Re: Small Block Water Bypass
[Re: 440PURSUIT]
#1626269
05/29/14 04:08 AM
05/29/14 04:08 AM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
Yes, do you want stable engine temps? This is not for your comfort (heat in the car), but rather to circulate coolant through the top of the motor, where the heat is.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: Polarapete]
#1626270
05/29/14 04:26 AM
05/29/14 04:26 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
it allows circulation of the water during warm up. Prevents water pump cavetation..
I am truckless..
[Re: 340SHORTY]
#1626271
05/29/14 04:42 AM
05/29/14 04:42 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
On Drag Car...never have used it..plugged.
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 340SHORTY]
#1626272
05/29/14 10:18 AM
05/29/14 10:18 AM
Posts: 15,487 Florida
scratchnfotraction
if you block the by-pass hose you should run a restricter in the t-stat housing and not a t-stat. the pump can and will cavitate when t-stat is closed and rpms go up.
[Re: 440PURSUIT]
#1626273
05/29/14 11:44 AM
05/29/14 11:44 AM
RapidRobert
I block it completely on our stock car that uses NO stat tho I believe every other type of car needs a stat for the faster warmup not for a restriction & some amount of bypass & I use a piece of cardboard in front of the rad to effect a normal (faster) warmup tho the increased wear from a slow warmup is a non issue in a stock car that is operated 1 or 2 days a week but I'm anal & a perfectionist. I've always wondered why the SB's needed such a huge bypass as that is coolant that ain't gettin cooled in the rad and if you look straight down on a BB housing the bypass hole is only a fraction of the size of the SB one. There must be a good reason in the design of the SB cooling system that had to be done in a certain way cuz engineers ain't stupid tho they do design cars for Grandma to drive daily for 100K (not sure how that relates tho) so it must be related to the design of the SB system that it needs that much bypass. For street I use the anticav plate (plus a bunch of other cooling mods) & restrict the bypass to 1/2 of it's original dia plus a (180) stat
[Re: 360view]
#1626277
05/30/14 03:51 PM
05/30/14 03:51 PM
Posts: 1,012 indiana
mcmopars
indiana
As part of using Evans NPG waterless coolant I bought a 17 mm Chrome plated 3/8th drive socket and slipped it inside a new coolant bypass hose and installed on my Magnum 360 V8.
This closed up the bypass passageway to a three eighths square.
I was hoping that the partially restricted bypass would increase full throttle engine maximum cooling enough to eliminate audible pinging starting about 3800 RPM when using 87 Octane gasoline in +95 degree North Carolina summer weather climbing a 6 percent grade hill.
There was no change after the bypass restriction.
Switching from 87 to 92 Octane would totally eliminate the full throttle pinging.
Running straight water as coolant with no thermostat would also eliminate the pinging on 87 Octane.
Removing sparkplugs from Cylinders 7 and 8 and spraying in official Chrysler Combustion Chamber Conditioner foam in, then reinstalling sparkplugs would eliminate the full throttle pinging on 87 Octane, but only for about 3 to 4 days.
i feel really stupid after reading this.what?
