 bbl have tips? Do you think the guy that bought the 6bbl didn't have the $20 for tips, or maybe he didn't want the ev2 shaker car to be too flashy with chrome tips?
[Re: 6bblgt]
#162666
12/07/08 10:15 PM
12/07/08 10:15 PM
6bblgt
Las Vegas, NV
The difference IS the 6bbl on an E-body!! Quote:
For 1970
CHALLENGER N95 - Evaporative Control System - required on all cars registered in the State of California N.A. otherwise .......... $37.85 N97 - Noise Reduction Package - required on all cars registered in the state of California equipped with 440-6 engines or 426 Hemi .......... N.C.
N97 - Noise reduction was accieved in different ways on different body platforms, again California "only". E-body - eliminate N42 "bright exhaust tips" from 440-6 & Hemi cars.
I will "assume" Plymouth's 'Cuda was dealt with in the same manner (in California).
[Re: Alaskan_TA]
#162668
12/07/08 11:10 PM
12/07/08 11:10 PM
340dart4spd
Parts Problem
Parts Problem
I have seen grills with red pin stripe in surround..and then not with pin stripe
[Re: Alaskan_TA]
#162669
12/07/08 11:12 PM
12/07/08 11:12 PM
6bblgt
Las Vegas, NV
Barry, Same 2 pages? I put some time/effort into this topic, this is what I came up with: 1970 performance cars sold in California Super BeeHEMI - N41, N95, N96, N97 (STD or Mandatory) N97 = NO TIPS383 4bbl - N41, N95, N97 (STD or Mandatory) & N42, N96 (optional) N97 = noise reduction mufflers 440 6bbl - N41, N95, N97 (STD or Mandatory) & N42, N96 (optional) N97 = add resonatorsCoronet R/THEMI - N41, N95, N96, N97 (STD or Mandatory) N97 = NO TIPS440 4bbl - N41, N95, N97 (STD or Mandatory) & N96 (optional) N97 = NO TIPS440 6bbl - N41, N95, N97 (STD or Mandatory) & N42, N96 (optional) N97 = add resonatorsCharger R/THEMI - N41, N95, N97 (STD or Mandatory) N97 = NO TIPS440 4bbl - N41, N95, N97 (STD or Mandatory) N97 = NO TIPS440 6bbl - N41, N95, N97 (STD or Mandatory) & N42 (optional) N97 = add resonatorsChallenger340 4bbl - N41, N42, N95 (STD or Mandatory) & N94, N96 (limited/optional) Challenger R/THEMI - N41, N95, N97 (STD or Mandatory) & N94, N96 (limited/optional) N97 = NO TIPS383 4bbl - N41, N42, N95 (STD or Mandatory) & N94, N96 (limited/optional) 440 4bbl - N41, N42, N95 (STD or Mandatory) & N94, N96 (limited/optional) 440 6bbl - N41, N95, N97 (STD or Mandatory) & N94, N96 (limited/optional) N97 = NO TIPSRoad RunnerHEMI - N41, N95, N96, N97 (STD or Mandatory) N97 = NO TIPS383 4bbl - N41, N95, N97 (STD or Mandatory) & N42, N96 (optional) N97 = noise reduction mufflers 440 6bbl - N41, N95, N97 (STD or Mandatory) & N42, N96 (optional) N97 = add resonatorsGTXHEMI - N41, N95, N96, N97 (STD or Mandatory) N97 = NO TIPS440 4bbl - N41, N95, N97 (STD or Mandatory) & N96 (optional) N97 = NO TIPS440 6bbl - N41, N95, N97 (STD or Mandatory) & N42, N96 (optional) N97 = add resonators'CudaHEMI - N41, N95, N97 (STD or Mandatory) & N96 (optional) N97 = NO TIPS340 4bbl - N41, N42, N95 (STD or Mandatory) & N96 (limited/optional) 383 4bbl - N41, N42, N95 (STD or Mandatory) & N96 (limited/optional) 440 4bbl - N41, N42, N95 (STD or Mandatory) & N96 (limited/optional) 440 6bbl - N41, N95, N97 (STD or Mandatory) & N96 (optional) N97 = NO TIPS![](/ubbthreads/images/graemlins/confused.gif) The guides make it "clear-as-mud", but what happened to a 383 4bbl Charger, Sport Satellite, or Coronet 500? ![](/ubbthreads/images/graemlins/shruggy.gif) ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) I'm thinking the 383 4bbl, 440 4bbl, & 440 6bbl b-bodies with N97 may have required resonators only if "tips" were ordered?? ![](/ubbthreads/images/graemlins/scope.gif) More to follow ... ![](/ubbthreads/images/graemlins/image_294343.gif)
[Re: 6bblgt]
#162670
12/08/08 01:13 AM
12/08/08 01:13 AM
Posts: 27,485 So Cal
autoxcuda
So Cal
... but what happened to a 383 4bbl Charger, Sport Satellite, or Coronet 500? ![](/ubbthreads/images/graemlins/shruggy.gif) ... ...
I thought those cars never got tips anyway. Neither did 70 383 N code E-bodies
Only non performance package (R/T, GTX, RR..) cars I can think of that got dual chrome tips were 70 A66 Challengers, 71 340 Challengers (non R/T), and maybe 71 Charger S/E 440 cars???
Getting off subject with tips, would be the 64-66 273 HP single big resonator chrome tips. Did every 273 HP get them? Or just Dart GT's and Formula "S". You could get a 273 HP Dart station wagon. ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
[Re: autoxcuda]
#162671
12/08/08 01:35 AM
12/08/08 01:35 AM
6bblgt
Las Vegas, NV
I believe we were talking N95 - "CA emissions" & N97 - "CA noise reduction". or was it N42 - "tips" on a Coronet R/T that started this? ![](/ubbthreads/images/graemlins/scope.gif)
