2295s on LYs and balancing #1625056
05/25/14 11:28 PM
05/25/14 11:28 PM
Australia
big_wedge Offline OP
Australia
Iv read that when using the trw 2295 piston on the old six pack rods a balance job will require adding mallory weight to the crank, but what about when using the 2295s on the LY rod, is adding weight still needed?
Re: 2295s on LYs and balancing [Re: big_wedge] #1625057
05/25/14 11:30 PM
05/25/14 11:30 PM
Oklahoma
hemiiroc Offline
hemiiroc  Offline
Oklahoma
Usually not.
Re: 2295s on LYs and balancing [Re: big_wedge] #1625058
05/25/14 11:53 PM
05/25/14 11:53 PM
Cab_Burge Online work
Cab_Burge  Online Work
Anytime you change one componentlike the rods or pistons, even the wrist pins in the rotating assembly you should have it check for balance The factory pistons are heavy, so are the six pak rods, but in a different place You have two different weights that are looked at and measured when balancing rotating masses, the recpricating(SP) and the actual weights of each component are matched so they weigh the same as the lightest individual components in the crank assembly, all rods weigh the same on both ends, all pistons, wrist pins, rings, bearings and so on weigh the same
Re: 2295s on LYs and balancing [Re: Cab_Burge] #1625059
05/26/14 02:07 AM
05/26/14 02:07 AM
Australia
Australia
it is my intention to get a balance done on this assembly I just was not sure if moly needed to be added when using this rod and piston together,
thank you both for the replys
Re: 2295s on LYs and balancing [Re: big_wedge] #1625060
05/26/14 08:44 AM
05/26/14 08:44 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
With the sixpac rods and 2295s on a crank that was balanced for the LY and a lighter piston combo you may need Mallory weight if the total bobweight exceeds 20 grams.It depends on how much weight was removed from the crank on the previous balance.
Re: 2295s on LYs and balancing [Re: B G Racing] #1625061
05/26/14 09:00 AM
05/26/14 09:00 AM
Australia
Australia
oh ok, just to clarify this is a complete different build. I am not changing from six pac to ly rods. the 2295s have all been balanced to the same as have the LY rods as well as shot peened, aftermarket bolts & resized etc etc. the factory fordged crank is ground .010 on all journals, the set just needs to be balanced complete.
Re: 2295s on LYs and balancing [Re: big_wedge] #1625062
05/26/14 10:44 AM
05/26/14 10:44 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
....when using the 2295s on the LY rod, is adding weight......needed?
This is the question, right?
I'd go with the "Usually not" response
Re: 2295s on LYs and balancing [Re: BSB67] #1625063
05/26/14 01:55 PM
05/26/14 01:55 PM
I should have stated that on a stock BB Mopar forged steel crank that was internally balanced at the factory you may need to have some of the balance holes welded up with those parts, some of them, not all of them I've built a bunch of 440 with those parts, I'm sure almost all of them had metal added by welding in the balance holes, some probally had some additional metal removed by drilling the counterweights also
Re: 2295s on LYs and balancing [Re: big_wedge] #1625064
05/26/14 02:54 PM
05/26/14 02:54 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
The original question was Mallory weight needed?You won't know till the bobweight is calculated and the crank is spun on the balancing machine.
Re: 2295s on LYs and balancing [Re: B G Racing] #1625065
05/27/14 01:25 PM
05/27/14 01:25 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
This is the correct answer ...
