Disc Rotor conditioning tool
#1626314
05/29/14 10:48 AM
05/29/14 10:48 AM
Posts: 240 Ft. Wayne, IN.
QTR MILR
Ft. Wayne, IN.
Does any one know of an abrasive tool for conditioning rotors?? I saw a new product advertised a couple of weeks ago I thought would really work well. Now my wife is complaining that her Challenger's brakes are squeaking.... While I'm at it I want to remove the glaze on the rotor. Any ideas?? Thanks,
Scott
69 Satellite, 3650lb street car... Dunnuck Racing pump gas 440. Best of 10:60@127...
Re: Disc Rotor conditioning tool
[Re: pattyboy 572]
#1626316
05/29/14 01:27 PM
05/29/14 01:27 PM
QTR MILR
Ft. Wayne, IN.
That's exactly what I was looking for!! Thanks!!!
Scott
[Re: QTR MILR]
#1626317
05/29/14 01:46 PM
05/29/14 01:46 PM
Posts: 21,083 Niles , Ohio
therocks
Niles , Ohio
Just use what i used at the shop and I do at home.My die grinder with a rolok pad.At work when we could turn rotors I let them spin and hit both sides.Home I just work it around the rotor.There was also a Tech bulliten years ago.It said that to quiet squeals take a sharp screwdriver and pull it across the rotor and it leaves small marks.I went fron hub side to the outside.It actually worked.Brake pad compound on the stell part also makes a big difference.Rocky
Chrysler Firepower
[Re: jbc426]
#1626320
05/30/14 07:19 PM
05/30/14 07:19 PM
therocks
Niles , Ohio
jbc I started using ceramic pads.Had Bendix best on the 65.I went ceramics and the stopping is great.Plus no dust and my price was under 30 bucks at Advanced.Just put them on my brothers Caravan also.The PT will get them when I replace the brakes in about a month.Rocky
Chrysler Firepower
[Re: RapidRobert]
#1626323
05/31/14 01:42 PM
05/31/14 01:42 PM
therocks
Niles , Ohio
RR we used to use them at the shop.On the ambulances we used the severe duty ones.Then on almost every car we used Advanced Golds.Never any problems.I use them on all my relatives cars.The wifes PT has about 65K on a set.Its about time for new ones though.Same with the big name rotors.We used only them.Then went to store brands and had basically no problems.I had more problems with the name brands than I want to remember.After you do a few thousand brake jobs you learn what works and what dosent.Rocky
Chrysler Firepower
[Re: RapidRobert]
#1626325
05/31/14 02:20 PM
05/31/14 02:20 PM
Posts: 75,089 A Banana Republic near you.
JohnRR
I've been using Wagner thermo quiest on my 2004 Grand Cherokee and until this Jeep I swore by them , now worst pad ever ,
Double R what changed? was it a pad composition material change or just the vehicle?
I don't know what changed all I know is that I have put 3 sets of fronts and 2 sets of back on this thing in the 30 months I have owned it and the common denominator is the Wagner Thermoquite brake pads. First 2 sets of rotors were Pronto store boxed Chinese made, braking surfaces are thinner than original, next set on the front were centrics , thicker braking surfaces like factory. I figured they would cure it, the pulsating started faster than with the cheaper rotors. I'm going back to regular pads and deglaze the rotors if they show true on the lathe. Hopefully I trade it before it starts again.
The brake pads work great till the pulsating starts , you can see the marks from pulsating on the rotor surfaces .
[Re: JohnRR]
#1626326
05/31/14 05:43 PM
05/31/14 05:43 PM
therocks
Niles , Ohio
John try a set of Advance Golds.I used thousands of sets and they were always good.Lately Ive used their ceramic pads.Just put a set and rotors on my brothers Caravan.Rocky
Chrysler Firepower
