Re: Swapping from 727 to Turbo 400 [Re: Ian] #1623915
05/24/14 08:24 PM
05/24/14 08:24 PM
Scatchamatoon
Saskabusa Offline OP
Scatchamatoon
a glide will fit in tunnel with no mods and will work well at your power level
Thanks. I was pretty sure that would work. I am slightly familiar with those.
I am trying to figure if it is worth while to look at the 400 or just stick with a PG.
What I want to do is be able to bracket race the car at 9.1 have a completely reliable drivetrain and have capacity to go faster.
1974 Roadrunner
1967 Charger
Re: Swapping from 727 to Turbo 400 [Re: Saskabusa] #1623916
05/24/14 10:51 PM
05/24/14 10:51 PM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
i love the glide and they will handle anything you can throw at it ,my car ia a little lighter and a less power than yours 1.37 60 ft std gear set 280 $ converter on a average track at 3550 lbs .i think you can not go wrong with a glide in yours ,pm if your keen i can get you a good deal on them cheers
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: Swapping from 727 to Turbo 400 [Re: Ian] #1623917
05/25/14 10:44 AM
05/25/14 10:44 AM
Mississippi
Mr. T Offline
Mr. T  Offline
Mississippi
I am not trying to pick a fight. I have known bracket racer's that have done away with their 727's and replaced them with Power Glide's in order to make their cars more consistent by reducing the initial torque and only having to shift once. But, what exactly is supposed to be the advantage of a Turbo 400 over a 727?
Re: Swapping from 727 to Turbo 400 [Re: Mr. T] #1623918
05/25/14 11:58 AM
05/25/14 11:58 AM
lino lakes,MN
onebaddakota Offline
lino lakes,MN
I always thought that the perceived advantages of the turbo 400 weren't great enough to warrant the cost. Once you outgrew the HP level of a built 727, you were in glide territory anyway. Hopefully, the "in the know" guys can help me out here.
10.56 at 125.6, with a 1.43 60 ft. E85, Hyd. Roller 410 magnum,full exhaust, 3500 race weight.
Re: Swapping from 727 to Turbo 400 [Re: Steve1118] #1623919
05/25/14 02:28 PM
05/25/14 02:28 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
"most folks in the know recognize the superiority of the TH400 and have for a long time"
I see, I understand now. I guess we've must been under a rock since 1964. Silly us for not seeing the obvious superiority of the TH400 and wasting time with TF's on our Hemi and wedge cars....if we'd have only known...... Excuse us for not being in the know.
Brand loyalty versus reality.
Re: Swapping from 727 to Turbo 400 [Re: John_Kunkel] #1623920
05/25/14 02:50 PM
05/25/14 02:50 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Where does the C6 rank in the mix?
Re: Swapping from 727 to Turbo 400 [Re: Mr. T] #1623921
05/25/14 08:46 PM
05/25/14 08:46 PM
in front of the computer
8
80arrow Offline
80arrow  Offline
I might be wrong but I think you can get different first gear ratios for a th400, not sure if you can with a 727? Changing the first gear ratio would help if you have a lot of power and limited traction.
Re: Swapping from 727 to Turbo 400 [Re: 80arrow] #1623922
05/25/14 09:10 PM
05/25/14 09:10 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
available from Tranzact of Indy for 727.
1:95 1st 1:35 2nd 1:1 3rd
2:12 1st 1:35 2nd 1:1 3rd
2:28 1st 1:40 2nd 1:1 3rd
Tony
70 AARCuda Vitamin C
Re: Swapping from 727 to Turbo 400 [Re: 70AARcuda] #1623923
05/25/14 09:32 PM
05/25/14 09:32 PM
8
80arrow Offline
80arrow  Offline
Thanks, I was thinking of changing the first gear in my 727. What is the standard first ratio?
Re: Swapping from 727 to Turbo 400 [Re: 80arrow] #1623924
05/26/14 08:26 AM
05/26/14 08:26 AM
moparx Offline
moparx  Offline
2.48 I believe
Re: Swapping from 727 to Turbo 400 [Re: moparx] #1623925
05/26/14 10:42 AM
05/26/14 10:42 AM
Mo.
racerx Offline
racerx  Offline
Mo.
2.76
Re: Swapping from 727 to Turbo 400 [Re: racerx] #1623926
05/27/14 08:21 AM
05/27/14 08:21 AM
moparx Offline
moparx  Offline
oops. I goofed. 727 ratios are : 2.45 low, 1.45 2nd, 1:1 drive & 2.20 reverse.
904/999 are: 2.74 low,1.54 2nd, 1:1 drive &
2.21 reverse. sorry for the mistake.
with that being said, I think there was a low gear planetary set for the 727 that was around a 2.77 low but I don't know for sure what it really was.
Re: Swapping from 727 to Turbo 400 [Re: moparx] #1623927
05/27/14 12:22 PM
05/27/14 12:22 PM
Gilbert AZ
tsanchez Offline
tsanchez  Offline
Gilbert AZ
I am thinking about doing the same thing, good converter is going to be 1200, then drum and sprag, brake etc. Ill have 2500 in it and still have limited converter choices(AMC) so going t400 I can borrow converters from all my friends and brake and all the other things are cheaper. I could space out the 727 but then it gets real tight with the csr shield.
Re: Swapping from 727 to Turbo 400 [Re: MR_P_BODY] #1623928
05/27/14 01:18 PM
05/27/14 01:18 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
I also don't understand the sudden shift on the perception of the TF.
It's not "sudden", most folks in the know recognize the superiority of the TH400 and have for a long time.
Doesnt the TH400 use a sprag also
I am no expert on either. But it seems that people think only Torqueflites explode. Theres exploding TH400s too. I don't know what causes it in the case of the 400s, but it happens.
Re: Swapping from 727 to Turbo 400 [Re: GTX MATT] #1623929
05/27/14 02:29 PM
05/27/14 02:29 PM
Cincinnati, Ohio
d7cook Offline
d7cook  Offline
Cincinnati, Ohio
Start the burnout in 2nd or 3rd and never neutral the trans at the stripe. Not doing that will cause explosions.
TH400's are heavy and do eat up some HP but they are also very tough and easy to build. Shift quality is better IMHO and the ability to buy an SFI case is a big plus.
In my case I just used a GM car with a TH 400 and swapped the motor. LOL
1967 Coronet, 1989 Daytona tube chassis. Former cars, 66 Charger, 67 R/T, 69 Coronet, 67 Dart GT. -Banned for life from V8Buick.com-
