Re: wheel well trim
[Re: 2JcodeChargers]
#1626027
05/28/14 07:30 PM
05/28/14 07:30 PM
Posts: 18,165 Mass
DAYCLONA
Mass
Metro closed up the Mopar end of the business, they went back to making/supplying skateboards...yes really www.rosevillemoparts.com has purchased the rights/marketing to some of their mopar product lines, contact them to see what's still available... Mike
Re: wheel well trim
#1626033
06/03/14 05:15 AM
06/03/14 05:15 AM
Posts: 1,661 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
Good thing Metro is gone, at least concerning wheel opening trim.
Take the Layson's trim for sure over Metro. Layson's is made of rolled aluminum sheet, formed and BRIGHT anodized, as was done originally. They look spectacular.
The Metro trash was extruded aluminum, formed, then DULL anodized. Problem is the chemistry of the aluminum for extrusion is not suitable for bright anodizing. As soon as you see the Metro trim, you know it's a long way from being bright.
Okay, Layson's, now that I have tooted your horn, how's about filling my backorder for 69 Barracuda, one pc right rear, Layson Part No. MY-679RP. Originally ordered a set of 4 on 10/30/09, but the right rear was defective and immediately returned and put on backorder. Reordered again on 10/3/12, your order 76941. Still waiting, and please don't forget the $thousands I already sent your way.
Re: wheel well trim
[Re: kentj340]
#1626034
06/03/14 08:07 PM
06/03/14 08:07 PM
kentj340
Cut and Shoot, TX
At the top of the photo is original factory trim.
The middle one is Metro, and notice that the reflection of my camera and me is just a shadowy blurr.
The bottom one is Layson's, and you can see a pretty good reflection of my camera and me.
As already said, the Layson's is correctly made from aluminum sheet that bright anodizes beautifully. The trim is rather soft and pliable like the oriinal.
The Metro junk was made from extruded aluminum that does not bright anodize, and it is very work hardened and stiff.
It's a good idea to weld up the fender holes, because you may run into hole alignment problems wih anybody's trim, including NOS.
Of course, as we all know, NOS stands for "Nitrious (sic) Oxcide (sic) Systems", right Rick? Thanks for your call and anxiously awaiting.
