Page 8 of 8 1 2 3 4 5 6 7 8
Re: Requesting guidance on a new build.... [Re: Chris'sBarracuda] #1623260
06/25/14 10:18 AM
06/25/14 10:18 AM
Idaho
1320Dart Offline OP
1320Dart  Offline OP
Idaho
Yes I do understand better now after speaking with the many guru's here about head flow and cubic inch.
I knew a guy a while back that had a 596 Mopar Wedge. 4.625 stroke and 4.530 bore. he had very very nice parts in it. Heads flowed 420 I think. He could only get 1000 to 1010 hp out of it. It just didn't make sense to me. I still feel that his combo was off some too.
Greg
Cost is irrelevant, making memories is far more valuable!biggrin
Re: Requesting guidance on a new build.... [Re: 1320Dart] #1623261
06/25/14 10:22 AM
06/25/14 10:22 AM
Idaho
1320Dart Offline OP
1320Dart  Offline OP
Idaho
I mainly want to make sure I do this right. If I have to do it again I'll probably get divorced and have to come live with one of you on here
Greg
Re: Requesting guidance on a new build.... [Re: 1320Dart] #1623262
06/25/14 11:31 AM
06/25/14 11:31 AM
corpus christi tex
Cheatham Offline
Cheatham  Offline
corpus christi tex
my combo is my first big bore long stroke deal, i origanally wanted to do a big bore short stroke motor cuz of the weight of the car, i wanted a 540ci but mike @ muscle motors didnt have a 4.250 crank on hand and offered a 4.50 crank for the same money so i said ok, as light as my car is turning out i see its going to be a struggle to get it to hook with the long arm crank, im going to try it as is and if its a pain to get the car to hook up then ill change to a short stroke maybe in the 3.75 - 4.25 stroke to calm the low end down. this is going to be a run what you brung type car not a bracket or class type car.
Re: Requesting guidance on a new build.... [Re: Cheatham] #1623263
06/25/14 11:51 AM
06/25/14 11:51 AM
Idaho
1320Dart Offline OP
1320Dart  Offline OP
Idaho
I can understand that.
I'd like to see what my o'l fat girl can do with the new bullet. Then dial it back for some longevity and consistency.
Greg
Re: Requesting guidance on a new build.... [Re: 1320Dart] #1623264
06/25/14 12:00 PM
06/25/14 12:00 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Yes I have run 4.5 stroke stuff and IMO they ran like poo..Last one was a Stage V Hemi in my Barracuda car went 8.70's with that at 3000lbs. What a turd!!! The Stage V stuff was ok but it will be the last time I RACE an old school hemi unless I have a blower for sure. Had a lot f money in that motor for it performing like it did.
I do not understand why Mopar guys are so afraid of RPM. Only a few ways to make power and RPM is one of them. Especially if you are cylinder head limited RPM is the ONLY way to make power. If you build it right they will last just fine at a tad more RPM, but you have to have your comfort zone I suppose. IMO 8000-8500 in the traps is not gonna hurt anything and can be very durable if done right.
Re: Requesting guidance on a new build.... [Re: Al_Alguire] #1623265
06/25/14 12:39 PM
06/25/14 12:39 PM
Idaho
1320Dart Offline OP
1320Dart  Offline OP
Idaho
Why do you believe the reason is, that the motor with the 4.5 crank ran like poo?
Greg
Re: Requesting guidance on a new build.... [Re: Al_Alguire] #1623266
06/25/14 12:57 PM
06/25/14 12:57 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I agree 100%... I have always been a rpm guy.. and
if you look at how HP/torque is measured... the number
of pulses in a minute(pulse being a firing) and the
more pulses you get in that minute the more power
it will make... its just a matter of building the
engine with light parts and good balance... most times
I turn down the counter weights on the crank to move
the weight in closer to the center line... then use
light pistons... big stroke makes a ton of torque
but that can cause issues at the line to maintain
traction... I always look at what a pro stock engine
is.. short stroke with big bores and a ton of rpm...
but you have to have heads and induction to support
the rpm then also you need good exhaust to get it out..
What I said before about running meth is that burns
2X the amount of fuels and that takes volume/area
to get that quantity in and out... if you were to
look at heads sold by different manufactures you will
see that they have larger valves and flow over the
gas versions of the same head
Re: Requesting guidance on a new build.... [Re: MR_P_BODY] #1623267
06/25/14 01:25 PM
06/25/14 01:25 PM
Idaho
1320Dart Offline OP
1320Dart  Offline OP
Idaho
Honest, I'm not being a smart alec. How do you account for the same motor, going from race fuel to alcohol, making more power, if the extra alcohol is taking up more room and is cutting back on the much needed oxygen?
Greg
Re: Requesting guidance on a new build.... [Re: 1320Dart] #1623268
06/25/14 01:30 PM
06/25/14 01:30 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
They usually make more torque, but less HP at sea level tracks.. The idea is the more fuel you can put in an engine, the more air you get through it, and alcohol carries it's own oxygen molecule allowing better power in high altitude situations. At sea level, not so much. Also, alcohol is very consistent.
Re: Requesting guidance on a new build.... [Re: camastomcat] #1623269
06/25/14 01:40 PM
06/25/14 01:40 PM
Idaho
1320Dart Offline OP
1320Dart  Offline OP
Idaho
That is the main reason why I want to use it in this motor that I'm building. More consistency. Our actual elevation at the track is 2720 feet. Oh and the other reason I want to use alcohol is that it is WAY cheaper than C-16
Thank you for explaining about the alcohol carrying it's own oxygen molecule.
Greg
Re: Requesting guidance on a new build.... [Re: 1320Dart] #1623270
07/01/14 12:22 PM
07/01/14 12:22 PM
Idaho
1320Dart Offline OP
1320Dart  Offline OP
Idaho
Anyone have any rod recommendations? ( aluminum or steel )
Pros/Cons
Goods/Bads
Greg
Re: Requesting guidance on a new build.... [Re: 1320Dart] #1623271
04/01/15 06:26 PM
04/01/15 06:26 PM
Idaho
1320Dart Offline OP
1320Dart  Offline OP
Idaho
This is way over due and a much needed update on my build so far;
Well I did finally get my new wedge block a few months back.
- 4.500 bore KB block with the 54mm cam upgrade, in the standard cam location.
- K-1 crank 4.675 with 2.2 journals (4.675 is correct)
That makes 595ci.
- Molnar 7.1 rods
- Jesel belt drive
- B1-MC heads CNC ported. They flow 440 range on Intake, 300 range on Ex.
- Jesel paired shaft rocker arms, 1.7 ratio.
- I have a set of Billet Specialty valve covers being made. Had to do that to clear the rocker arms.
Been waiting over a month for Koffel's to get more B1 intakes made.
Haven't ordered a cam, pistons, lifters or push rods yet.
I will probably need a new tranny. Or severely upgrade the glide I have.
Needless to say it has been slow going.
Greg
