Re: Swapping from 727 to Turbo 400
[Re: Saskabusa]
#1623916
05/24/14 10:51 PM
05/24/14 10:51 PM
Posts: 1,044 Victoria, Australia
Ian
Victoria, Australia
a glide will fit in tunnel with no mods and will work well at your power level
Thanks. I was pretty sure that would work. I am slightly familiar with those.
I am trying to figure if it is worth while to look at the 400 or just stick with a PG.
What I want to do is be able to bracket race the car at 9.1 have a completely reliable drivetrain and have capacity to go faster.
i love the glide and they will handle anything you can throw at it ,my car ia a little lighter and a less power than yours 1.37 60 ft std gear set 280 $ converter on a average track at 3550 lbs .i think you can not go wrong with a glide in yours ,pm if your keen i can get you a good deal on them cheers
[Re: 70AARcuda]
#1623923
05/25/14 09:32 PM
05/25/14 09:32 PM
Posts: 814 in front of the computer
80arrow
I might be wrong but I think you can get different first gear ratios for a th400, not sure if you can with a 727? Changing the first gear ratio would help if you have a lot of power and limited traction.
available from Tranzact of Indy for 727.
1:95 1st 1:35 2nd 1:1 3rd 2:12 1st 1:35 2nd 1:1 3rd 2:28 1st 1:40 2nd 1:1 3rd
Thanks, I was thinking of changing the first gear in my 727. What is the standard first ratio?
[Re: 80arrow]
#1623924
05/26/14 08:26 AM
05/26/14 08:26 AM
Posts: 19,568 north of coder
moparx
2.48 I believe
[Re: racerx]
#1623926
05/27/14 08:21 AM
05/27/14 08:21 AM
moparx
oops. I goofed. 727 ratios are : 2.45 low, 1.45 2nd, 1:1 drive & 2.20 reverse. 904/999 are: 2.74 low,1.54 2nd, 1:1 drive & 2.21 reverse. sorry for the mistake. with that being said, I think there was a low gear planetary set for the 727 that was around a 2.77 low but I don't know for sure what it really was.
