wiring question #1625045
05/25/14 10:39 PM
05/25/14 10:39 PM
wisconsin
mod381 Offline OP
mod381  Offline OP
wisconsin
Hi everyone I was just trying to clean up the wiring on my 1972 duster and I have a question on what a wire all runs to. I have the manual and I can not find in the wiring diagrams I have where it shows this wire coming to and from the fuse block. The fuse block is labeled brake and LP for the circuit in question. It looks like the blue/white wire power is coming from the ignition switch. The diagram does not show this wire going to the fuse block. I can tell you that it goes to terminal 1 of the instrument cluster. It also goes to a bulb (was not hooked to anything) and to what looks like a relay. The wire splices and goes to 5 wires just to the left of the gauges in the wiring harness. I would just like to know where they all go without having to take a bunch apart to find out. Thanks
Re: wiring question [Re: mod381] #1625046
05/25/14 10:40 PM
05/25/14 10:40 PM
wisconsin
mod381 Offline OP
mod381  Offline OP
wisconsin
fuse block
Re: wiring question [Re: mod381] #1625047
05/25/14 10:41 PM
05/25/14 10:41 PM
wisconsin
mod381 Offline OP
mod381  Offline OP
wisconsin
relay
Re: wiring question [Re: mod381] #1625048
05/25/14 11:03 PM
05/25/14 11:03 PM
any addit'l info in the wiring diagrams at www.mymopar.com
Re: wiring question [Re: RapidRobert] #1625049
05/25/14 11:45 PM
05/25/14 11:45 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Key/door buzzer?
Re: wiring question [Re: RapidRobert] #1625050
05/26/14 12:18 AM
05/26/14 12:18 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Some of those are very wrong... DAMHIK!
If you have a FSM, that's your best source.
Re: wiring question [Re: RobX4406] #1625051
05/26/14 12:52 AM
05/26/14 12:52 AM
wisconsin
mod381 Offline OP
mod381  Offline OP
wisconsin
Maybe that is the problem. I do have a FSM but it is on a cd and it will not play on my new windows 8 computer it says it is the wrong bit version. I have a print off diagram but it is just like the ones on mymopar and it seems to be wrong.
Re: wiring question [Re: RobX4406] #1625052
05/26/14 01:31 AM
05/26/14 01:31 AM
I knew mymopar was missing a very few circuits but I was not aware that they had errors. I've used it alot & have had perfect luck so far on the circuits I did trace out but I will be alert
Re: wiring question [Re: RapidRobert] #1625053
05/26/14 04:19 AM
05/26/14 04:19 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
There are missing diagrams at mymopar (don't ask me how I know), but they are almost all Motor or National Service. Those are very generic and generally don't include optional circuits.
Re: wiring question [Re: Jim_Lusk] #1625054
05/26/14 04:29 AM
05/26/14 04:29 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
In 1973 the dark blue wire to a lamp is the seat belt warning lamp.
Re: wiring question [Re: Jim_Lusk] #1625055
05/26/14 11:13 PM
05/26/14 11:13 PM
wisconsin
mod381 Offline OP
mod381  Offline OP
wisconsin
Thanks for the idea. I had to look in a 1973 fsm and that wire does go to the seatbelt warning system.
